Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
YPlusRAS and interFoam
Old   October 23, 2008, 13:43
Default yPlusRas does not currently wo
Dennis Kingsley
dkingsley is on a distinguished road
yPlusRas does not currently work with interFoam/rasInterFoma etc. The issue is that the transportProperties dictionary contains data for 2 phases.
Has anyone modified yPlusRas to work for this case, I tried to quickly swap in:
//#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/incompressibleTwoPhaseMixture/twoPhaseMixture.H"
and calling
//singlePhaseTransportModel laminarTransport(U, phi);
twoPhaseMixture laminarTransport(U, phi);
however, it crashes with the following message:
Selecting incompressible transport model Newtonian
request for volScalarField alpha1 from objectRegistry region0 failed
available objects of type volScalarField are
3
nu2
nu1
yPlus
Can anyone point me in the right direction, I would like the tool to ultimately give me the yPlus values for each phase just like it does for a single phase based on the initial definition of gamma.
dkingsley is offline   Reply With Quote
Old   October 23, 2008, 15:23
Default Dennis, The source of your
James Criner
jcriner is on a distinguished road
Dennis,
The source of your error is likely the lack of the gamma field (i.e. you need to read in the gamma field and create the twoPhaseMixture properties for mu() and nu()). Have a look at
src/turbulenceModels/RAS/incompressible/RASModel/RASModel.C
src/transportModels/incompressible/incompressibleTwoPhaseMixture/twoPhaseMixture .C
to see what is going on. Then you could follow the source in createFields.H of rasInterFoam for how to create (read in) the gamma field and create the twoPhaseMixture properties.
James
jcriner is offline   Reply With Quote
Old   October 23, 2008, 21:32
Default James, Thanks for the advic
Dennis Kingsley
James,
Thanks for the advice, I have it working now.
Dennis
Old   October 23, 2008, 23:25
Default Next question, I would like to
Dennis Kingsley
Next question, I would like to override the RASModel::YPlus method in the SpalartAllmaras class to add the alternative yPlus formulation that I found in this older post http://www.cfd-online.com/cgi-bin/Op...c=1&post=18488.
Is this a reasonable approach? Is there a more suitable formulation?
tmp<scalarfield> tYp =
sqrt(mag(turbulence->nuEff()().boundaryField()[patchI]*
U.boundaryField()[patchI].snGrad()))/
nu.value()*nearWallDist(mesh).y()[patchI];
scalarField& Yp = tYp();
Old   April 28, 2010, 10:08
Claus Meister
idrama is on a distinguished road
Hello dkingsley,
I read your post! I just want to know what have you change in yPlusRAS.C, i.e. have you only made that change:
or have you done a couple of things more?
Cheers
idrama is offline   Reply With Quote
Transient interFoam with MRF jaswi OpenFOAM Running, Solving & CFD 18 October 21, 2011 00:29
Writing yPlusRAS Values velan OpenFOAM Running, Solving & CFD 0 December 30, 2008 07:09
Outlet bc in interFoam happysimulant OpenFOAM Running, Solving & CFD 0 November 6, 2008 11:06
InterFoam floooo OpenFOAM Running, Solving & CFD 0 November 3, 2008 12:00
About interfoam solver qiu OpenFOAM Running, Solving & CFD 0 May 6, 2007 23:48
