[foam-extend.org] OpenFOAM-1.6-ext on Ubuntu 12.04 install errors |
September 1, 2012, 03:42 |
#21 | |
Rep Power: 15 |
when I execute sudo chmod -R 751 /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/bin and then execute . ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc the following comment is shown but when I want to Compile the ThirdParty packages and execute the ./AllMake.stage1 >& log.AllMake.stage1 the linux did not ant thing please help me to install OF-1.6ext I have downloaded the Linux 12.04 at the Ubuntu site and boot it on flash memory and then install on my PC can you tell me why I encounter some errors which others person did not occur to them ? aminiyasser@aminiyasser-pc:~$ . ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh Environment variables defined for OpenMPI: OPENMPI_BIN_DIR : /usr/bin OPENMPI_LIB_DIR : /usr/lib/openmpi/lib OPENMPI_INCLUDE_DIR : /usr/lib/openmpi/include /usr/lib/openmpi/include/openmpi OPENMPI_COMPILE_FLAGS : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread OPENMPI_LINK_FLAGS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl MPI_HOME : /usr MPI_ARCH_PATH : /usr OPAL_PREFIX : /usr PINC : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread PLIBS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl MESQUITE_DIR is initialized to: METIS_DIR is initialized to: PARMETIS_DIR is initialized to: PARMGRIDGEN_DIR is initialized to: LIBCCMIO_DIR is initialized to: SCOTCH_DIR is initialized to: CMAKE_DIR is initialized to: M4_DIR is initialized to: BISON_DIR is initialized to: FLEX_DIR is initialized to: ZOLTAN_DIR is initialized to: PYTHON_DIR is initialized to: QT_DIR is initialized to: PARAVIEW_DIR is initialized to: Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh aminiyasser@aminiyasser-pc:~$ foam aminiyasser@aminiyasser-pc:~/OpenFOAM/OpenFOAM-1.6-ext$ ./AllMake.stage1 >& log.AllMake.stage1 aminiyasser@aminiyasser-pc:~/OpenFOAM/OpenFOAM-1.6-ext$ |
September 15, 2012, 23:47 |
errors in state4
#22 |
jack
Rep Power: 15 |
Hello everyone
I am trying to install openfoam-1.6-ext to ubuntu 12.04 32 bit. I am following the procedure given at http://openfoam-extend.git.sourcefor...02de56;hb=HEAD But I have problem at state4.The error is: Code:
error: open /home/lg88/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/i386/ParaView-3.12.0-linuxGcc46DPOpt.i386.rpm fail:No such file or directory Can you tell me what should I do? Thank you very much! regards! lg88 |
September 16, 2012, 07:39 |
#23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi lg88,
I tested the instructions myself on a VM with Ubuntu 12.04 i686, fully up-to-date and I was unable to trigger the same error. Therefore, please do the following steps:
Bruno
September 16, 2012, 12:09 |
#24 |
jack
Rep Power: 15 |
Hi Bruno
I have installed Ubuntu 12.04 (64bit).But I have met the same problem.I have attached the "log.AllMake.stage4" here.But it contains some chinese.And the main error I think is Code:
error: open /home/lg88/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.12.0-linuxGcc46DPOpt.i386.rpm fail:No such file or directory I have deleted something,because it is too large. regards! lg88 |
September 16, 2012, 17:02 |
#25 |
Bruno Santos
Rep Power: 128 |
Hi lg88,
Looks like this is the reason: Code:
Could NOT find OpenGL (missing: OPENGL_gl_LIBRARY) Code:
sudo apt-get install git flex bison rpm g++ zlib1g-dev binutils-dev \ openmpi-bin libopenmpi-dev libxext-dev libxt-dev libxrender-dev \ libstdc++5 libgl1-mesa-dev libglu1-mesa-dev Code:
sudo apt-get install git flex bison rpm g++ zlib1g-dev binutils-dev openmpi-bin libopenmpi-dev libxext-dev libxt-dev libxrender-dev libstdc++5 libgl1-mesa-dev libglu1-mesa-dev Bruno
September 17, 2012, 01:45 |
#26 |
jack
Rep Power: 15 |
Hi Bruno
I have done what you tell me.Now the problem of state4 have been solved.But a new problem came up which atg have mentioned here before: Code:
the final ./Allwmake script hangs up reliably on the incompressible yPlusRAS: regards! lg88 |
September 17, 2012, 04:48 |
#27 |
Bruno Santos
Rep Power: 128 |
Hi lg88,
Try this: Code:
unset WM_NCOMPPROCS ./Allwmake > make.log 2>&1 Best regards, Bruno
September 17, 2012, 22:11 |
#28 |
jack
Rep Power: 15 |
Hi Bruno
With your command: Code:
unset WM_NCOMPPROCS ./Allwmake > make.log 2>&1 Thank you very much! lg88 |
November 5, 2012, 13:43 |
#29 | |
Atheendra
Rep Power: 14 |
I am also installing OF 1.6-ext on ubuntu 12.04(32 bit) and have the same problem as you- the ./Allwmake script stops running after compiling yPlusRas. the zlib1g-dev library seems to be installed fine. Do you know what could be the problem? Thanks! |
November 5, 2012, 14:07 |
#30 |
Atheendra
Rep Power: 14 |
Sorry for the spam guys,I am new to the forum and didn't check this page of the thread before posting, and I tried Bruno's method of compilation and it seems to have worked, even though the log file doesn't show "Done" or any such similar message at the end.
Thanks! |
November 5, 2012, 16:00 |
#31 | |
Bruno Santos
Rep Power: 128 |
Greetings Atheendra and welcome to the forum!
And indeed, the script doesn't indicate any pretty messages. Once we get use to it, it becomes second nature to simply run Allwmake it a second time to confirm if it's all done or not Best regards, Bruno
November 30, 2012, 12:23 |
#32 |
Rep Power: 15 |
Hi, I am trying to install OpenFoam-1.6-ext on Ubuntu-12.10-32bits, and I am having the same problem while running Allmake.stage4:
error: open /home/lasim/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/i386/ParaView-3.12.0-linuxGcc46DPOpt.i386.rpm fail:No such file or directory All the necessary package mentioned in the build instructions for Ubuntu 12.04-32bits was installed. I don't know if it is necessary to install some other stuff for Ubuntu 12.10, have anyone tried? |
February 18, 2013, 18:13 |
#33 |
Jack
Rep Power: 14 |
Hi atg,
I know you posted me this a while ago; but I have only just got round to downloading the link. Is there anyway to install OF not on a Virtual Machine (that may sound like a stupid question - I am still downloading it (have realllll slow internet).. can I just mount it and run?) |
September 11, 2013, 09:19 |
#34 |
behzad Ghasemi
Rep Power: 13 |
hi guys
im new here.im trying to instal openFOAM 1.6 on ubuntu 12.04 i did according the user guide and extract the .gtgz files but when i check the installation { Code:
$HOME/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest i got some errors Code:
Executing /home/behzad/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: behzad-Dell-System-XPS-L502X OS: Linux version 3.2.0-23-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/behzad/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/behzad/OpenFOAM/behzad-1.6 yes no $WM_THIRD_PARTY_DIR /home/behzad/OpenFOAM/ThirdParty-1.6 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/behzad/OpenFOAM/OpenFOAM-1.6 yes yes yes $FOAM_APPBIN ...1.6/applications/bin/linux64GccDPOpt no yes $FOAM_SITE_APPBIN ...penFOAM/site/1.6/bin/linux64GccDPOpt no no $FOAM_USER_APPBIN ...1.6/applications/bin/linux64GccDPOpt no no $WM_DIR /home/behzad/OpenFOAM/OpenFOAM-1.6/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.6/lib/linux64GccDPOpt no yes $FOAM_SITE_LIBBIN ...penFOAM/site/1.6/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN ...nFOAM/behzad-1.6/lib/linux64GccDPOpt no no $MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.6.3 Minimum required: 4.3.1 gcc 4.6.3 WARNING: Conflicting installations: OpenFOAM settings : /home/behzad/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.4 /bin/gzip tar 1.26 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/behzad/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. Code:
behzad@behzad-Dell-System-XPS-L502X:~$ cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity behzad@behzad-Dell-System-XPS-L502X:~/OpenFOAM/behzad-1.6/run/tutorials/incompressible/icoFoam/cavity$ blockMesh blockMesh: command not found behzad@behzad-Dell-System-XPS-L502X:~/OpenFOAM/behzad-1.6/run/tutorials/incompressible/icoFoam/cavity$ icoFoam icoFoam: command not found behzad@behzad-Dell-System-XPS-L502X:~/OpenFOAM/behzad-1.6/run/tutorials/incompressible/icoFoam/cavity$ paraFoam created temporary 'cavity.OpenFOAM' /home/behzad/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: 129: /home/behzad/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: paraview: not found please help me |
September 11, 2013, 17:35 |
#35 |
Bruno Santos
Rep Power: 128 |
Greetings Behzad and welcome to the forum!
I think you're confusing these two:
Best regards, Bruno
July 27, 2016, 16:06 |
OpenFoam 1.6-ext installation error on Ubuntu 16.04
#36 |
Manm
Rep Power: 11 |
I am installing OpenFoam 1.6-ext on my laptop working on Ubuntu 16.04 LTS. I followed the procedure as outlined in: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04 However, though it runs until step 15 of the above document, when I test it to run 'icoFoam -help' as per step 16, it gives 'icoFoam: command not found. I have attached the compressed file her. I don't think this is because of the Ubuntu versions being different. Kindly advise how do I address this issue. Thanks. Man |
August 7, 2016, 18:57 |
#37 |
Bruno Santos
Rep Power: 128 |
Quick answer: Use the same hack that is given for 16.04 here: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 - namely this command:
find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1=' |
August 8, 2016, 12:48 |
#38 |
Manm
Rep Power: 11 |
Thank you.
I had reinstalled Ubuntu 14.04 and then Openfoam 1.6 extend and it had started working. |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
Environment errors with .deb install and ubuntu 13.04 64 bit | jonathanbyrn | OpenFOAM Installation | 14 | September 26, 2013 06:22 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
