Problem in fvschemes divSchemes cannot use Gauss linearUpwind |
October 18, 2007, 10:57 |
Looking at the UserG
nicolas
Rep Power: 17 |
Looking at the UserGuide, it's something I should be able to do. I want to use the linear Upwind scheme for div(phi,U). Using simpleFoam in Openfoam 1.4.1 on linux 64bit. div(phi,U) Gauss linear; div(phi,U) Gauss linear corrected; div(phi,U) Gauss QUICK; works fine. But div(phi,U) Gauss linearUpwind; does not. I get: --> FOAM FATAL IO ERROR : Grad scheme not specified Valid grad schemes are : 8 ( cellMDLimited extendedLeastSquares faceMDLimited leastSquares fourth faceLimited cellLimited Gauss ) file: /home/nr/OpenFOAM/nrousselon-1.4.1/run/ccm2foam4/system/fvSchemes::div(phi,U) at line 40. From function gradScheme<type>::New(Istream& schemeData) in file /home/nr/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/gradScheme.C at line 65. FOAM exiting /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear corrected; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } // ************************************************** *********************** // |
October 18, 2007, 11:13 |
You need to specify the grad-s
Rep Power: 22 |
You need to specify the grad-scheme used by linearUpwind, e.g.
div(phi,U) Gauss linearUpwind Gauss linear; or div(phi,U) Gauss linearUpwind leastSquares; or if you want to limit the gradient used by the linearUpwind scheme which is often beneficial div(phi,U) Gauss linearUpwind cellLimited Gauss linear 1; etc. |
October 24, 2007, 08:18 |
Thanks,
just what I needed.
nicolas
Rep Power: 17 |
Thanks,
just what I needed. Nicolas |
January 18, 2010, 10:45 |
#4 | ||
Rep Power: 17 |
I have the same problem and tried to adapte it on my case with the bouyantBoussinesqSimpleFoam, but it didn't work.
This is what I get: Quote:
January 19, 2010, 05:11 |
Hrvoje Jasak
Rep Power: 33 |
You messed up the order: cellLimited is a modifier for a gradient scheme, so it comes first. Think about which class should contain which.
div(phi,U) Gauss linearUpwind cellLimited Gauss linear 1; Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 22, 2010, 04:26 |
Rep Power: 17 |
Hi Hrvoje,
thank you. Stupid mistake. Now it's running! :-) Regards, Erik |
September 26, 2010, 16:55 |
Claus Meister
Rep Power: 18 |
Hello!
I got a question. Does div(phi,U) Gauss linearUpwind fourth mean that with order fourt the velocity field is approximated? Cheers |
September 27, 2010, 04:07 |
Alberto Passalacqua
Rep Power: 36 |
No, it means you use a fourth-order scheme to compute the gradients, but clearly the order of the linearUpwind stays unchanged.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 27, 2010, 04:31 |
#9 |
Claus Meister
Rep Power: 18 |
I think I have to learn something. Could you send me a reference which contains the derivation of this kind of scheme?
February 21, 2011, 08:21 |
#10 |
José
Rep Power: 15 |
Could you please have a look at this thread I just created?
http://www.cfd-online.com/Forums/ope...fvschemes.html thanks! |
November 12, 2011, 11:53 |
fvSchemes in OF20
#11 |
Jozsef Rideg
Rep Power: 15 |
div(phi,U) Gauss linearUpwind Gauss linear; or div(phi,U) Gauss linearUpwind leastSquares; or if you want to limit the gradient used by the linearUpwind scheme which is often beneficial div(phi,U) Gauss linearUpwind cellLimited Gauss linear 1; etc.[/QUOTE]" Does anyone know, how should the same fvSchemes be set in the 2.0 version of OpenFOAM? |
November 12, 2011, 16:16 |
#12 |
Hi!
gradSchemes { default cellLimited leastSquares 1; } divSchemes { default none; div(phi,epsilon) Gauss linearUpwind grad(epsilon); // OF20x syntax div(phi,k) Gauss linearUpwind grad(k); // OF20x syntax div(phi,U) Gauss linearUpwind grad(U); // OF20x syntax div((nuEff*dev(T(grad(U))))) Gauss linear; // OF20x syntax }
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
November 14, 2011, 13:16 |
#13 |
Felipe
Rep Power: 16 |
Could you help me with this:
Implementing: laplacian(nuEff,U) Gauss linear Gauss fourth; gives: [0] --> FOAM FATAL IO ERROR: [0] Unknown discretisation scheme fourth Valid schemes are : 3 ( corrected limited uncorrected ) but it should be able to work with fourth... Thanks |
November 14, 2011, 13:21 |
#14 | |
Alberto Passalacqua
Rep Power: 36 |
Gauss <scheme> <correction option>; so Gauss linear corrected; For fourth-order it is: Gauss cubic corrected; Best,
November 14, 2011, 14:02 |
#15 |
Felipe
Rep Power: 16 |
Thanks Alberto for your reply
Now it is running, so I hope my solution will improve. Thanks Felipe |
November 14, 2011, 17:39 |
Thanks
#16 |
Jozsef Rideg
Rep Power: 15 |
November 14, 2011, 18:00 |
#17 |
Felipe
Rep Power: 16 |
Hi again Alberto
Well my simulation ran, but I guess I have not achieved what I wanted. In the attached graph I have made the simulations from 0 to 20 degrees with a step of 2 degrees with OpenFOAM and another CFD code. I want to use the QUICK scheme, but I am over predicting my solution with OF in comparison to the other CFD code and both over predict lift in comparison to the measurements (Abbot and Doenhoff). I have my convection terms with QUICK and the diffusion terms with second order scheme (Gauss linear corrected). Thus I change my diffusion terms to a fourth interpolation scheme in order to improve my solution (QUICK2), and I can see that the curve is lower, but still it can not capture the separation pretty well. In this case my diffusion terms are Gauss cubic corrected. Do you have any suggestions for improving my results? Regards Felipe ps: I was going to upload the case but due to the size, it did not let allow me to do it. But I could send you a tar file with it (2.7 MB). |
November 15, 2011, 10:25 |
#18 |
Which OF version do you use?
November 16, 2011, 02:10 |
#19 |
Felipe
Rep Power: 16 |
I use 1.7.1
November 16, 2011, 03:28 |
#20 |
Ok, because in 20x I noticed strange behavior: viscous terms are under-estimated in my case with equal settings I was simulating in v16 and 17x. I will study it in details and also report here on forum.
DivSchemes Gauss limitedLinearV and interfaceCompression | nicasch | OpenFOAM Running, Solving & CFD | 1 | July 12, 2010 11:26 |
FvSchemes | sega | OpenFOAM Running, Solving & CFD | 2 | February 15, 2010 12:07 |
DivSchemes limitedLinearV and interfaceCompression | nicasch | OpenFOAM | 0 | February 28, 2008 11:33 |
Divschemes limitedLinearV 1 and interfaceCompression | nicasch | OpenFOAM | 0 | February 27, 2008 13:24 |
FvSchemes from 12 to 11 | fedegavo | OpenFOAM Running, Solving & CFD | 1 | January 20, 2006 14:49 |
