GAMBIT STARTUP error
Old   June 23, 2007, 13:17
Default GAMBIT STARTUP error
Farhat
During the startup of gambit, error is displayed:
OPENGL_DEVICE_DRIVER not supported
Defaulting to X_DEVICE_DRIVER with standard visual. vgl_OpenGLDevBestVisualX: ierr= 8 SYS_ERROR_OPERATION An operation failed in current state
what does it signify?
Old   June 23, 2007, 13:40
Default Re: GAMBIT STARTUP error
Amir
Dear Farhat i think you have some problem abourt youe exceed set up.you should reinstall it . Best
Old   June 23, 2007, 16:21
Muhammad Usman Qureshi
make sure you have put the license file in the same directory in which gambit or fluent is installed.
Old   February 9, 2010, 14:52
ahmet
disturbed666 is on a distinguished road
did you solve this problem? I have same and i don't solve. if you solve this can you help me how i solve?
disturbed666 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
