pressure time history of some nodes
Old   January 27, 2010, 14:29
Default pressure time history of some nodes
ibuki kusano
ibuki is on a distinguished road
Hello. I'm running a 2D transient model, and I would like to know if there is a way to write an output of pressure time history of certain nodes.
Thank you.
ibuki is offline   Reply With Quote
Old   January 27, 2010, 16:59
DoHander is on a distinguished road
Yes, it is possible. Define a surface that pass through your nodes and then write a Scheme or a UDF function that will save the data at every iteration or time step.
Do
DoHander is offline   Reply With Quote
Old   January 28, 2010, 06:35
Default UDFs
ibuki kusano
Thank you for the reply. I have never used UDFs, and I've been reading the manual about UDF and Scheme. I know that I have to write UDF using C code, but I don't have much idea of what exactly I have to do. Would you give me a little example of this case to print pressure of some nodes along a surface every X time steps? Thank you very much.
Old   January 28, 2010, 17:14
This will save the pressure coefficient from a zone named "zone_name" at each time step in files named data-0000.txt data-0001.txt ....
(cx-macro-define
'((save-data . "file/write-profile\ndata-%t.txt\nzone_name\n\npressure-coefficient\nq\n")
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
