May 9, 2011, 17:51 |
accessing dpm data commands, help!!!
patty
Rep Power: 16 |
hey,
does anyone know where all of the random commands used in udf's by fluent and even some users on here can be found? i'm talking about things that i can't find documented anywhere that seem to be critical for some udf's. for example: p->stream_index = -1 to turn off a particle stream loop(I, Ilist) { } to loop through all injections i cant find documentation on these anywhere. it makes me wonder what other commands are out there that could really help me. can i go through any of the "xxx.h" files to find these? in particular, im trying to set the start and stop time of an unsteady particle injection in a udf, but i can't find a macro for that in fluent's udf manual. id also like to know where people find these obscure commands so i can help myself more easily in the future. thanks! |
May 10, 2011, 12:02 |
Bernhard
Rep Power: 22 |
Did you check dpm.h in the /src dir of your installation (for me in /opt/packages)? It is nice for accessing information of particles, but you should be very carefull to changes the variables from your udf.
May 10, 2011, 12:28 |
patty
Rep Power: 16 |
Thank you for the reply, Bernhard.
I did look through all dpm_xxx.h and dpm.h files, and dpm_types.h seems to be the most resourceful file where things like P_INIT_RHO(p) or P_POS(p) are defined. Here's one line of code from the file: #define P_INIT_RHO(p)((p)->init_state.rho) To me, that means I could use either the macro P_INIT_RHO(p) or p->init_state.rho in a udf and get the same result. There's nothing defined in this file for start/stop time, however. The deeper question to me is where are things like init_state.rho or state.pos defined in the first place? That file is the one that would probably list all data access variables. |
May 11, 2011, 03:44 |
Bernhard
Rep Power: 22 |
I can find the time_of_birth real in the tracked_particle_struct
I'm not exactly sure what time you mean exactly with start/stop time, but I suppose those are solver settings, that you cannot change for a single particle. |
May 19, 2011, 17:58 |
patty
Rep Power: 16 |
I got it now, so here's how it works.
loop(p,I->p_init) { I->unsteady_start = ... I->unsteady_stop = ... } You need to have initial values inserted in the GUI other than 0 for both or FLUENT will completely ignore the injection. |
dpm, udf |
Export Data DPM | OSouza | FLUENT | 0 | March 20, 2009 08:48 |
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 06:19 |
Saving particle (DPM) data to file? | Philip | FLUENT | 2 | June 12, 2006 02:41 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
Accessing solution data in UDF | Ale | FLUENT | 1 | June 12, 2002 01:25 |
