Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Meshing a Wheel in Pointwise/Fluent problem
Old   November 28, 2010, 12:38
Default Meshing a Wheel in Pointwise/Fluent problem
Luke
Marli is on a distinguished road
Hi All,
I am attempting to mesh an external flow around an aircraft wheel (closed rim) in Pointwise to run using (at first) the k-e RKE model with Enhanced Wall Function.
My mesh is built up in sections, first is the boundary layer. Using Y+ of 1 (0.0057mm) and expansion ratio of 1.2, for a wheel D of 1.4m, and reynolds number of 6.71x10^6, 70m/s. The quarter-wheel profile is meshed in 2d then rotated/mirrored around to cover the whole wheel. This is then built up into the far field cuboid mesh, 5.6m x 5.6m x 4.2m (infront) x 10m (behind), 3.6 million cells in total. (see attachments). Pointwise Wall Spacing examination corresponds to equivalent ~ 0.6>y+>1.6 around the whole wheel.
Now, when I run it in Fluent, I get Continuity divergence after only about 50 iterations, and when I do a Turblence>YPlus contour in fluent I often see huge Y+ values (10^3), although this seems to vary depending on how long i run it, so I don't know whether due to the divergence this examination is irrelevant.
So in summary, according to Pointwise, my y+ is pretty consistent, but I get continuity convergence quickly in fluent. I have re-meshed loads of times with same divergence. So not sure whether it's a Pointwise or Fluent problem.
Any help would be much appreciated.
Marli is offline   Reply With Quote
Old   November 28, 2010, 17:43
Chris Sideroff
cnsidero is on a distinguished road
Luke,
What are the dimensions of the wheel? I ask because you have to make sure it's scaled properly in Fluent, as it works in meters. For example, if you created a wheel with a diameter of 1000 in Pointwise, representing the units mm, you will have to scale it in Fluent by a factor of 0.001.
Since you reported y+ values 3 orders of magnitude higher than you were expecting, my guess is that your Reynolds number is 1000 too large, hence the incorrect scaling.
Let me know if that works.
-Chris
cnsidero is offline   Reply With Quote
Old   November 28, 2010, 19:27
Luke
Genius! It worked!
Thanks Chris, this had been bugging me for weeks. It was indeed the scaling so Fluent thought my mesh was 10km long! Now I can move on to the proper stuff
Many thanks again, I should have posted this ages ago. Yet another reason why CFD online/wiki is an indispensable resource!
Luke
Old   January 22, 2011, 22:49
Default More scaling/units problem
arapha is on a distinguished road
I am using a k-omega SST model on a flow going through a duct. I should get my y+ between 1 and 5 I believe from what I've seen. I found out about a scaling issues in Fluent thanks to your previous posts. However I am still having difficulties obtaining the right y+ values from my mesh. When I try to adapt in Fluent it halves the y+ value but horribly increases the number of cells. My mesh y+ is about 60 so that I can't obtain the correct y+ value with a decent sized mesh in Fluent. I'm wondering if this is another scaling issue in Pointwise (importing from CATIA to Pointwise, or in Pointwise, do I have to set the units ? If I go to Properties the ratio of Grid/Database is about 600 ??). Or am I using the adapt function in Fluent wrong ?
Any thoughts or suggestions greatly appreciated.
Thank you !!
arapha is offline   Reply With Quote
Old   January 26, 2011, 22:15
Tobino
tobino is on a distinguished road
Dear all,
I am meshing a model of ship. Have anybody known How to create structure mesh? please advise me !
tobino is offline   Reply With Quote
Old   March 14, 2016, 12:40
Default sclae
masoudsh is on a distinguished road
hello
i create mesh in pointwise
i import it in openfoam but i have a problem
openfoam in default import mesh in meter but my mesh in mm.
can anyone help me?
thanks
masoudsh is offline   Reply With Quote
Old   March 27, 2020, 01:47
Marium Mou
Marium is on a distinguished road
have you succeeded? I am also trying to create structure mesh in pointwise.
Marium is offline   Reply With Quote
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Gambit meshing problem nana ANSYS Meshing & Geometry 5 August 31, 2009 06:58
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 09:29
Meshing problem... Gustaf CFX 2 March 28, 2003 11:37
