February 21, 2009, 16:24 |
Hydrogen-Air Non-Premixed Combustion
Hello there, I am working on simulating hydrogen-air non-premixed combustion. I am having problems in attaining good results. My set-up includes a jet of hydrogen at 900K (to allow for auto-ignition) flowing into a still enviroment at 300K (working fluid by default - air). I have modelled the problem using non-premixed combustion model. The contours of static temperatures does not show an increase in temperature; in other word, I cannot see the flame (which tells me that combustion does not take place). I have even tried patching the fluid to a temperature of about 2000K, but nothing seems to work out. Please help me out! The deadline for the work is due in for the 3rd of March, 2009. I would really appreciate your help.
Thanks |
February 22, 2009, 16:01 |
Re: Hydrogen-Air Non-Premixed Combustion
Hi Wasim,
I am working on the similar problem of nonpremixed combustion, but the fluids are air and methane. I just started my project and I am a beginner in Fluent. Could you please tell give me an idea that for nonpremixed combustion, what viscous models and other parameters do I need to select? Thank you so much. |
February 22, 2009, 17:14 |
Non-premixed combustion model in fluent is most suitable for turbulent diffusion flames. Hence I suggest you start off with k-epsilon standard model and have the default values for k and e (which is 1). Those are the value I chose anyway. The modelling process is quite straight forward, but i am just stuck because ignition does not seem to take place in my place. Anyways Good luck!
Regards, Wasim |
February 22, 2009, 18:03 |
Hello Wasim,
Thanks for replying. |
February 23, 2009, 14:20 |
Are you using the built-in reaction mechanisms? What values are you getting for kinetic reaction rate? turbulent reaction rate? You can modify parameters if needed to get combustion started. The basic k-epsilon model for turbulence combined with eddy dissiptation model for combustion will not give a lot of insight into the flame structure, but should at least show something burning.
February 23, 2009, 21:59 |
Since I was using non-premixed combustion model I do not have the choice to specify reaction mechanism. However, my simulation is now working and I think I have obtained good results (though I might be wrong). Thank you!
Regards, Wasim |
March 21, 2012, 05:44 |
#7 | |
Rep Power: 14 |
How did you correct this problem?? I am also having constant value for pressure and temperature |
February 5, 2013, 04:27 |
deepthi
Rep Power: 13 |
Use k-e model but try giving turbulence and hydraulic diameter in boundary condition instead of giving values for k and e
June 13, 2013, 04:48 |
#9 | |
Bahram
Rep Power: 12 |
I define the excess air of fuel by selecting a suitable mass flow of air at the boundary condition of the Fluent software,but I see that by increasing the excess air of fuel the maximum temperature is increased!?? I expect that the adiabatic flame temperature is dropped down by increasing the excess air of fuel. Please guide me that how can I define the excess air of fuel at the non premixed combustion model. Thanks Bahram |
Display Modes | |
air-hydrogen combustion | steven | FLUENT | 0 | August 15, 2008 18:06 |
Hydrogen combustion | Subramani | Siemens | 0 | March 10, 2008 00:52 |
hydrogen combustion | A.Subramani | Siemens | 1 | December 1, 2007 20:05 |
hydrogen combustion | George | Main CFD Forum | 17 | August 1, 2007 11:15 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 19:40 |
