trying to simulate two-phase jet flow with particles in surface injection
Like Tree3Likes
  • 1 Post By ajkratos
  • 1 Post By Amir
Old   March 21, 2011, 13:21
Default trying to simulate two-phase jet flow with particles in surface injection
ajkratos is on a distinguished road
Hi
I am trying to simulate two-phase jet flow. I use my inlet surface which is 0.1x0.1 to inject particles. Mass loading is 0.1, diameter of the particle is 7.69E-04m and the total mass flow rate of particles is 0.01225 kg/s. Using this data i calculated i need to inject 7.04E+04 particles to achieve the mass loading of 0.1. But in surface injection, the number of particles injected are equal to number of cell faces on that surface which in my mesh are 25.
I do know that i can increase the number of particles by creating a surface and samples on that surface which will be equal to number of particles, or/and and i can switch on the stochastic tracking in which case No. of tries are multiplied to the number of particles released by the surface.
my question is what is the significace of specifying mass flow rate in point properties tab of DPM, how does it effect the number of particles injected? As i increase or decrease the value of total mass flow rate of particles, the number of particles remain same= No of mesh faces. Soo why does fluent need the total mass flow rate of particles. Also if i switch on stochastic tracking and increase the number of tries just to increase the number of particles, what other implications will it have other than increasing the number of particles?
I will really appreciate if sumone culd help, i urgently need to clear this. Thanks
ajkratos is offline   Reply With Quote
Old   March 21, 2011, 16:00
Amir's Avatar
Amir
Amir is on a distinguished road
the particle mass flow rate doesn't change the No. of particle streams but it implicitly affect particle numbers in the flow field. you can imagine each stream as a sequence of specified particles and you can change that by changing mass flow rate.
in finding particle trajectories, the mass flow rate doesn't play a role but in particle concentration concepts it's very important.
Amir is offline   Reply With Quote
Old   March 22, 2011, 08:21
Originally Posted by Amir View Post
Hi Amir thanks for your helpful reply. How do i determine the totall No. of particles being ejected? Am i right to understand that each particles stream represent No. of particles according to the totall mass flow rate specified in point properties? I have 25 mesh faces on the inlet surface so there are 25 particles streams being ejected. If i divide the total mass flow rate by 25 is it correct to say that i will get mass flow rate of each stream and then i can calculate No. of particles in each stream by
No of particles in each stream= mass flow rate of stream/mass of single particle
Also in my case the diameter of all particles is same and the distribution is uniform.
hassansalem likes this.
Old   March 22, 2011, 08:43
Amir's Avatar
Amir
If you divide the total mass flow rate by 25; you'll obtain mass flow rate of each stream.
so i correct your statement:
No of particles in each stream= (mass flow rate of stream/mass of single particle)*(the time of first particle tracking in each stream)
so it's dimension is also correct.
Old   March 22, 2011, 11:32
yes ofcoarse i meant number of particles in 1 second. Thank you very much amir, you have been very helpful
Old   March 3, 2015, 22:33
Zhimin Zheng
zhengjimi is on a distinguished road
Are you sure that No of particles in each stream=total flow rate /truck numbers/ mass of single particle(NO/s)?
But I can not understand that meaning of P_FLOW_RATE(p)?
Thanks for your help ?
zhengjimi is offline   Reply With Quote
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 08:01
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
how to simulate jet flow? Benny FLUENT 18 May 12, 2014 11:53
How to define the diameter for second phase in Eulerian model in free surface flow boa7128 Fluent Multiphase 1 December 14, 2013 07:20
injection problem Mark New FLUENT 0 August 4, 2013 02:30
