Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
interFoam parallel
Old   June 6, 2010, 22:06
Default interFoam parallel
bunni is on a distinguished road
As discussed in a thread related to parallel computation, I've hit a bug in interFoam.
discussion is here: http://www.cfd-online.com/Forums/ope...-parallel.html
Starting at post #23, I've got the output of the log file, and then on a following post I've included the files I've used. (blockMeshDict etc). I've been running that case serially now with different types of turb models (including laminar), and it runs fine on a single proc. for days. It's just the parallel jobs that die. Sadly, I was hoping for results sooner rather than later ...
bunni is offline   Reply With Quote
Old   June 9, 2010, 12:13
Mattijs Janssens
mattijs is on a distinguished road
Took a while to find out what was wrong. The problem is your blockMesh which contains an unsupported mode of defining a cyclic (on patch1). We've only ever generated cyclics on opposite faces of a block but yours uses neighbouring faces.
Two workarounds:
- use opposite block faces and have a zero area axis face at the bottom.
- take your generated mesh and use createPatch to do an automatic face reordering. You'll need to add transformation information to your constant/polyMesh/boundary file (attached) and just have a dummy system/createPatchDict. Run createPatch and move the 1e-8/polyMesh back to the constant directory.
Thanks,
Mattijs
mattijs is offline   Reply With Quote
Old   June 9, 2010, 18:39
thanks, I'll try that.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
InterFoam in parallel sara OpenFOAM Running, Solving & CFD 3 April 19, 2011 06:05
Performance of interFoam running in parallel hsieh OpenFOAM Running, Solving & CFD 8 September 14, 2006 10:15
InterFoam problem running parallel vatant OpenFOAM Running, Solving & CFD 0 April 28, 2006 20:22
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
