how iam determine good quality of mesh grid of airfoil using gambit
Old   June 29, 2009, 04:00
Default how iam determine good quality of mesh grid of airfoil using gambit
labib
nuimlabib is on a distinguished road
how to determine the good quality of grid mesh of airfoil using gambit to get a good aerodynamic coefficient...please help me..
nuimlabib is offline   Reply With Quote
Old   June 29, 2009, 09:02
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Well that is very much a flow dependent issue.
You have to look at your y+ values for the first cell.
If you want to use nearwall modeling you need a y+ below or equal to 1, although the Fluent manual says below 4, as I can recall.
If you only need to resolve the wall shear layer you need a y+ above 30 and preferably below 100, but not higher than 300.
If you have no idea what y+ is please consult the manual as this is very important for this kind of problem. Searching google for "law of the wall turbulence" you will find information why this is important.
also the book "Bruce R. Munson, Donald F. Young and Theodore H. Okiishi - Fundamentals of Fluid Mechanics" or "Schlichting, Hermann; Gersten, K. - Boundary-layer Theory" are good reads on the topic.
Back to you question,
you don't know if your mesh is sufficiently fine/coarse before you have set it up and have a converged solution in Fluent / other CFD. Fluent has built in features which can refine the mesh based on some values eg. y+, so maybe this would be an idea.
Regards
linnemann is offline   Reply With Quote
Old   June 29, 2009, 09:11
linnemann's Avatar
Niels Nielsen
ooops double post
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 16:41
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
How to creat mesh in Gambit for airfoil sanjay FLUENT 3 March 15, 2005 04:14
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
