Difference betw Binary & Fortran Unformatted? |
April 25, 2002, 00:38 |
My cfd output file is in Fortran Unformatted PLOT3D format, I want to convert it to get PLOT3D Binary file? How should I do? Anyone can point out their difference?
Thank you YRB |
April 25, 2002, 09:43 |
Re: Difference betw Binary & Fortran Unformatted?
If they are both of same Endian kind (big/little) and if I remenber well, it's just a matter of C. Return. Fortran ends each line with a CR.
Sylvain |
April 26, 2002, 05:42 |
For each single instruction write(), the binary fortran format (unformatted) include at the beginning and the end of the data block a word (4 bytes) giving the size of the data block. For instance : write(10) k write(10) ((a(i,j),i=1,2),j=1,3) write(10) b,c where each variable as a size of four bytes (integer and float) will result in : [4] [binary value for k] [4] [24] 6*[binary value for a(.,.)] [24] [8] [binary value for b] [binary value for c] [8] with [] a four bytes block. The existence of these blocks is the only difference between a binary format and the fortran unformatted format for PLOT3D. Best regards |
April 28, 2002, 04:04 |
Thanks a lot. What you pointed out is exactly the difference. I have fixed my format problem.
Ruobo |
Comparison between C/C++ and Fortran? | rick | Main CFD Forum | 45 | September 6, 2011 01:52 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Binary in Fortran | Gerrit | Main CFD Forum | 6 | September 8, 2006 05:26 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 09:42 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
