August 17, 2006, 07:58 |
I was trying to reach the wiki
#21 |
Guido Adriaensen
Rep Power: 17 |
I was trying to reach the wiki-site (http://openfoamwiki.net) , but I could not get access. Is the site out of the air? Or is it at another location?
Guido |
August 17, 2006, 08:58 |
I'm looking into the problem.
#22 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm looking into the problem. It seems like the university is playing around with the firewall and is blocking our webserver (I can reach the Wiki from inside the university net but not from outside)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 17, 2006, 09:14 |
Oke thanks Bernhard! I'll try
#23 |
Guido Adriaensen
Rep Power: 17 |
Oke thanks Bernhard! I'll try later.
August 17, 2006, 09:31 |
Should be working again.
T
#24 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Thanks for your feedback. I would have lived in blissful ignorance about the state of the Wiki without it.
August 17, 2006, 10:24 |
Indeed it is working again, th
#25 |
Guido Adriaensen
Rep Power: 17 |
Indeed it is working again, thx for the fix!
October 19, 2006, 10:07 |
Hi!
Seems there is a problem
#26 |
Hi!
Seems there is a problem on one of the main page of the Wiki : http://www.cdlact.unileoben.ac.at/non_cdl/OpenFOAMWiki/index.php/Main_Page#The_a pplications On my browser, most of the links on this page produce an error message , like that one for example : "Not Found The requested URL /index.php/Main_OFSolvers was not found on this server." (when requesting http://www.cdlact.unileoben.ac.at/in...Main_OFSolvers ) Does any other user notice a similar error? Otherwise I would like to express all my thanks to the webmaster and the authors for this very useful website! Regards, Jonathan |
October 19, 2006, 13:49 |
Are you accessing it through:
#27 |
Mattijs Janssens
Rep Power: 26 |
October 19, 2006, 14:12 |
Hi Jonathan!
Mattijs is rig
#28 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Jonathan!
Mattijs is right, you should access the Wiki through the openfoamwiki.net-URL (the other one happens to be the machine the Wiki lives on, a fact which might change). What you are seeing is that the Wiki-engine tries to rewrite parts of the URL - for the openfoamwiki.net-address, which won't work for the cdlact-address. BTW: I have been told that the university had a 2 hour internet-downtime today. I apologize if the Wiki wasn't reachable in that time (I wasn't in the office so I don't know for sure whether that was the case)
October 20, 2006, 05:22 |
Hi!
Ok I did not know for the
#29 |
Hi!
Ok I did not know for the correct url, by default I was always using the one provided on the openCFD website! (cf. http://www.opencfd.co.uk/openfoam/di...tml#discussion ) Maybe will this page be updated soon! Anyway, I have an other error with the openfoamwiki.net adress, the issue is different. When I'm requesting the page indicated by Mattijs I get a timeout message from my browser. This is quite funny as the ping of this domain, even if long (1 second!), is successful (cf. below). Could be just a matter of time/network... ;-) or could be something else! ;-) I will try from home tonight, maybee will that be more successful! Cheers, Jonathan ps : -for information- even after having change the default seting for the timeout on my browser (to 1.5second) I keep having this problem. S:\>ping www.openfoamwiki.net Pinging www.openfoamwiki.net [213.229.60.9] with 32 bytes of data: Reply from 213.229.60.9: bytes=32 time=1029ms TTL=50 Reply from 213.229.60.9: bytes=32 time=1103ms TTL=50 Reply from 213.229.60.9: bytes=32 time=1157ms TTL=50 Reply from 213.229.60.9: bytes=32 time=1157ms TTL=50 Ping statistics for 213.229.60.9: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 1029ms, Maximum = 1157ms, Average = 1111ms |
October 23, 2006, 04:45 |
Today everything is fine
#30 |
Today everything is fine regarding the access to openfoamwiki URL! This was a network issue then! Thank you very much all! Jonathan |
February 24, 2007, 10:37 |
This morning I try to f
#31 |
Francois Beaubert
Rep Power: 17 |
This morning I try to find a way to convert my LaTeX files to the MediaWiki syntax found on openfoamwiki. Perhaps such a tool will help TeX users to post some useful info on the Wiki ... So far I have found: http://wikisophia.org/wiki/Wikitex http://qwiki.caltech.edu/wiki/Converting_LaTex_To_Wiki Any way, hope this will be usefull ... |
February 19, 2008, 09:23 |
Hi!
Bad news. The machine t
#32 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
Bad news. The machine that hosted the Wiki decided that this world is no longer worth living in. There exist backups (and the hard-disk still seems to work) and I'm setting up a different machine with them, so I'm hoping to have it back online by the end of the week. For obvious reasons the Wiki will not be available till then. I apologize for any inconvenience caused. Bernhard
February 21, 2008, 20:37 |
Hi!
The Wiki is back online
#33 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
The Wiki is back online .... kind of. The server moved to a new location, but half of the nameservers (amongst them mine) still refer to the old location. So please be patient. The Server died on the 19th at approx 9am (MEZ), the last backup was at the 17th approx 4am. Any edits done between these dates will be lost. Sorry. Also the Wiki got moved to a new version of the Wiki-software. The only downside to this move is that characters with "exotic" encodings (German Unlauts for instance) got garbled. I guess we have to live with that. Should you experience any other problems (and I suspect here still might be some), please contact me. Bernhard PS: As the server is quite new I might have to do some modifications. Expect unanounced downtime (but not longer than a few minutes)
August 5, 2009, 15:08 |
#34 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
After sitting on these changes for some time I finally changed the front page of the Wiki.
The redesign was done by Jason Hoogland who felt that the old design of the front page was not very user friendly as finding stuff involved a lot of scrolling and he felt it would be nice if there were links to the forum, the doxygen etc right on the first page. The new design was presented at the Workshop in Montreal and the feedback there was quite positive (and minor changes suggested) There are further changes planned that would make it easier to update the New and other sections without editing the front-page itself but the plugin that should do this is broken and I currently haven't got the time to fix it. Feedback is appreciated (either here or on the discussion-page) Thanks again to Jason Hoogland for the re-design and Henrik Rusche and all the others who suggested or contributed adjustments Bernhard |
August 8, 2009, 05:21 |
#35 |
Philippose Rajan
Rep Power: 25 |
Hello Bernhard,
A Good Morning to you :-)! I was looking through the "new and improved" OpenFOAM Wiki, and I must say.... it does look cool :-)! Nice work and thanks to everyone who was involved in the rework effort....! The wiki has grown by a decent proportion in the last few years.... nice to see a multitude of "How-to"s... tips... contributions, etc...! I was wondering if it would be possible to have a link to the Wiki at some prominent... easily visible location on the OpenFOAM CFD-Online forum.... something like a Sticky-post in large red (or maybe blue is a little less aggressive !!) bold font :-) !? One question though.... what did you people use to create the front page of the wiki? Was it purely hand-crafted by some mediawiki "super-dude" ? Or are there some tools that normal people can use to come up with such a slick interface? Anyway... all in all.... nice work... :-)! Have a great day! Philippose |
August 10, 2009, 16:38 |
#36 | |||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
To have a look at how it is done just click on the "View Source"-Tab on the top and you will see it was done Bernhard |
December 8, 2009, 16:29 |
#37 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
Due to a hardware problem the machine that hosts openfoamwiki.net is currently down. We're working on it, but I can't promise anything before next week Bernhard |
December 11, 2009, 17:09 |
The Wiki is back!
#38 |
The Wiki is running again. Excuse tad longer downtime. I blame national holiday on Tuesday, burned out motherboard and power supply that had to be ordered and finally my apprentice administration skills.
For record: Bernhard promised me Toblerone as a reward. Note: Clarify with Bernhard "We're working on it, but I can't promise anything before next week". Does it make the second Toblerone negotiable? Last edited by pvita; December 11, 2009 at 17:12. Reason: Typo as usual... |
December 13, 2009, 12:28 |
#39 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
[QUOTE=pvita;239688]The Wiki is running again. Excuse tad longer downtime. I blame national holiday on Tuesday, burned out motherboard and power supply that had to be ordered and finally my apprentice administration skills.
/QUOTE] Thanks again. One more remark: AFAICT (As Far As I Can Tell) no edits were lost. I apologize again for the downtime. Bernhard It would have been, yes. But because you're discussing sensitive internal topics (distribution of chocolate) externally I deduct it. So only one. |
May 17, 2010, 11:52 |
#40 |
Paul Garlick
Rep Power: 17 |
Hi Berhard,
I have noticed that the link to the 'NETL wiki' on the OpenFOAMWiki site is currently not being found. (This is in section 3.2 Tutorials) Do you know whether this is a temporary situation on the NETL site or has the content been moved? Cheers, Paul. |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam/60855-wiki.html
Posted By | For | Type | Date | |
OpenFOAMWiki | This thread | Refback | July 16, 2012 05:06 |
Wiki | iyer_arvind | OpenFOAM Running, Solving & CFD | 1 | July 26, 2007 03:12 |
Wiki | Dan | Main CFD Forum | 1 | February 4, 2007 19:14 |
CFD-Wiki - We Need Your Help! | Jonas Larsson | Main CFD Forum | 5 | May 12, 2006 09:25 |
CFD Wiki - We Need More Help! | Jonas Larsson | Main CFD Forum | 0 | September 26, 2005 09:11 |
CFD Wiki - We Need More Help | Jonas Larsson | Main CFD Forum | 13 | September 13, 2005 18:36 |
