Which turbulent model is good for a diffuser?
Old   March 19, 2012, 12:57
Default Which turbulent model is good for a diffuser?
mertimiks is an unknown quantity at this point
So I placed a duct (diffuser) around my wind turbine, and the air flow is turbulent. So do you guys have any recommendations for which turbulence model should I used, and why?
mertimiks is offline   Reply With Quote
Old   March 19, 2012, 13:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
SST with automatic wall treatment. Keep y+ below 10
Far is offline   Reply With Quote
Old   March 19, 2012, 13:40
Why is that? What do you mean by y+ below 10?
Old   March 19, 2012, 14:00
Zigainer is on a distinguished road
Sorry, but that is real basics ... you should understand that, because otherwise you wonīt know how to get a good solution.
http://www.cfd-online.com/Wiki/Dimensionless_wall_distance_%28y_plus%29
Zigainer is offline   Reply With Quote
Old   March 19, 2012, 14:02
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
This is what i learned recently, someone please corrects me if i'm wrong:
Y+ is an non-dimentional parameter that determines how refined your mesh is near a wall and therefore how accurate you can be (regarding boundary layer), the more refine the more accurate, small value means good accuracy in general below 10 and not less than 0.
There is a tool in cfd-online that allows you to determine the height of the first cell near the wall depending on the Y+ you want. just google Y+ estimator.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 19, 2012, 14:10
yes
y+ is important for wall treatment. To less cells for the boundary layer (not only y+ of the first cell, also number of cells within the boundary layer) will not resolve the boundary layer correctly and therefore your solution is not good. If you use "wall function" instead of resolve the boundary layer, your y+ can be lager (y+ ... 20-200) and you do not need so many cells within the boundary layer. low-Re mesh need y+<1 to be accurate.
y+ canīt be less than 0
How to model a turbulent flow over a cylinder? Mahbub FLUENT 14 February 10, 2018 12:14
turbulent viscosity in k-e model orlik Fluent UDF and Scheme Programming 1 July 19, 2017 13:27
Turbulent combustion error... XiFoam model achinta OpenFOAM 1 July 7, 2010 09:24
k-w turbulent model and inflow boundary conditions vaina74 Main CFD Forum 6 April 26, 2010 07:03
contradicting results of different turbulent model dani FLUENT 0 July 6, 2004 03:07
