parallel cfd
Old   March 18, 2008, 08:49
Default parallel cfd
venkatesh
Hi everybody,
I have following error(below), everything is fine until I terminate the calculation to save it. The followig error appears and I dont have datas anymore data to save. Please any comments.
Thanks Venkatesh
Writing "G:\venky_fluent\PCB_7M_dpm_sharedmemory.dat". ..
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory The Parallel FLUENT process could not be started.
Error: Error writing "G:\venky_fluent\PCB_7M_dpm_sharedmemory.dat". Error Object: #f
Old   March 20, 2008, 17:12
Default Re: parallel cfd
Vinod Dhiman
This happens because of communication error. So, one or more of the processors are not being able to communicate with the host node. Just make sure that you're using right type of communicator.
Old   April 8, 2008, 04:40
Aris Nikolopoulos
Which release do you have? Fluent 6.4.11 beta?
Old   November 13, 2011, 06:45
Emre G
emreg is on a distinguished road
same problem by me...
is there any solution??
thanks...
emreg is offline   Reply With Quote
Parallel UDF Karo FLUENT 2 April 25, 2017 02:36
Where is my Parallel Log andrewburns OpenFOAM Running, Solving & CFD 5 February 5, 2008 00:07
udf parallel Phil FLUENT 4 May 28, 2004 20:49
cfx parallel Rao CFX 7 April 17, 2004 00:53
Parallel run Bogdan Siemens 2 June 26, 2002 11:31
