June 11, 2009, 08:01 |
Setting variable material properties
Philip Cardiff
Rep Power: 34 |
I have a meshed femur (thigh bone), I ultimately want to be able to assign variable Young's Modulus values to the bone, dependent on the CT scan intensity. Or at least some sort of varied Young's Modulus higher at the surface and lower in the centre. I know one can use setFields utility to assign values (as in the newStressedFoam, damBreak etc tutorials). But setFields seems to only be able to assign value to simple geometry regions. I will probably just have to mess around with setFields, but if anybody has done anything similar or if anybody has any tips, they would be much appreciated. Philip |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Vaiable Material properties | Pialisen | FLUENT | 2 | November 29, 2006 14:12 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
