Evaporation appears but condensation doesn't
Like Tree4Likes
Old   July 27, 2016, 06:56
Default Evaporation appears but condensation doesn't
Przemek
gaza is on a distinguished road
Hi everyone,
I implemented Lee model in the following UDF:
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "metric.h"
#include "flow.h"
#include "sg.h"
DEFINE_SOURCE(vap_src, cell, vap_th, dS, eqn)
    real m_dot_v;
    const real T_SAT = 373.0;
    Thread *mix_th, *liq_th;
    mix_th = THREAD_SUPER_THREAD(vap_th);
    vap_th = THREAD_SUB_THREAD(mix_th, 0);
    liq_th = THREAD_SUB_THREAD(mix_th, 1);
    m_dot_v = 0.0;
    if (C_T(cell, mix_th) > T_SAT)
        //Message("Jestem w if vap\n");
        m_dot_v = 0.1*C_R(cell, liq_th)*C_VOF(cell, liq_th)*(C_T(cell, mix_th) - T_SAT)/T_SAT;
        //m_dot_v = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*(C_T(cell, mix_th) - T_SAT) / T_SAT;
        dS[eqn] = 0.0;
        //dS[eqn] = 0.1*C_R(cell, liq_th)*C_VOF(cell, liq_th)/T_SAT;
        //Message("VOF = %f", C_VOF(cell, liq_th), " \n");
        //Message("T = %f", C_T(cell, mix_th), " \n");
        //Message(" m_dot_v = %f%s", m_dot_v, "\n");
    else
        //Message("Jestem w else vap\n");
        m_dot_v = -0.1*C_R(cell, vap_th)*C_VOF(cell, vap_th)*(T_SAT - C_T(cell, mix_th))/T_SAT;
        //m_dot_v = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*(T_SAT - C_T(cell, mix_th)) / T_SAT;
        //dS[eqn] = -0.1*C_R(cell, pri_th)*(T_SAT - C_T(cell, mix_th)) / T_SAT;
        dS[eqn] = 0.0;
        //dS[eqn] = 0.1*C_R(cell, vap_th)*C_VOF(cell, vap_th)/T_SAT;
        //Message("VOF = %f", C_VOF(cell, vap_th), " \n");
    //Message(" M_DOT_v = %f%s", m_dot_v, "\n");
    return m_dot_v;
DEFINE_SOURCE(liq_src, cell, liq_th, dS, eqn)
    real m_dot_l;
    Thread *mix_th, *vap_th;
    mix_th = THREAD_SUPER_THREAD(liq_th);
    m_dot_l = 0.0;
        //Message("Jestem w if liq\n");
        m_dot_l = -0.1*C_R(cell, liq_th)*C_VOF(cell, liq_th)*(C_T(cell, mix_th) - T_SAT)/T_SAT;
        //m_dot_l = -0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*(C_T(cell, mix_th) - T_SAT) / T_SAT;
        dS[eqn] = 0.0; //-0.1*C_R(cell, sec_th)*(C_T(cell, mix_th) - T_SAT) / T_SAT;
        //dS[eqn] = -0.1*C_R(cell, liq_th)*C_VOF(cell, liq_th)/T_SAT;
        //Message(" m_dot_l = %f%s", m_dot_l, "\n");
    else
        //Message("Jestem w else liq\n");
        m_dot_l = 0.1*C_R(cell, vap_th)*C_VOF(cell, vap_th)*(T_SAT - C_T(cell, mix_th))/T_SAT;
        //m_dot_l = 0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*(T_SAT - C_T(cell, mix_th)) / T_SAT;
        dS[eqn] = 0.0;
        //dS[eqn] = -0.1*C_R(cell, vap_th)*C_VOF(cell, vap_th)/T_SAT;
        //("VOF = %f", C_VOF(cell, vap_th), " \n");
    //Message(" M_DOT_l = %f%s", m_dot_l, "\n");
    return m_dot_l;
DEFINE_SOURCE(enrg_src, cell, mix_th, dS, eqn)
    real enrg_dot = 0.0;
    const real LAT_HT = 2200e3;
    Thread *vap_th, *liq_th;
        enrg_dot = -0.1*C_VOF(cell, liq_th)*C_R(cell, liq_th)*LAT_HT*(C_T(cell, mix_th) - T_SAT)/T_SAT;
        dS[eqn] = 0.0;//-0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*LAT_HT / T_SAT;
        //dS[eqn] = -0.1*C_VOF(cell, liq_th)*C_R(cell, liq_th)*LAT_HT/T_SAT;
    else
        enrg_dot = 0.1*C_VOF(cell, vap_th)*C_R(cell, vap_th)*LAT_HT*(T_SAT - C_T(cell, mix_th))/T_SAT;
        dS[eqn] = 0.0;//-0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*LAT_HT / T_SAT;
        //dS[eqn] = -0.1*C_VOF(cell, vap_th)*C_R(cell, vap_th)*LAT_HT/T_SAT;
    return enrg_dot;
UDF compiles and works well. I did two simulations: first with domain filled with water at saturation temperature 373 K and left boundary at T = 398 K. I ran simulation and evaporation appeared (volume phase of water and vapor changed). When I set initial conditions to only vapor in the domain, at sat. tempr. 373 K and boundary condition at right wall at 300 K I haven't noticed any condensation. I do not know why because I checked m_dot_l and m_dot_v in both cases and they are not zero (by uncomment lines in UDF). Is it bug in Fluent?? Can anybody help? I append the case file.
BlnPhoenix, D.M, phong6495 and 1 others like this.
best regards
pblasiak
gaza is offline   Reply With Quote
Old   August 6, 2016, 15:57
Default difficulty in modelling condensation
Nitin
Nitin Minocha is on a distinguished road
Hi
I am using mixture model and using evaporation-condensation model for mass transfer. I am not able to model condensation.
Any help will be greatly appreciated.
Thank You
Nitin Minocha
Nitin Minocha is offline   Reply With Quote
Old   August 8, 2016, 03:14
Przemek
I see that you have the same problem as me
Few other guys on this forum also reported on that
I don't know why it is so
best regards
pblasiak
Old   September 20, 2016, 06:27
Przemek
Hi All,
I found the solution. Fluent 16.2 has a bug. Everything works well in 17.1 version.
best regards
pblasiak
Old   October 18, 2016, 14:02
Abdelhamid Kassem is on a distinguished road
Originally Posted by gaza View Post
Hi All,
Could you upload the working files after fixing the problem because, i still stuck with errors while doing the analysis,and i need it in my bachelor project, and i'm a beginner user of fluent.
My email: Abdelhamidkassem93@gmail.com
Thanks in advance.
Abdelhamid Kassem is offline   Reply With Quote
Old   October 20, 2016, 15:39
Vivek Kumar Mahato
ImVKMahato is on a distinguished road
Hello sir, I m new to heat pipe (wick or wickless ) simulation using UDF.I have done a lot of research but has not been very much fruitful. Could you plz guide me How to do it using UDF. I request you. It is very essential for my project. Thank u
ImVKMahato is offline   Reply With Quote
Old   October 20, 2016, 16:04
Przemek
Hi All
The code in the post #1 is correct. It did not work in Fluent 16 but it works in 17. The is to compile this on linux because windows compiler sometimes does not see the errors.
best regards
pblasiak
Old   October 20, 2016, 16:15
Vivek Kumar Mahato
I have watch few videos on youtube regarding using UDFs n compiling them. However I m not very clear about it. Do you have any suggestion where I can make my concept clear about compiling , running these codes and getting desired results. Thanks for the previous reply.... Regards
Old   October 20, 2016, 16:26
Przemek
read the udf manual ...
best regards
pblasiak
Old   November 1, 2016, 05:05
Vivek Kumar Mahato
I have been reading UDF manual for quiet a few days now...Could you advice or suggest something which can help me move ahead in my work in simulation. I donot have much knowledge about the various models eg. Lee model etc..
Old   November 2, 2016, 07:46
Przemek
The udf is in post #1
You have to compile it and hook the udf into your simulation.
The tutorial on that is film boiling
https://www.google.pl/url?sa=t&rct=j...ci9r3Q&cad=rja
best regards
pblasiak
Old   November 2, 2016, 09:36
Vivek Kumar Mahato
Thankful for the tutorial you provided .. Leme try it and i will let you know if i have some problem.. Thank you again.. Regards
Old   November 3, 2016, 00:45
Vivek Kumar Mahato
Could you email me the files mentioned in the tutorial test-2d.msh and boiling.c? i could not find them ..thanks
Old   November 3, 2016, 00:49
Vivek Kumar Mahato
VOF multiphase model too..if u have..
Old   December 21, 2016, 12:20
Default Heat Pipe
  #15
Reza
Rezaa is on a distinguished road
Hi everyone. I am new in the two-phase flow and heat pipe field and I should simulate a wicked heat pipe by OpenFoam. It is appreciated if anyone can help me ... Thanks
Rezaa is offline   Reply With Quote
Old   January 10, 2017, 09:07
manan
manan13 is on a distinguished road
Increase condensation frequency
manan13 is offline   Reply With Quote
Old   January 20, 2017, 06:29
Przemek
Hi All
Hi
sorry I was wrong. It also does not work in fluent 17. I got evaporation and condensation but also artificial condensation at the liquid-vapor interface. I do not know how to solve it.
best regards
pblasiak
Old   September 19, 2017, 22:50
phong6495
phong6495 is on a distinguished road
Hi gazza, you uses VOF models or mixture model????
phong6495 is offline   Reply With Quote
Old   September 20, 2017, 03:23
Przemek
I used VOF model
best regards
pblasiak
Old   September 20, 2017, 09:00
phong6495
Thanks gazza. I'm also simulating evaporation, condensation with thermosyphon. With condensation, your boundary conditions like? Are the heat transfer coefficients used?
Thanks!!!!
Evaporation and condensation model in VOF ic3lemon Fluent Multiphase 0 December 12, 2015 07:56
Evaporation & condensation in 2D Heat Exchanger Somnath rangrej Main CFD Forum 0 December 8, 2015 12:25
Evaporation and condensation Model in Fluent amy24d Fluent Multiphase 5 May 26, 2015 13:20
Evaporation & Condensation model Amit FLUENT 0 September 7, 2012 07:53
evaporation and condensation in the VOF model Glev FLUENT 0 December 24, 2004 05:55
