Using file to define injection distribution!!(DPM)
Like Tree35Likes
Old   October 10, 2012, 06:47
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
Old   April 27, 2013, 13:46
Victor
VictorLP is on a distinguished road
Hello. I cannot create valid injection definition file.
May somebody send me some valid file?
Thanks in advance, Victor.
p.s: my e-mail: 1205blp@gmail.com
VictorLP is offline   Reply With Quote
Old   May 29, 2013, 16:44
Cristian
cantonuc is on a distinguished road
Hi, I need to generate the archive .inj to make an injection for a fluent model, but I don't know where to find the C routine to make this, can someone help me with this?? thanks a lot, and the other question is if this kind of archive can be used when the geometry is cylindrical or if I must to transform the coordinates to use it,
Please I need to make this step to start my model
Thanks a lot
Cristian
cantonuc is offline   Reply With Quote
Old   May 22, 2014, 14:40
Default What about the time?
  #24
Marcos
marcoscp2 is on a distinguished road
I don't understand how can I set up in the software the time of each injection.
For example, I want my first injection to begin at 30 s, my second injection needs to begin at 45 s and my final one at 60 s.
Does it mean that I have to create three injections and set in the software boxes for start and stop time manually?
marcoscp2 is offline   Reply With Quote
Old   May 22, 2014, 15:19
Victor
Why not? I think it is the best decision. Bisides if you will do such you will can track, get summuries and time statstics etc. for each injections separately.
Alternative is use injection profile with zero parametres such as velocity, flow rate, diameter etc. between injections. I think it is not good.
I also did injection of my second portion just by manual changing settings of injection-0. example: first injection start time 1ms stop time 2ms, second injection start time 2.1ms stop time 3.1ms. I calculated until 2.1ms with settings start time 1ms stop time 2ms, then changed to start time 2.1ms stop time 3.1ms and continued. Keep attention to your velosity and massflow profiles for right time coordinate.
Old   May 22, 2014, 15:31
Marcos
I undestand. But I don't think that is viable for a lot of injections. Let me explain better my problem so you can say if you agree with me.
I need 30 points of injection. Each point has to release particles with different diameters at different times in a random fashion (time and diameter). I'll need to set the start and stop times manually? That seems counterproductive to me. Even more if I think that later on I will have to create more points.
If you have any suggestions, please let me know. It will be much appreciated.
Old   May 22, 2014, 17:02
Victor
In this case I think you should use the number of injections equal number of position and create for each position velocity and massflow profile, that will contain zeros between injections period. Fluent deleting the particles with mass less than some limit.
Or you can use "file injection" and create number of injections equal to number of time periods injections. different locations and diameters will be included in injection file. For example: injection-0 duration from 30s to 39s, in injection file will be included 30 locations with different diameters and velosities and massflows. injection-1 duration from 40s to 49s with locations, velosities and massflows etc for new 30 point that included in injection file.
Old   May 22, 2014, 17:11
Marcos
I see.
But I still have to set the time manually for each one of the injections, right?
Thanks again for the help.
Old   May 23, 2014, 04:23
Victor
I see.
In the case of second variant you can create previously all number of time intervals in corresponding number of injections.
I think you'd like to create injection file with time dependance, but i dont know whether it is possible. I wanted to do such for my calculations, but i could not do it. It was necessary for me to create 1 injection with diameter dependent on time. I couldnot find the solution of this.
Old   July 22, 2014, 11:09
Default injection file
  #30
Rupesh Verma
roopesh99 is on a distinguished road
Hi friends, i need your guidance to understand the injection file. My geometry is 3D (10cmX10cmX60cm) and i want to fill 1mm particle up to 21 cm height. But i am unable to understand how to decide about x,y ad z coordinate for making injection file. Also vx,,vy and vz are zero then how we calculate mass flow rate my particle density is 2500kg/cm3.Can any one sent me method or link to write injection file. i mean method for ((x y z u v w diameter temperature mass-flow) name )
my email roopesh99@gmail.com
roopesh99 is offline   Reply With Quote
Old   July 25, 2014, 11:38
Rupesh Verma
Can anyone sand or explain about the method for writing injection file in the following format.
my email: roopesh99@gmail.com
Old   July 25, 2014, 14:31
sescobar is on a distinguished road
Take a look at this previous thread.
http://www.cfd-online.com/Forums/flu...ution-dpm.html
sescobar is offline   Reply With Quote
Old   July 28, 2014, 00:35
  #33
Rupesh Verma
Thanks for reply, I saw this ((x y z u v w diameter temperature mass-flow) name ), but I am unable to understand abt the mass flow rate of which they are trying to write, i mean method for calculating it for injection file. Also method for arranging the particle, Is it side by side.
Old   July 24, 2015, 06:59
Shaheer
Shaheer is on a distinguished road
Hello i have coordinates of multiple particles with their x y z coordinate radius and temperature(they are supposed to be stationary so no mass flow there). I need to input them in a geometry. I am using Ansys 15 at the moment and i was told i could import them as point by the create opition. However there is no temperature there and its not working since the file i have is in excell format and i dont think it can read it very well.
Some help in this would be highly appreciated. I am new in fluent i started working on it last week so a bit basic explanation would be appreciated even more.
Shaheer is offline   Reply With Quote
Old   July 24, 2015, 09:27
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Shaheer,
as I wrote in the other post, you can create an injection file to load your volume.
The injection file must have this format (check in fluent guide!!):
(( x y z U V W particleDia particleTemperature massFlow) injection:0)
x: x coordinate in m
y: y coordinate in m
z: z coordinate in m
U: x velocity in m/s
V: y velocity in m/s
W: z velocity in m/s
particleDIA: particle diameter in m
particleTemperature: particle temperature in K
massFlow: particle mass flow in kg/s
injection:0 --> name of the injection
Now, you have an excel file, not formatted as you want: all you have to do is to automatically format your excel data into a new injection file, so it can be read in fluent. You can program in visual basic, or what you want, or this can be easily done in excel itself.
For example, you have in your excel file, in sheet1:
Column A: x coordinate in m
Column B: y coordinate in m
Column C: z coordinate in m
Column D: temperature in K
Column E (create it): progressive numbers starting from 0, step +1 (so you have E1=0, E2=1, E3=2 and so on).
All your particles have 1 mm diameter.
You set a time step for the transient simulation of 0,01 s.
You set end time of injection at 0,01 s.
Your particles have a density of 1500 kg/m3.
In another sheet of excel you can write in A1 cell:
Take cell values from sheet1
="(( " & A1 & " " & B1 & " " & C1 & " " & "0.0 " & "0.0 " & "0.0 " & "0.001 " & D1 & " " & "0.00007854) " & "injection:" & E1 & ")"
Value of 0.00007854 is derived by:
you have a particle with a volume of 5.24e-10 m3.
Your particle has mass of 7.85e-7 kg
You inject your particle during 0.01 s, from time 0 s to 0.01 s (time step 0.01 s): you are injecting at 0 m/s velocity your particle once (i.e.: you are loading your volume only at the first time step).
0.00007854 = 7.85e-7 / 0.01
Now you have the first string for your first particle.
Now drag down that cell to aoutomatically complete all the remaining strings for all your particles.
Once finished, copy your new sheet2 into a txt file and rename it.
NB: before all, try to inject a single particle to see if it works and check carefully in fluent user guide format of the injection file.
Daniele
wc34071209, soheil_r7, AHF and 4 others like this.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   July 24, 2015, 11:25
Shaheer
Thank you very much for taking your time on this one.
Old   July 30, 2015, 11:00
Shaheer
Hi I did as you said and formed the script using excel in txt file it looks like this
(( -0,98748 -0,00978254 -0,0349822 0 0 0 0.001 773,099 0.00007854) injection:0)(( -0,850535 -0,00640727 -0,0349854 0 0 0 0.001 770,736 0.00007854) injection:1)(( -0,855105 -0,00489111 -0,0353856 0 0 0 0.001 771,4 0.00007854) injection:2)(( -1,03791 -0,0109162 -0,0338131 0 0 0 0.001 772,951 0.00007854) injection:3)
I just tried it for one particle ie made it to .inj with only one particle data and i am getting the following message when i try to see the list
''Particle streams from injection-0:
STREAM ...........................INITIAL VALUES...........................
NO TYP (X) (Y) (Z) (U) (V) (W) (T) (DIAM) (MFLOW)
1 particles not found in injection injection-0
Is there a problem with the format or anything?
Old   July 30, 2015, 12:26
ghost82's Avatar
Rick
Hi Shaheer,
see attached file (extract from zip) I tested on a test case.
The file must be formatted as the attached one, including first line.
In the file I'm injecting 2 particles.
You need to code in excel several strings to reproduce each line, for each particle, then copy to a txt file and finally rename it.
PS: I'm going on holidays now and I will be out for some time. Happy summer to all!
File Type: zip injection.zip (261 Bytes, 242 views)
soheil_r7, Shaheer and Shakib_005 like this.
Old   July 31, 2015, 12:32
ghost82's Avatar
Rick
Remember that in fluent decimal separator is point, so you may need to do a find and replace all commas with points.
Shaheer likes this.
Old   August 5, 2015, 06:13
Shaheer
I really think there should be a tutorial for these things you know!
I tried to access my files with the format but no avail.
I tried to fit in your file and mine but sth didnt click so instead of create injection i read the injections and well in both case it seems i am getting this
//rror: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: name
Importing the following injections:
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: name//
Do you face the same issue ever?
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
