udf unsteady flow.
Old   March 28, 2015, 22:54
Default udf unsteady flow.
elliot ward
elliot is on a distinguished road
Hi all first time poster here so i'l keep it short and sweet.
Im trying to write a udf for a unsteady flow that varies with time step on a pipe in 2d, (I am having great difficulty). I have written a udf (below), however when I run it in fluent it only runs the last velocity and misses out the rest. Can anyone spot my mistake/s? Any help would be much appreciated.
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND];
real y;
real t = RP_Get_Real("physical-time-step");
face_t f;
begin_f_loop(f, thread)
{if (t<=10);
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = 1;
{if (t<=11 && t>10);
y = x[1];
F_PROFILE(f, thread, position) = 0.5;
{if (t<=12 && t>11);
y = x[1];
F_PROFILE(f, thread, position) = 3;
{if (t<=13 && t>12);
y = x[1];
if (y<=7)
F_PROFILE(f, thread, position) = 9;
if (t<=14 && t>13);
y = x[1];
F_PROFILE(f, thread, position) = 5;
end_f_loop(f, thread)
Last edited by elliot; March 28, 2015 at 23:03. Reason: needs to be in udf & scheming
elliot is offline   Reply With Quote
Old   March 28, 2015, 23:13
`e`
`e` is on a distinguished road
First, use tabs and spaces to make your code easier to read. I've tried to make sense of your code but the brackets don't seem to match; does this code compile?
Second, I don't think those if statements are doing what you're intending, have a read of this tutorial on loops in C.
`e` is offline   Reply With Quote
Old   March 28, 2015, 23:26
`e`
Here's an example of your first two cases:
	y = x[1];
	if (t<=10.)
		F_PROFILE(f, thread, position) = 1.;
	else if (t<=11.)
Comments:
  • F_CENTROID is called, and y is evaluated, only once per loop through the faces
  • if/else statements are used to distinguish velocity values with time
  • trailing periods on integers to treat them as real numbers (good coding practice)
  • correct brackets and spacing makes the code easier to read
Old   March 28, 2015, 23:55
elliot ward
Hi thanks for the reply, yes i can interpret the udf, and have made the recommend changes however fluent still only runs the last velocity profile. Is there anything else you can suggest?
Also sorry for the poor code formatting, and the double posting
Old   March 29, 2015, 00:02
`e`
We don't know what your UDF looks like after you've made my recommended changes, can you post the new version?
Old   March 29, 2015, 00:10
elliot ward
Sorry, i did tab it but it has reformatted in the post. also i exclude the else term as the caused a parse error,
#include "udf.h"
real x[ND_ND];
real y;
face_t f;
if (t<=1.);
y = x[1];
if (t<=2.);
y = x[1];
if (t<=3.);
y = x[1];
if (t<=4.);
y = x[1];
if (y<=7)
if (t<=5.);
y = x[1];
Cheers
Old   March 29, 2015, 00:11
elliot ward
Old   March 29, 2015, 00:39
`e`
You can use the [CODE] tags for inserting code into posts (retaining the tabs/spacing).
As for your code, again, I recommend you reading this page on if loops because your incorrect usage of the if statements is causing your velocity profile to be defined by your last case.
Have a think about what velocity is applied to which face and at which time because currently they're not defined for t > 5 s and for y > 7 m at t <= 4 s.
Old   March 29, 2015, 01:06
elliot ward
First thanks for spending your time trying to help me. Is this code the correct format for a change in velocity with time step rather than time? also i have tried this variation, still with no luck.
#include "udf.h"
    real x[ND_ND];
    real y;
    face_t f;
    if (t==1.);
        y = x[1];
    if (t==2.);
     if (t==3.);
    if (t==4.);
    if (y<=7)
    if (t==5.);
Old   March 29, 2015, 01:33
`e`
No worries.
You're still missing the if statement problem so I'll be specific: the semicolon is used to terminate a statement in C, and you've used this semicolon immediately after you've provided the condition of said statement. The second problem with your if statements is that you've not included curly brackets to include multiple lines of code.
Problem 1:
if (t==3.); // if t is equal to 3, then do nothing extra
    F_CENTROID(x,f,thread); // this line is read regardless of whether t==3. or not
    F_PROFILE(f, thread, position) = 3; // same as the line above
Problem 2:
if (t==2.) // correct if statement but only the next line is included
    F_CENTROID(x,f,thread); // this line is read if t==2.
    F_PROFILE(f, thread, position) = 0.5; // this line is always read
Fixed code:
if (t==2.)
The RP variable macro, RP_Get_Real("physical-time-step"), gives the current physical time step size (in seconds). If you were after the integer number of time steps, then you could directly access this value with the solver macro N_TIME, or indirectly access with the equivalent RP variable macro RP_Get_Integer("time-step").
Old   March 29, 2015, 01:39
`e`
Also, you're missing a starting curly bracket for begin_f_loop.
What velocities are you trying to define (provide both time and position in your descriptions)? I still don't think your logic with the if statements is quite right.
Old   March 29, 2015, 03:43
elliot ward
Cheers mate, its working now. Your a god send. Sorry it took so long for me to get there.
Old   March 29, 2015, 03:52
`e`
Awesome, thanks, glad to hear it's working!
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
Unsteady interna flow yhoarau OpenFOAM Running, Solving & CFD 2 June 5, 2012 11:42
Unsteady flow and DPM moloykb FLUENT 5 March 21, 2012 04:28
unsteady UDF Sukanta Bhattacharjee FLUENT 0 August 20, 2007 12:11
a UDF for unsteady flow mike FLUENT 0 August 7, 2007 09:06
