gcc (OpenFOAM 2.1.0 on CentOS 5)
Old   April 30, 2012, 17:13
Default gcc (OpenFOAM 2.1.0 on CentOS 5)
sukye is on a distinguished road
Question:
Where to find rpm file of gcc4.3 or 4.4?
I am installing 2.1.0 on CentOS 5 with yum-updated gcc 4.1.2.
The error messages include
mpi.h: No such file or directory
It's mentioned in
http://www.openfoam.org/download/git.php
that gcc-4.4.? is recommended but gcc-4.3.? is sufficient.
sukye is offline   Reply With Quote
Old   April 30, 2012, 17:55
and how to set the environment?
export WM_COMPILER=/usr/bin/gcc44
is it all?
Old   April 30, 2012, 18:39
Retired Super Moderator
Bruno Santos
Greetings sukye and welcome to the forum!
Since you have CentOS, then it's best/easier for you to use CentFOAM: http://sourceforge.net/apps/mediawik...itle=Main_Page
Best regards,
Bruno
Old   April 30, 2012, 19:20
Thank you Bruno. You are always so helpful.
When I run python centFOAM.py --netgen, here is the error
adding netgen-4.9.14-svn to .bashrc file for user running the script
Traceback (most recent call last):
  File "centFOAM.py", line 338, in ?
    main()
  File "centFOAM.py", line 312, in main
    installNetgen(options.path, "4.9.14-svn",rel)
  File "centFOAM.py", line 135, in installNetgen
    writeStartNetgen(path, package, "netgen")
  File "centFOAM.py", line 39, in writeStartNetgen
    fileHandle = open ( fileName , 'w' )
IOError: [Errno 2] No such file or directory: '/home/sukye/centFOAM//netgen-4.9.14-svn/bin/start_netgen'
Should I run --yum first, then --paraview etc. one by one?
Best regards,
Bruno
Old   May 1, 2012, 06:56
Bruno Santos
Hi sukye,
Unfortunately I don't know the answer, but Linnemann should know the answer, since he's the one who has developed CentFOAM. In the mean time, you can read the following threads and perhaps ask again in the second one:
Best regards,
Bruno
Old   May 1, 2012, 17:17
Thank you Bruno,
Here are steps I have made:
1. sudo python centFOAM.py --yum
(yum only install 4.1.2 instead of 4.3 required by OF)
2. python centFOAM.py --nonOF
3. python centFOAM.py --OF21
(double slashes (incorrectly?):
installing OpenFOAM-2.1.0 to /home/sujian/centFOAM//OpenFOAM/OpenFOAM-2.1.0
Folder does not exist, now creating if possible)
Any further steps to complete the compilation?
When
~/centFOAM/OpenFOAM/OpenFOAM-2.1.0>./Allwmake
It says:
./Allwmake: line 4: wmakeCheckPwd: command not found
Error: Current directory is not $WM_PROJECT_DIR
but actually:
>echo $WM_PROJECT_DIR ~/centFOAM/OpenFOAM/OpenFOAM-2.1.0
Thanks.
Old   May 1, 2012, 21:27
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
No need to compile when using CentFOAM it is already compiled for you.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 2, 2012, 01:37
Thank you Linnemann.
But blockMesh and other functions do not work.
Old   May 2, 2012, 01:47
linnemann's Avatar
Niels Nielsen
you have to source the OF environment.
So open a new terminal as the user who installed OF and type OF21
that will source the OF environment using an alias to the OpenFOAM bashrc file.
you can see the alias in your $HOME/.bashrc file of the user who installed using the centFOAM script.
Linnemann
Old   May 2, 2012, 02:06
I followed your instruction and it works! Thank you Linnemann!
Old   May 5, 2012, 11:35
Bruno Santos
Greetings to all!
@Linnemann: sukye had problems using paraFoam - which you do indeed describe about on the wiki:
Originally Posted by sourceforge.net/apps/mediawiki/centfoam/index.php?title=Main_Page
To use Paraview with the new reader just create an empty file in your case folder "touch casename.foam" and open this file using Paraview.
Anyway, here is another hack for using paraFoam: http://www.cfd-online.com/Forums/ope...tml#post359479 post #21
Best regards,
Bruno
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Installation problem: openfoam 2.1.0 on opensuse 11.4 raphael7 OpenFOAM Installation 4 April 12, 2012 08:10
[SOLVED] Intel Compiler 12.1 + Ubuntu 11.10 (gcc 4.6) + OpenFOAM 2.0.x wyldckat OpenFOAM Installation 0 November 4, 2011 15:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 13:46
