[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch |
#81 |
Juimo Pierre
Rep Power: 14 ![]() |
it is the same solution
1- in fact it's just addition of a line "-lincompressibleTransportModels \" and " -linterfaceProperties" in Make/option 2- wmake source alexeym |
#82 | |
J.-H. Wang
Rep Power: 16 ![]() |
For the complete record, I changed the options file in the following folders manually, $FOAM_APP/solvers/multiphase/driftFluxFoam/Make $FOAM_APP/solvers/multiphase/interFoam/Make $FOAM_APP/solvers/multiphase/interDyMFoam/Make $FOAM_APP/solvers/multiphase/porousInterFoam/Make $FOAM_APP/solvers/multiphase/LTSInterFoam/Make For each of the options file, I added Code:
-lincompressibleTransportModels \ -linterfaceProperties \ Thanks for the help. JHW |
#83 |
Francisco T
Rep Power: 15 ![]() |
Hello
I have successfully installed OF 2.3 in MacOS, cases are running ![]() when I write in terminal: paraFoam, this is what I got: >> paraFoam created temporary 'OpenFOAM-2.3.0.foam' /Users/frantov/OpenFOAM/OpenFOAM-2.3.0/bin/paraFoam: line 265: paraview: command not found |
#84 |
#85 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 ![]() ![]() |
paraFoam won't work though as the filter distributed with OpenFOAM needs a source-installation of paraview. But paraview has a fine built-in OpenFOAM-filter. That's why I currently don't bother to install it from source
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
#86 |
Dear Bernhard,
I'm not quite sure that the problem is in desire to build Paraview from sources. To illustrate the problem, I've created test.sh and test1.sh files (it's more or less vanilla OS X 10.9, maybe Macports installs its own version of bash). test.sh is: Code:
#!/bin/sh alias lha='ls -lha' Code:
#!/bin/sh lha Code:
$ . test.sh $ ./test1.sh ./test1.sh: line 3: lha: command not found If I change test.sh to: Code:
#!/bin/sh lha() { ls -lha } export -f lha Maybe it's worth changing alias to function in future patches? Also there was an issue with driftFluxFoam. Last edited by alexeym; May 24, 2014 at 05:32. |
#87 | |
Assistant Moderator
Bernhard Gschaider
About driftFluxFoam. There is a problem with it not linking, right? Adding -ltwoPhaseMixture to Make/options fixes that. It's not in the patch because the solver has been added only recently and I don't rush out a new version of the patch every time something changes (especially in cases like this where nothing else depends on the compilation failure).
#88 | ||
#90 | |
Assistant Moderator
Bernhard Gschaider
#91 |
Pierluigi Morra
Rep Power: 13 ![]() |
Has anyone tried parallel running on a single machine?
I've started to use the program for a few weeks on Mavericks (10.9.1). Today, I wanted to see how to perform a parallel run on a i7 quad core. I know it is possible, but I get some errors. I would like to get some feedback on that; has anyone tried and succeeded? |
#92 | |
Reamonn Mac Reamoinn
Rep Power: 12 ![]() |
#93 |
Pierluigi Morra
#94 |
If I remember correctly it was the wingMotion tutorial in the incompressible/pimpleDyMFoam/ directory.
#95 |
Can you post error message(s)? I've run it in parallel on a single machine and it was OK. |
#96 |
Pierluigi Morra
Well, I'm sorry that I didn't reply sooner, but the problem was not in the program itself but in some cell distortion I got after scaling the mesh with different ratios in different directions.
I took the engineFoam tutorial, scaled its mesh to (0.7 0.7 0.5) to make it closer to my cylinder, split the domain in 4 parts and it diverged. Using 2 subdomains solved the problem. I know I should have made a new mesh, but I did't know a fast way for it. As far as the tutorials I made a stupid mistake. Bye. |
#97 |
Davide D.
I am encountering some problems in compiling.
Every time it attempts to compile something, it writes: Code:
ld: library not found for -lPstream collect2: ld returned 1 exit status |
#98 |
Assistant Moderator
Bernhard Gschaider
The problem must have happened before (during compilation of Pstream). A LITTLE bit of context would be helpful
#99 |
Juimo Pierre
Pre-compiled disk images of version 2.3.x for Mac 10.9?
#100 |
Assistant Moderator
Bernhard Gschaider
None that I know of (but I haven't looked very much for precompiled versions to be honest). Closest thing I know of is found at https://sourceforge.net/projects/ope...am-extend-3.1/ (but of course that is the other fork).
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 03:01 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
