[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X
Like Tree20Likes
Old   March 9, 2014, 21:49
Brian Weeks
bweeks is on a distinguished road
I'm doing an installation of OF2.2.2 using the Source Pack, downloaded from here.
bweeks is offline   Reply With Quote
Old   March 10, 2014, 15:25
Assistant Moderator
Bernhard Gschaider
Then you can ignore these messages (if they are the only ones). Patch is usually developed/maintained against the git-version (which is usually more advanced than the latest release)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 17, 2014, 07:31
Default Problems with 2.2.x latest built
  #123
Michael
lithos is on a distinguished road
Dear all,
now it hit me trying to get a running copy of the last OpenFOAM 2.2.x built from
mpmp:OpenFOAM-2.2.x mplagge$ git show
commit 61b850bc107bdd60bbf1bf9a6417b9faf701d128
Merge: 3743359 68ae524
Author: andy <andy>
Date:   Wed Feb 26 16:43:52 2014 +0000
with the patches provided by Bernhard. I put a new sparseimage, fresh git clone from the repository, checked the installation of boost, cgal, flex, bison, ccache, gcc46, openmpi-1.7.2-gcc46 etc., put a fresh copy of ThirdParty tools. Then I applied the two patches below, followed also http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2 and started compiling.
I noticed quickly that openmpicc was not used by allwmake for building Scotch. So I had a look at the patches and not being an expert I applied also the newMacPortsMPIThirdParty.patch. The second run openmpicc was used. However, as soon as finishing ThirdParty tools there is a strange gcc error occuring that I never had before:
/opt/local/include/gcc46/c++/cwchar:66:11: error: '::mbstate_t' has not been declared
/opt/local/include/gcc46/c++/cwchar:141:11: error: '::wint_t' has not been declared
/opt/local/include/gcc46/c++/cwchar:143:11: error: '::btowc' has not been declared
/opt/local/include/gcc46/c++/cwchar:144:11: error: '::fgetwc' has not been declared
I put only four of dozens of these messages. Compilation fails completely, not even the 'platforms' folder is generated. Does anybody know this error by chance? I checked already printenv a dozen times, everything seems fine. Also GCC 4.8 I tried with the same result. The full allwmake log file can be downloaded here:
https://box.cern.ch/public.php?servi...a28f082c2c0148
I would really appreciate any help. Thanks in advance.
Cheers,
Michael
Originally Posted by gschaider View Post
OK. Attachments seem to broken. Here are the two full patch:
Attachment 28765
Attachment 28766
SOLVED: Bloody damn stupid beginner mistake: disk image was not case sensitive. Layer 8, right in front of the machine. -.-
lithos is offline   Reply With Quote
Old   March 19, 2014, 19:03
Assistant Moderator
Bernhard Gschaider
It's a good thing that I'm two days behind with answering the message board stuff. It's much more satisfying to find the mistake yourself, right? (and my first impression was "looks familiar, but I can't remember what the cause is")
Old   March 20, 2014, 06:21
Michael
Dear Bernhard,
one day I'll show you our archive of keyboards and desk tops, the ones with the bite marks...
However, could you please let me know what should be the setting for WM_MPLIB with your patches? I added the full patch and newMacPortsMPIThirdParty with 2.2.x and I get:
mpmp:motorBike mplagge$ openmpirun -np 6 snappyHexMesh -parallel -overwrite
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
openmpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[46715,1],5]
  Exit code:    1
Not exactly the same procedure as very year, rather something new. At least for me Available are right now GCC 4.6 with OpenMPI 1.7.2 and GCC 4.8 with OpenMPI 1.7.2
Cheers,
Michael
Old   March 20, 2014, 15:11
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
This one?
http://fatpenguinblog.com/wp-content...tyKeyboard.jpg
(No. The patch does not hack your webcam. I was only guessing )
That's the point with the latest version of the patches: it looks at /opt/local/bin/mpicc and determines from that which MPI-version to use (and sets WM_MPLIB)
  Exit code:    1
Cheers,
Michael
That confuses me a bit: with the new MacPorts there is no (open)mpirun anymore. A mpiexec that points to the default MPI and a number of executables of the form mpiexec-openmpi-gcc46.
Are you using an outdated MacPorts (do a "port selfupdate; port upgrade outdated") or a self-compiled OpenMPI (honorable but I can't help you there. I avoid compiling stuff)?
Old   March 24, 2014, 11:51
Michael
Dear Bernhard,
thanks for your comments. I did a complete selfupdate and upgrade of the outdated stuff, a lot of things have been relinked. The following run of Allwmake was successful. However, I dont see any mpicc use anymore in the log file as before.
And I agree with you on the compilation stuff. That is why I avoid regularly to get the newest port and git version: it creates more trouble than it helps usually.
In the end I did a
ln -s /opt/local/bin/mpiexec-openmpi-gcc46 $WM_PROJECT_DIR/bin/mpirun
and now everything works. For the keyboard, famous and known for years. But we don't smoke in our offices anymore...
Cheers,
Michael
Old   March 25, 2014, 11:01
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
In the end I did a
Cheers,
Michael
Have you set the default MPI with "port select"? Of course then it is still called "mpiexec"
Old   March 30, 2014, 16:56
Michael
Yes, of course. Both, MPI and GCC:
Available versions for gcc:
    llvm-gcc42
    mp-gcc46 (active)
    mp-gcc47
    mp-gcc48
    none
Available versions for mpi:
    mpich-mp-fortran
    none
    openmpi-gcc46-fortran (active)
    openmpi-mp-fortran
As long as it works now I don't care for the name of the (data) manager :-)
Old   April 12, 2014, 08:30
Default makefile for scotch
  #130
malu
malfrienz is on a distinguished road
Hi all,
I'm trying to install open foam on my macbook. I followed all the appropriate instructions in wiki page. once i did the './Allwmake 2>&1 | tee logName.log', I found some errors and the first error says 'Error: Scotch needs an appropriate makeFile.inc'. I don't understand whats wrongs and what i have to do next.
Any help is much appreciated.
Thanks
malfrienz is offline   Reply With Quote
Old   April 14, 2014, 20:32
Assistant Moderator
Bernhard Gschaider
Originally Posted by malfrienz View Post
Hi all,
Thanks
Did you apply the ThirdParty-patch? That should add that make-file. And that line is not very much maybe it is said before that WHICH file is expected
Old   April 14, 2014, 21:22
malu
I applied the third part patch. these are the exact lines from the log file.
Build Scotch decomposition library scotch_6.0.0
/Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ cd scotch_6.0.0/src
+ prefixDIR=/Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ libDIR=/Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib
+ mkdir -p /Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ mkdir -p /Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib
+ configOpt='prefix=/Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0 libdir=/Users/mharibabu/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib'
+ '[' -f ../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM ']'
+ '[' -f Makefile.inc ']'
+ echo ' Error: scotch needs an appropriate Makefile.inc'
+ exit 1
WARNING: required include file 'scotch.h' not found!
What do you think is the problem here?
Thanks
Malu
Old   April 24, 2014, 19:37
Assistant Moderator
Bernhard Gschaider
+ exit 1
Thanks
Malu
No idea. Makefile.inc should be a symbolic link to ../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM but that test seems to fail ("scotch need an appropriate ...")
Old   December 29, 2014, 02:40
Default scotch compilation issues after using the latest full patch (2014-02-17 version)
  #134
Vishal Achasrya
vishalsacharya is on a distinguished road
I am having the same problem with scotch.
The scotch Makefile is present and accounted for and I also checked its contents in the appropriate linked location, but despite that, scotch is not being compiled. It still creates a dummy scotch and ptscotch library. I have applied all patches, and made all the softlinks and all serial runs work.
I am using the latest MacPorts in 10.10 Yosemite. There are no more openmpi files.... everything is mpirun-openmpi-mp and mpicc-openmpi-mp etc. Im wondering if this is the issue?
Below is a snippet showing just the scotch and ptscotch compilation part and its errors:
    /Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ prefixDIR=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ mkdir -p /Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ configOpt='prefix=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0 libdir=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib'
+ ln -s ../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM Makefile.inc
+ make -j 1 CC=gcc-mp-4.6 CCS=gcc-mp-4.6 scotch
Build PTScotch decomposition library scotch_6.0.0 (uses MPI)
+ incDIR=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-system
+ configOpt='prefix=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0 libdir=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-system includedir=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-system'
+ make -j 1 CC=gcc-mp-4.6 CCS=gcc-mp-4.6 ptscotch
    WARNING: required include file 'ptscotch.h' not found!
+ wmakeLnInclude scotchDecomp
wmakeLnInclude: linking include files to scotchDecomp/lnInclude
+ wmakeLnInclude ptscotchDecomp
wmakeLnInclude: linking include files to ptscotchDecomp/lnInclude
+ wmake libso scotchDecomp
SOURCE=dummyScotchDecomp.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/parallel/decompose/decompositionMethods/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/parallel/decompose/scotchDecomp/lnInclude -IlnInclude -I. -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/dummyScotchDecomp.o
'/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/dummy/libscotchDecomp.dylib' is up to date.
+ wmake libso ptscotchDecomp
Making dependency list for source file dummyPtscotchDecomp.C
SOURCE=dummyPtscotchDecomp.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/parallel/decompose/decompositionMethods/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/parallel/decompose/ptscotchDecomp/lnInclude -IlnInclude -I. -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/dummyPtscotchDecomp.o
'/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/dummy/libptscotchDecomp.dylib' is up to date.
using SCOTCH_ARCH_PATH=/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0
+ '[' -n /Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0 ']'
Making dependency list for source file scotchDecomp.C
could not open file scotch.h for source file scotchDecomp.C
SOURCE=scotchDecomp.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/local/include -I/include -I/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/scotchDecomp.o
ld: library not found for -lscotch
make: *** [/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/libscotchDecomp.dylib] Error 1
+ '[' scotch_6.0.0 = scotch_6.0.0 ']'
+ export LINK_FLAGS=-lscotch
+ LINK_FLAGS=-lscotch
+ wmakeMpiLib ptscotchDecomp
wclean ptscotchDecomp
Making dependency list for source file ptscotchDecomp.C
could not open file omp.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/constants.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/functions.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/datatype.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/exception.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/op.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/status.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/request.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/group.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/comm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/win.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/file.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/errhandler.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intracomm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/topology.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intercomm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/info.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pop_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/functions_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/request_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/comm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/topology_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/group_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/op_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/status_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/info_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/win_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/file_inln.h for source file ptscotchDecomp.C
could not open file ptscotch.h for source file ptscotchDecomp.C
SOURCE=ptscotchDecomp.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/local/include -I/include -I/Users/vishalacharya/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-system -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOptSYSTEMOPENMPI/ptscotchDecomp.o
ptscotchDecomp.C: In member function 'Foam::label Foam::ptscotchDecomp::decompose(const Foam::fileName&, int, const int*, int, const int*, const scalarField&, Foam::List<int>&) const':
ptscotchDecomp.C:551:39: warning: use of old-style cast [-Wold-style-cast]
ld: library not found for -lptscotch
make: *** [/Users/vishalacharya/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-system/libptscotchDecomp.dylib] Error 1
vishalsacharya is offline   Reply With Quote
Old   December 5, 2015, 04:30
Default Installation on Mac El Capitain
  #135
ferra89 is on a distinguished road
Hello everyone
I'm experiencing some problems trying to install OpenFOAM 2.2.2 on MAC OS El Capitain. I followed the tutorial http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2.
I used the patch OpenFOAM-2.2.x-Mac_2014-02-17.patch but it says:
Marcos-MacBook-Pro:OpenFOAM-2.2.2 ferra_marco$ patch -p1<OpenFOAM-2.2.x-Mac_2014-02-17.patch
patching file applications/solvers/combustion/fireFoam/Make/options
patching file applications/solvers/compressible/rhoSimpleFoam/rhoSimplecFoam/Make/options
patching file applications/solvers/incompressible/adjointShapeOptimizationFoam/Make/options
patching file applications/solvers/incompressible/simpleFoam/SRFSimpleFoam/Make/options
can't find file to patch at input line 57
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/applications/solvers/lagrangian/DPMFoam/Make/options b/applications/solvers/lagrangian/DPMFoam/Make/options
|--- a/applications/solvers/lagrangian/DPMFoam/Make/options
|+++ b/applications/solvers/lagrangian/DPMFoam/Make/options
File to patch:
Skip this patch? [y]
Skipping patch.
1 out of 1 hunk ignored
patching file applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/Make/options
patching file applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/icoUncoupledKinematicParcelDyMFoam/Make/options
Reversed (or previously applied) patch detected! Assume -R? [n]
and so on for other command line like that.
Instead ThirdPart patch runs without problem.
Then, if I go on the tutorial and I try to make ./Allwmake I have many errors. It seems I do not have a:
/Users/ferra_marco/OpenFOAM/OpenFOAM-2.2.2/wmake/rules/darwinIntel64Gcc46/general: No such file or directory
I enclose my log file.
I hope someone can help me.
Thanks
Marco
ferra89 is offline   Reply With Quote
Old   October 10, 2017, 18:18
Default Installing openfoam 2.0 in macbook showing error
  #136
Maheandar
Mahe512 is on a distinguished road
hai friends,
I would like to install openfoam 2.0 in mac.
While installing i got the error that i mentioned below.
Anyone can give the idea or link to solve the error is helpful for me.
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
Thanks in advance.
Mahe512 is offline   Reply With Quote
Old   October 10, 2017, 18:25
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Originally Posted by Mahe512 View Post
hai friends,
Thanks in advance.
The problem (and the solution) is self explaining. Your environment variables are not correctly configured. Did you correctly sourced the etc/bashrc file?
rdbisme is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
