December 8, 2010, 18:00 |
two boundary condition on an edge or face
Rep Power: 16 |
hi all again me Akhenathon
first off all i very pleased to previous helps of you and i thank you. my new problem is; im working on a 2D invisdic, incompressible flow. i want to determine inlet and outlet pressures and velocities. But i didnt find with these together. there is a velocity inlet boundary condition and pressure outlet condition. if i want to give an edge two boundary condition( velocity and pressure values together), what i must do? |
December 8, 2010, 19:36 |
Rep Power: 17 |
I am unsure if one can use velocity inlet and pressure outlet in the case setup.
The easiest thing to do is: use "velocity inlet" and "outflow" boundary conditions. Usually these converge very easily. Once converged one can check all observables on any boundary. Report->Result reports... opens a menu Choose Area-weighted-average on the left choose static pressure on the right select your outlet from the list below You will have the value of pressure Similarly, one can calculate many other properties at any boundary |
December 9, 2010, 15:10 |
Rep Power: 16 |
i mean that
inlet boundary condition: Velecity 10m/s and pressure 10 Pa outlet boundary condition: Velocity 10 m/s and presssure 10 Pa is it possible?? İf it is, how can i do that? |
December 9, 2010, 16:11 |
Rep Power: 17 |
if you use density-based solver, you can input a pressure reading in the velocity inlet window. But it will be used only in a case of backflow
December 9, 2010, 21:01 |
#5 | |
Real Name :)
Rep Power: 16 |
If you think about flow in a pipe, I believe you're trying to over-specify the problem. You can specify the mass flow and one pressure (inlet or outlet) and the solver will solve the other. You can specify both pressures and the solver will calculate a mass flow. You can specify both mass flow and the pressure distribution will be calculated. You are trying to specify the mass flow and the pressure at both boundaries. If I'm correct, there is nothing left to solve. Regards, ComputerGuy |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
Boundary condition vector field gradient from two sides of patch face | quba | OpenFOAM | 0 | December 12, 2007 06:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
