[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM
Like Tree10Likes
Old   July 15, 2014, 13:33
Default swak4foam >>>> INSTALLATION PROBLEM
stevem garcia
steven123 is on a distinguished road
During swak4foam installation, I receive a terminal erros:
(I use ubuntu 14.04 with openfoam 2.3.0 installed from this video tutorial: "Building and installing OpenFOAM 2.3.0 on Ubuntu 14.04 from source"https://www.youtube.com/watch?v=LkLgwm64jGI )
My step-by-step:
1º STEP
Install the necessary packages:
sudo apt-get install build-essential bison flex subversion git mercurial wget
2º STEP
Download from the repository
HTML Code:
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
(cd swak4Foam && hg update port_2.0.x)
3º STEP
cd swak4Foam
4º STEP
./Allwmake
AND GIVES THE FOLLOWING ERROR...:
a@a-Aspire-V3-571:~/OpenFOAM/swak4f/attempt2/swak4Foam$ ./Allwmake
Previously compiled for OpenFOAM
No file 'swakConfiguration'. Python etc won't work. See README for details
Checking swak4Foam-version and generating file
abort: no repository found in '/home/a/OpenFOAM/swak4f/attempt2/swak4Foam' (.hg not found)!
Swak version is 0.3.1
./Allwmake: line 60: wmake: command not found
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
Anyone know how to fix it?
THANKS FRIENDS FOR ALL ATTENTION!
Luttappy likes this.
steven123 is offline   Reply With Quote
Old   July 15, 2014, 16:21
stevem garcia
I dowloaded swak4foam from:
http://openfoamwiki.net/index.php/In...2.3.0_to_2.3.x >>>ISWAK4FOAM INSTALLATION FOR OpenFOAM 2.3.0 to 2.3.x
Old   July 16, 2014, 19:29
stevem garcia
Please, Anyone?
Old   July 16, 2014, 20:36
stevem garcia
I got sucess... To install swak4foam, It is necessary one thing: remove "alias" from variables into bashrc
alias fe31='source $HOME/foam/foam-extend-3.1/etc/bashrc' gives the error above
removing alias:
after remove it, ./Allwmake works!!!
after allwmake finished and checking the version of swak4foam:
a@a-Aspire-V3-571:~$ funkySetFields
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.1                                |
|   \\  /    A nd           | Web:         http://www.extend-project.de       |
Build    : 3.1-f77b4801a214
Exec     : funkySetFields
Date     : Jul 16 2014
Time     : 20:28:03
Host     : a-Aspire-V3-571
PID      : 29818
CtrlDict : /home/a/foam/foam-extend-3.1/etc/controlDict
Case     : /home/a
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
swakVersion: 0.3.1 (Release date: 2014-07-11)
--> FOAM FATAL ERROR:
funkySetFields: time/latestTime option is required
    From function main()
    in file funkySetFields.C at line 643.
FOAM exiting
Elham and Luttappy like this.
Old   July 22, 2014, 17:50
Assistant Moderator
Bernhard Gschaider
removing alias:
Date     : Jul 16 2014
Time     : 20:28:03
PID      : 29818
Case     : /home/a
nProcs   : 1
FOAM exiting
Just became aware of this because I was on vacation.
Thanks for posting the solution to your own problem. This makes things easier for people that have the same problem.
vs1 likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 1, 2015, 16:28
Rafael Marques
rafa13 is on a distinguished road
Hi everybody,
I am quite new at Openfoam and on linux. I tried to install swak4foam but i get this error message, ah first of all i use ubuntu 14.01 LTS and OF2.2.2. I tried mant this almost everything. but here is the message,
Previously compiled for OpenFOAM 2.2.2
/home/rafa/OpenFOAM/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
abort: no repository found in '/home/rafa/OpenFOAM/swak4Foam' (.hg not found)!
Swak version is 0.3.2
Bison is version 2.7.12-4996
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 2 Patch 2 (-1 == x / 2)
No change to swak4FoamParsers/foamVersion4swak.H
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
SOURCE=writeFields/writeFieldsGeneral/writeFieldsGeneralFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100  -I../swak4FoamParsers/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/meshTools/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/sampling/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/triSurface/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/reactionThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/SLGThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/radiation/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/regionModel/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/surfaceFilmModels/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/turbulenceModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/transportModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/intermediate/lnInclude  -IlnInclude -I. -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/writeFieldsGeneralFunctionObject.o
SOURCE=timeManipulation/timeManipulationFunctionObject/timeManipulationFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100  -I../swak4FoamParsers/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/meshTools/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/sampling/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/triSurface/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/reactionThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/SLGThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/radiation/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/regionModel/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/surfaceFilmModels/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/turbulenceModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/transportModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/intermediate/lnInclude  -IlnInclude -I. -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/timeManipulationFunctionObject.o
SOURCE=timeManipulation/setDeltaTByTimelineFunctionObject/setDeltaTByTimelineFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100  -I../swak4FoamParsers/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/meshTools/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/sampling/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/triSurface/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/reactionThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/SLGThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/radiation/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/regionModel/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/surfaceFilmModels/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/turbulenceModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/transportModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/intermediate/lnInclude  -IlnInclude -I. -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setDeltaTByTimelineFunctionObject.o
SOURCE=manipulateFvSolutionFvSchemes/manipulateFvSolutionFvSchemesFunctionObject/manipulateFvSolutionFvSchemesFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100  -I../swak4FoamParsers/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/meshTools/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/sampling/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/triSurface/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/reactionThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/SLGThermo/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/liquidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solids/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/solidMixture/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/radiation/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/regionModel/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/regionModels/surfaceFilmModels/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/turbulenceModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/transportModels -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/basic/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/lagrangian/intermediate/lnInclude  -IlnInclude -I. -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/manipulateFvSolutionFvSchemesFunctionObject.o
writeFields/writeFieldsGeneral/writeFieldsGeneralFunctionObject.C:60:30: fatal error: basicThermoCloud.H: No such file or directory
 #include "basicThermoCloud.H"
compilation terminated.
make: *** [Make/linux64GccDPOpt/writeFieldsGeneralFunctionObject.o] Error 1
make: *** Waiting for unfinished jobs....
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
/usr/bin/ld: cannot find -lsimpleFunctionObjects
collect2: error: ld returned 1 exit status
make: *** [/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so] Error 1
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
Compiling swakFvOptions
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakFvOptions.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
make: *** [/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakPythonIntegration.so] Error 1
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakMeshWaveFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakCoalCloudAdaptor.so' is up to date.
Compiling user function-plugin ../Examples/UserPlugins/swakTestFunctionPlugins
'/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib/libswakTestFunctionPlugin.so' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/fieldReport' is up to date.
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt       -I/usr/include/python2.7 -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/sampling/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/meshTools/lnInclude -I../../Libraries/swakPythonIntegration/lnInclude/ -I../../Libraries/simpleFunctionObjects/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/rafa/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/funkyPythonPostproc.o -L/home/rafa/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib \
         -lfiniteVolume     -lmeshTools -L/usr/bin -lpython2.7     -L/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/lib -lswakPythonIntegration -lsimpleFunctionObjects     -lswak4FoamParsers -lOpenFOAM -ldl   -lm -o /home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkyPythonPostproc
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date.
/usr/bin/ld: cannot find -lswakPythonIntegration
make[1]: *** [/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkyPythonPostproc] Error 1
make: *** [funkyPythonPostproc] Error 2
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkySetLagrangianField' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date.
make[1]: `/home/rafa/OpenFOAM/rafa-2.2.2/platforms/linux64GccDPOpt/bin/funkyWarpMesh' is up to date.
make: Target `application' not remade because of errors.
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/rafa/OpenFOAM/swak4Foam/Libraries (most people will be fine without setting that variable)
and i don't know to fix this....when i write funkySetFields in the terminal i get OK
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9739c53ec43f
Date   : Aug 01 2015
Time   : 20:26:44
Host   : "rafa"
PID    : 31915
Case   : /home/rafa
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
swakVersion: 0.3.2 (Release date: 2015-05-31)
    in file funkySetFields.C at line 723.
FOAM exiting
but i am not uble to use Swak4 Foam maybe some body have a Ideia??
thanks ang greets
Rafa Marques
Last edited by wyldckat; August 2, 2015 at 12:43. Reason: Added [CODE][/CODE] markers
rafa13 is offline   Reply With Quote
Old   August 2, 2015, 16:21
Retired Super Moderator
Bruno Santos
Greetings Rafael,
Wow, I wasn't aware about this issue in OpenFOAM 2.2... I've reported this and provided a fix for swak4Foam 0.3.2 just now: https://sourceforge.net/p/openfoam-e...swak4foam/228/
The file in attachment should help, as it's the patch provided in the bug report. To apply it, do the following steps:
  1. Download the attached file "writeFieldsGeneralFunctionObject.C.patch".
  2. In the terminal, go to the folder where you have the swak4Foam source code and run the following command:
    patch -p1 < ~/Downloads/writeFieldsGeneralFunctionObject.C.patch
    Where I'm assuming you downloaded the file into the folder "~/Downloads/", so change it to your need
  3. Now you can run "Allwmake" once again, as you did before.
Best regards,
Bruno
File Type: patch writeFieldsGeneralFunctionObject.C.patch (964 Bytes, 256 views)
rafa13, dkjiao and Aabadani like this.
Old   August 2, 2015, 18:04
Rafael Marques
Hi Bruno
I Just followed your advise in another thread,I now I have swak4foam 0.2.4 compiled but I will update it with your instructions, thanks again!
Greets an thanks a lot!!!
Rafa Marques
Old   August 3, 2015, 09:27
Rafael Marques
Hi Bruno,
thanks a lot I compiled Swak4Foam 0.3.2 on OpenFoam 2.2.2 with success! This patch is magical! ah and thanks for the detailed installation instruction! I get so stucked without cfd-online!
Kind regards
Rafa Marques
wyldckat likes this.
Old   October 13, 2015, 14:06
Default swak4foam compilation or compatibility error/bug?
ma-tri-x is on a distinguished road
Dear Bruno, Bernhard and Rafa,
I am stuck with a groovyBC problem, which I think is related to compilation issues, hope you can help me. I am using
ubuntu 14.04 LTS and
openfoam extend 3.1 from source (in $HOME),
tried also
extend 3.0 from source (in $HOME), as well as
extend 3.1 from binary (/opt/...),
as well as
recompiling groovyBC or swak4foam from the extend thirdparty dirs,
as well as from downloaded swak4foam sources. I tried
bison version 3.x and
bison version 2.7 from thirdparty packages dir and I tried
http://www.cfd-online.com/Forums/ope...end-3-0-a.html
with the extend 3.1 version from source in the home directory without sudo rights (it linked successfully, but swak4foam did not compile errorlessly) ...
but I have everywhere the same problem with groovyBC:
in file 0/p when using rhoSonicFoam
transducer
        type groovyBC;
        valueExpression "10001315."
does not work. The maximum value of p is the value in the internal field (101315 which is < 10001315) and the density field gets killed to 0 in the first "solve" routine and therefore I get a floating point exception in the next solve routine. But
transducer
         type     fixedValue;
         value uniform 10001315;
works well.
I attached a minimum example (with rhoSonicFoam containing a few more "Info <<" lines). I would like to also attach the output of
 ./AllMake.stage5 &>log.stage5.txt
which was executed using
$HOME/foam/foam-extend-3.1/ThirdParty/packages/bison-2.7/platforms/linux64GccDPOpt/bin/bison
in the respective ThirdParty dir, but it's too large. The first error in this file is:
Making dependency list for source file SubsetValueExpressionParser.yy
could not open file DataEntry.H for source file makeSwakDataEntry.C
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionParser.yy
could not open file mappedFvPatch.H for source file FieldValueExpressionParser.yy
could not open file mappedWallFvPatch.H for source file FieldValueExpressionParser.yy
There are a lot of "could not open" messages...
Another idea is that the line
p.boundaryField().types()
in the constructor of rho in createFields.H of rhoSonicFoam might cause the problem. Is "Type" of p there compatible with groovyBC ?
Does anyone have an idea? Am I doing something wrong?
Best regards,
Max
ma-tri-x is offline   Reply With Quote
Old   October 17, 2015, 16:06
Bruno Santos
Greetings Max,
You were really close to the solution and thanks to your deductions I managed to be a bit faster in finding the solution:
  1. You must modify in "createFields.H" how the "rho" field is started:
        volScalarField rho
            IOobject
                "rho",
                runTime.timeName(),
                mesh,
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE
            mesh
    Don't forget to run wmake.
  2. Then you must create the field file "0/rho" with the following content:
    FoamFile
        version     2.0;
        format      ascii;
        class       volScalarField;
        location    "0";
        object      rho;
    dimensions      [1 -3 0 0 0 0 0];
    internalField   uniform 1.2042092;
    boundaryField
        front
            type            wedge;
        back
            type            wedge;
        side
            type            zeroGradient;
        transducer
            type            groovyBC;
            value           uniform 1.2042092;
            valueExpression "1.2042092";
        bottom
            type            fixedValue;
        top
            type            zeroGradient;
        axis
            type            empty;
  3. The field file was originally generated because I ran a previous build with this:
        volScalarField rho
            IOobject
                "rho",
                runTime.timeName(),
                mesh
            psi*p,
    rho.write();
    Which created the file "0/rho.gz", which I uncompressed like this:
    gunzip 0/rho.gz
As for the messages you got while building swak4Foam, those in particular are normal, because swak4Foam is able to be built with various OpenFOAM versions, which depend on different files, which are only found when it's gathering the dependency lists, hence the warnings about not finding some files.
Best regards,
Bruno
Old   October 17, 2015, 17:11
Hi Bruno!
Thanks a lot!!!
While you wrote the answer I also found someone explaining the line
which I didn't know before. Found the answer here:
http://www.idurun.com/2008/05/21/son...dent-pressure/
So it is supposed to mean that the rho-Field which has the constructor with the above line uses the same boundary types that were set for the p-Field in the file 0/p, right?
So it all made sense.
But I didn't think of creating a 0/rho file, so thanks a lot for that suggestion! Actually it's quite good to know this about constructors!
Old   November 18, 2015, 18:12
Sandra
sabago is on a distinguished road
Anyone have any other ideas?
The only alias in my bashrc is
alias of230='source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=8 WM_MPLIB=SYSTEMOPENMPI'
I'm using OpenFOAM 2.3 and Ubuntu 14.04 and I've tried 5 different times, (including OP's outlined method above) to reinstall it to no avail (I had it before but had to reinstall my OF and lost it).
Any help for this stupid error will be greatly appreciated!
/home/sandra/OpenFOAM/sandra-2.3.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
abort: no repository found in '/home/sandra/OpenFOAM/sandra-2.3.0/swak4Foam' (.hg not found)!
./Allwmake: line 61: wmake: command not found
sandra@sandra-ThinkCentre-M91p:~/OpenFOAM/sandra-2.3.0/swak4Foam$ export PATH=$PWD/bison/bin:$PATH
Best,
Sandra
removing alias:
Date     : Jul 16 2014
Time     : 20:28:03
PID      : 29818
Case     : /home/a
nProcs   : 1
FOAM exiting
sabago is offline   Reply With Quote
Old   November 19, 2015, 19:38
Bruno Santos
Quick answer:
  1. Start a new terminal window.
  2. Run:
    of230
    which will use the alias command that you defined in your "~/.bashrc" file.
  3. Try checking if wmake is found, by running:
    which wmake
  4. If it tells you the path to where it is, then try building swak4Foam. For example, it should tell you something like this:
    /home/ofuser/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake
If it doesn't tell you the path to where wmake is located, then I need more details. In such a case, please run the following command:
cat ~/.bashrc
Old   November 20, 2015, 13:16
Sandra
Wow, that worked! Thanks a lot (I wonder what I would do without you).
So the issue was that I was trying to install swak4Foam in the folder advised in the instructions when my "wmake" was elsewhere
/home/sandra/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake
but I think that that instruction should be edited to the "folder where wmake is" as per Bruno's suggestion above.
Best,
Sandra
Old   November 21, 2015, 16:07
Bruno Santos
Hi Sandra,
Sorry, I should have been clearer, but the other day I was in a hurry.
The missing detail was that you needed to run the following command whenever you start a new terminal:
of230
This is an alias command that will executed the associated command, namely:
The instructions on the wiki, such as the ones here: http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu - instruct the person reading the instructions to use this alias because this makes it possible to easily have more than one OpenFOAM version installed.
If you prefer to only use a single version of OpenFOAM and don't want to worry about any other versions, then you can edit the file "~/.bashrc" and change this line:
To this:
Save and close the file. Now whenever you start a new terminal, OpenFOAM 2.3.0 will always be ready to be used.
Best regards,
Bruno
Old   July 3, 2017, 03:38
Default swak4foam patch problem
  #17
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Dear Rafael:-
I got the following error after running ( patch -p1 < ~/Downloads/writeFieldsGeneralFunctionObject.C.patch):
patching file Libraries/simpleFunctionObjects/writeFields/writeFieldsGeneral/writeFieldsGeneralFunctionObject.C
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] yes
Hunk #1 FAILED at 57.
Hunk #2 FAILED at 161.
2 out of 2 hunks FAILED -- saving rejects to file Libraries/simpleFunctionObjects/writeFields/writeFieldsGeneral/writeFieldsGeneralFunctionObject.C.rej
so what to do ?
Originally Posted by wyldckat View Post
Greetings Rafael,
Best regards,
Bruno
alinuman15 is offline   Reply With Quote
Old   July 3, 2017, 06:49
Assistant Moderator
Bernhard Gschaider
Originally Posted by alinuman15 View Post
Dear Rafael:-
so what to do ?
Are you sure that the patch is still necessary? As mentioned in the bug-tracker entry in the message you quoted it is incorporated into swak for almost 2 years. So it should be in the current release and in the relase before that (at least)
Old   July 3, 2017, 07:00
Ali Noaman Ibrahim
Thank you so much for replying!
I have installed swak4foam for OpenFoam 2.4 successfully. However, when checked it by typing funkySetFields in terminal, I got the following :-
| \\ / O peration | Version: 2.4.0 |
Build : 2.4.0-dcea1e13ff76
Date : Jul 02 2017
Time : 20:38:23
Host : "ali-HP-ENVY-TS-15-Notebook-PC"
PID : 21168
Case : /home/ali/OpenFOAM/ali-2.4.0
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
swakVersion: 0.4.1 (Release date: 2017-05-31)
in file funkySetFields.C at line 759.
FOAM exiting
I struggled for long time to get it work but it still showing FOAM exiting. So, do you ( or any other foamer) have any suggestions ?
Thanks
Old   July 3, 2017, 08:31
Assistant Moderator
Bernhard Gschaider
<snip>
FOAM exiting
Thanks
That is not an installation/compilation problem but a problem with how you're using it. funkySetFields refuses to guess which time you want to use it on. So it asks you to specify it. Either with something like "-time 0" if you want to set initial conditions or with "-latestTime" if you want the latest time (these are the regular OpenFOAM-options so things like time-ranges will work too)
The reason why funkySetFields refuses to guess which time you want to use is that it is possibly destructive (it may overwrite your old data) and I don't want people running around crying "I didn't know it writes to the last time. Now my results are gone"
[OpenFOAM.org] Problem in installation of OpenFOAM-2.3.x Parisa_Khiabani OpenFOAM Installation 5 December 4, 2014 10:04
[Other] Problem in Open foam installation in ubuntu 14.04 zannatul OpenFOAM Installation 2 November 3, 2014 21:56
RHEL 6.3 Installation problem Turbulent STAR-CCM+ 0 September 3, 2014 08:01
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 14:00
[swak4Foam] installation problem: "./Allwmake: ... [[: not found" Rajarshi OpenFOAM Community Contributions 8 May 13, 2013 09:05
