How to rectify the error of mesh check failed |
November 17, 2011, 04:34 |
mahendra
Rep Power: 15 |
Hi friends,
This is mahendra. I imported the mesh from icemcfd(tet) to fluent. While doing the mesh check operation i got the problem. ie WARNING: 3 degenerate contact points identified. To print out a list of the contact points call (print-contact-points)......................... Done. WARNING: Mesh check failed. Can anyone help me to solve this problem Thanks in advance Mahendra |
November 17, 2011, 15:35 |
raj
Rep Power: 15 |
In ICEM as far as i remember, you have mesh check options that looks for t-connections, degenerate cells, free edges etc etc. try running them first. Look for mesh quality, especially the skewness, AR, OQ, EQ etc . if the mesh is good enough fluent doenot complain about mesh check failed.
In fluent you do have mesh repair options, use them using text commands. It should solve your problem. Please let me know if this is useful.... |
January 24, 2013, 02:34 |
#3 | |
davia
Rep Power: 13 |
May 18, 2013, 23:43 |
#4 | |
davia
Rep Power: 13 |
thank you |
January 22, 2014, 12:11 |
run with no issues
Manuel Díaz Brito
Rep Power: 13 |
And a year later... my contribution: getting the same mesh check failure "1 degenerated point" the simulation runs with no further complaints! However it would be better to don't have such errors in the mesh for improved convergence etc...
mesh check failed / degenerated contact points | shohin | FLUENT | 16 | April 11, 2014 23:32 |
Mesh Check Failed, Please Help! | fyp | ANSYS | 4 | August 29, 2010 06:41 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Storage alloction failed in cfx mesh | Mario Tremblay | CFX | 2 | March 6, 2009 11:35 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
