Errors while installing openfoam on ubuntu 12.04 AND 11.10 |
August 7, 2012, 08:06 |
#21 |
John Eckart
Rep Power: 14 |
Actually the command to set the variable VERS worked as it was supposed to. The first thing I checked was to make sure that the variable was assigned correctly. It seemed to work for all but about 4 parts of the download when "update" was run.
August 7, 2012, 08:15 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Mmm... I understood from your description that the problem was that the words "lsb_release" appeared instead of "precise" during the update...
August 7, 2012, 08:48 |
#23 |
John Eckart
Rep Power: 14 |
yes, but not in every case. It seemed that most of the fetch commands worked properly. Only a few had the problem.
August 25, 2012, 12:02 |
#24 |
Chris Pellegrino
Rep Power: 14 |
I too am having similar issues. I have Ubuntu 10.04 LTS running on a 64bit machine (dual boot alongside Windows.) Following the instructions in http://www.openfoam.org/download/ubuntu.php ends up having issues with the GET UPDATE command. All the lines referring to openfoam begin with Ign (Ignore I presume?) At the end it's trying to get "main Packages" and "-cs Packages" from www.openfoam.org lsb_release/ with Ign at the beginning of each line and finally says Err instead of Ign then "W: Failed to fetch" from the same locations when it tries to get the Packages.gz file (it tried to get it from /-cs/binary-amd64 and also from /main/binary-amd64/.)
Is this something going on at OpenFOAM's end and I should just try again later? I don't know how to copy/paste from the terminal window, so please excuse the lack of detailed information. |
August 25, 2012, 14:41 |
#25 |
Bruno Santos
Rep Power: 128 |
Greetings Chris and welcome to the forum!
You can copy from the from the terminal by pressing the key combination Ctrl+Shift+C For pasting on the terminal you can use Ctrl+Shift+V Selection is with the mouse. As for the commands for installing, try these instead: Code:
VERS=$(lsb_release -cs) sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list" Best regards, Bruno
September 5, 2012, 01:18 |
#26 |
Chris Pellegrino
Rep Power: 14 |
Dang - you guys are awesome. Thanks - worked.
November 19, 2013, 10:52 |
#27 | |
For my problem with ATI radeon X1400 the following magic worked:
Now it uses standard Radeon driver with GLX support. Cheers, Alex
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
May 1, 2021, 13:10 |
#28 |
I just installed a brand new driver from NVIDIA.
I am using a NVIDIA Quadro 600 My OS is SUSE SLES 15 not Ubuntu! Code:
( 4.058s) [paraview ]vtkXOpenGLRenderWindow.:637 ERR| vtkXOpenGLRenderWindow (0x559c0d04a560): Cannot create GLX context. Aborting. Code:
VERS=$(lsb_release -cs) |
Trouble installing OpenFoam 2.10 on Ubuntu 11.10 | LucasCG | OpenFOAM Installation | 17 | January 27, 2013 15:58 |
OpenFOAM 2.1 on Ubuntu SERVER 11.10 | samiam1000 | OpenFOAM Installation | 2 | March 7, 2012 03:40 |
openFOAM installation in ubuntu 11.10 | kirubhakaran | OpenFOAM Installation | 5 | February 17, 2012 03:16 |
.deb installation of OpenFOAM 2.1.0 on Ubuntu 11.10 (Oneiric Ocelot). | kxk7607 | OpenFOAM Installation | 7 | January 21, 2012 12:57 |
[SOLVED] Intel Compiler 12.1 + Ubuntu 11.10 (gcc 4.6) + OpenFOAM 2.0.x | wyldckat | OpenFOAM Installation | 0 | November 4, 2011 15:52 |
