[Other] Windows (x64) Binaries for OpenFOAM-2.1.x using OpenMPI
Like Tree9Likes
  • 1 Post By JLight
  • 4 Post By JLight
  • 1 Post By JLight
  • 1 Post By mathppp
  • 2 Post By GRAUPS
Old   November 9, 2012, 01:39
Default Windows (x64) Binaries for OpenFOAM-2.1.x using OpenMPI
Nishit Joseph
JLight is on a distinguished road
Hi
I have uploaded my binaries for OpenFOAM-2.1.x here.
This was compiled using the instructions outlined by Symscape and provided here.
The only difference between Symscape's is this is compiled against OpenMPI and does not use MSMPI.
I have not tested this extensively and hope to get some feedback on this.
Hope to document the process so enable recreating this with ease.
I will push the source soon (I have a crawling connection).
Cheers!
JLight
namsivag likes this.
JLight is offline   Reply With Quote
Old   November 9, 2012, 12:16
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Very cool! I am going to try your binary over the weekend. Also, I'm interested in this documentation. Was this compiled on linux with MinGW?
chegdan is offline   Reply With Quote
Old   November 9, 2012, 14:13
Nishit Joseph
Yes, it was compiled on linux with MinGW-w64.
Old   December 1, 2012, 19:14
Brock Lee
GRAUPS is on a distinguished road
Dude you are awesome, I was just going to try and tackle this binary build using the instructions from symscape... and then I found this... great work!
You said you were looking for some feedback. I have the first bit. It seems like the sourceforge binaries might not include everything needed to run. I receive this attached error when trying to run blockMesh...
I may have missed a step, I am most definitely not a linux expert, but it appears some of the MinGW-w64 libraries may not have been included (or couldn't be) as per symscape's instructions.
If you can't update the install on sourceforge, do you know where I can get the required dll files? Do I have to build MinGW myself? Thanks! And great work!
GRAUPS is offline   Reply With Quote
Old   December 2, 2012, 05:23
Nishit Joseph
Originally Posted by GRAUPS View Post
I may have missed a step, I am most definitely not a linux expert, but it appears some of the MinGW-w64 libraries may not have been included...
Hi thanks for this. I think I had zlib installed on my Windows from some previous work.
The easiest workaround is for me to upload the dll (Tha I had cross compiled) to sourceforge. I have updated the Readme. Please try it and tell me if it works.
Glad to know you like this.
Cheers!
NJ
Old   December 6, 2012, 03:00
Nishit Joseph
Hi All
Just a quick update.
I have pushed the source of OpenFOAM with the Symscape patch and brought it up to commit d957081e1400ad2fd88fefcf7db3599dd66b0ddf (2 Dec 2012).
The recompiled binaries is upload to SourceForge this very moment.
I am in the process of writing out the steps needed to do it yourselves and is located here.
Cheers!
NJ
Old   December 6, 2012, 09:48
Brock Lee
Awesome, thank you for taking the time to do this. I have tested blockMesh with the included zlib.dll file and it now runs without a hitch. I'll let you know when I have tested it more extensively or find anything amiss. Thanks again!
Old   December 13, 2012, 18:25
Daniel P. Combest
This is really nice. I just downloaded and tested the install...so far its working great. I'm interested in the notes on how to compile...since this is what I would like to do over the holiday with some custom solvers. Thanks again and excellent work.
Old   December 14, 2012, 21:11
Brock Lee
This is really nice. I'm interested in the notes on how to compile...since this is what I would like to do over the holiday with some custom solvers. Thanks again and excellent work.
I second Dan's motion, I have some custom solvers as well that would be nice to cross compile. If and when you have the time to finish the wiki page. I will gladly give it a run through to see if everything is clear and concise and to make sure I'm able to successfully compile. Thanks again!
Old   January 7, 2013, 15:46
Default Update
Nishit Joseph
Quick Update
I just updated and pushed the source that bring it up to commit c79762488bb97ec8cb786ecff81560e3409762f0 (02-Jan-2013).
The work on the wiki is going a bit slow, I have done about 30%. Hoping to complete it all by the end of the week.
Cheers!
NJ
GRAUPS likes this.
Old   January 9, 2013, 10:27
Brock Lee
The wiki is looking good, keep up the good work. Be sure to post back when you're finished, I'd be happy to take it for a test drive.
Old   November 15, 2013, 04:20
Default parallel problem
  #12
OH il seok
oilsok is on a distinguished road
I installed Openmpi and unarchive openfoam in c:\openfoam
I excuted dosmode.bat and try to run tutorial
so
blockmesh ==> work
icofoam ==> work
but when I try to calculate tutorial as parallel. this error is appeard.
C:\openfoam\OpenFOAM\OpenFOAM\OpenFOAM-2.1.x\tutorials\multiphase\interFoam\lami
nar\damBreak>mpirun -np 4 interFoam -parallel
mpirun was unable to launch the specified application as it could not find an ex
ecutable:
Executable: interFoam
Node: CS382
while attempting to start process rank 0.
4 total processes failed to start
can you help me this problem
oilsok is offline   Reply With Quote
Old   November 15, 2013, 08:23
W.T
dybuk is on a distinguished road
Try use application name wit extension :
 mpirun -np 4 interFoam.exe -parallel
dybuk is offline   Reply With Quote
Old   November 15, 2013, 08:57
OH il seok
I got It!
thank you!!!
Old   June 13, 2014, 03:35
Default Kuo
  #15
mathppp is on a distinguished road
Hi Everyone,
I used to use the windows version openfoam v2.1 on my desktop.
I have a problem about merge the mesh from a parallel job. I try to use the command "reconstructPar" to merge the results of those processors' data including the meshes. I think I should use "reconstructParMesh", but I can not find it in the bin folder.
could you do me a favor ? thinks.
dragazsolt likes this.
mathppp is offline   Reply With Quote
Old   June 16, 2014, 17:54
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Hi Joseph,
Great job done, its really working fine. Just a small query, once the calculation is finished.I used foamtoVTK utility in the dos prompt to get the data readable in Paraview. Because normally in linux one uses the internal utility paraFoam to open the calculated case in the current working case directory.
Is there alternative approach to directly post-process the calculation in Paraview.
Thanks.
taxalian is offline   Reply With Quote
Old   February 3, 2015, 23:26
Default incomplete set of binaries
  #17
Andrew
and44bor is on a distinguished road
Originally Posted by JLight View Post
Hi All
Cheers!
NJ
There is no "parafoam.exe" among your binaries.
Moreover, "ParaView" package directories do not exist at all.
Hence, all 3 corresponding environmental variables in setvar.bat to run DOS_MODE.bat remain undefined.
With your binaries a user can run CFD but for post-processing he needs other piece of software. Which is not the case of the Linux based distribution of OF-2.1.x or available Win64 binaries of OF-1.5.x and OF-1.6.x and OF-1.7.x -- all they are freeware.
So, my private opinion is that without "parafoam" any OF distribution does not look complete.
Cheers.
and44bor is offline   Reply With Quote
Old   February 4, 2015, 00:29
Brock Lee
Moreover, "ParaView" package directories are not exist at all.
Lucky for us, Paraview has a native Windows install available from their website which we can use to open OF jobs! This isn't the case with OpenFOAM, and is why people like JLight are awesome.
Cheers
chegdan and sharonyue like this.
Old   August 15, 2015, 16:49
Default reconstructParMesh
  #19
ZsoltDraga
dragazsolt is on a distinguished road
Hi Nishit,
I could not find a reconstructParMesh option in your Openfoam 2.1x Win 64 version.
Do you plan to update it with reconstructParMesh feature?
Basically, I could not run any parallel simplefoam simulations after running snappyhexmesh using mpirun.
Do you have any advice to fix this issue?
Thanks,
Zsolt
dragazsolt is offline   Reply With Quote
Openfoam on windows cluster with OpenMPI craig.tickle OpenFOAM Installation 9 October 17, 2014 00:21
Windows 7 binaries that do not require admin priviliges jola SU2 Installation 10 January 10, 2013 18:19
OpenFOAM 2.1.x Windows Patch Released gocarts OpenFOAM Announcements from Other Sources 0 January 18, 2012 15:56
CFX Parallel Setup on windows 7 x64 SlicedBread CFX 1 November 14, 2011 18:06
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
