Fluctuating residuals!
Old   January 8, 2016, 13:39
Default Fluctuating residuals!
cglr
wales is on a distinguished road
I have been in trouble throughout days with converging and have to turn something reasonable in to my advisor. So I need urgent help of you.
Attached, you can see mY very simple model. Its a 40mmx2000mmx4000mm flow region. The blue regions (two side) have an air inlet velocity of 7 m/s and temperature of 298K. Red faces are representing pressure outlet. And white ones are walls which have higher temperature than air.(350K). Simply put, its a narrow duct flow and will naturally have natural convection too.
I need to observe heat transfer rate at the walls. I used hexahedral mesh and applied 10 inflation layer to each wall with a first cell height of 0.1 mm whereby I would be able to get a y+ about 1. Mesh report has no problem. I have about 9 million nodes and elements.
I first resolved it without energy equation using SST. After 1000 iterations, I turned it on and resolved it again for 1000 iterations using SST with the effect of boussinesq density air and the gravity. I chose second order for momentum and energy and presto for pressure. I set under rel. factor for momentum,k and energy at 0.5 0.5,0.9 respectively.
As a result, residuals still fluctuating and going up. What may be wrong? May it be a possible factor that inlet faces are adjacent to outlet faces?
Your comments is very precious for me. Im in deadline times.
I can also share my mesh file. Thank you.
wales is offline   Reply With Quote
Old   January 11, 2016, 10:50
cglr
At least any idea would help, no one faced such a converge problem ?
in the console, it says reversed flow for each iteration. Can it lead a converge problem ? My results seem sensible neverthless.
Old   January 12, 2016, 03:34
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Considering you set up all the parameters correctly, I would switch to unsteady simulation to get a quasi steady state solution.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Fluctuating residuals for all the parameters jhssyb FLUENT 0 January 7, 2016 22:12
Fluctuating residuals tichaona Main CFD Forum 1 February 7, 2012 15:49
Multi body part and fluctuating residuals tichaona Main CFD Forum 0 February 7, 2012 14:09
Fluctuating residuals in transient simulation (transientSimpleFoam) robingilbert OpenFOAM 1 November 17, 2011 20:36
pls help fluctuating residuals due to courant no sagar CFX 3 March 28, 2006 02:10
