how to use PRF_CSEND/PRF_CRECV to replace host_to_node? |
June 13, 2016, 12:36 |
liuyan
Rep Power: 13 |
my variables difine in udf,
real rsec[10][20]; /*Normalizes radius from GUI*/ real csec[10][20]; real twst[10][20]; /*Twist*/ char type[10][20][30]; /*Profile type name */ int fzon[10]; /*Rotor face zone ID*/ int nsec[10]; /*Number of blade sections along span*/ i need to transfer data from host to node,One-dimensional array fzon and nsec can use host_to_node to tranfer data,for example host_to_node_int(fzon,10),host_to_node_int(nsec,10 ), but the two-dimensional array and three-dimension array can be not. In UDF manul,this description is that, "Note that the higher-level communication macros expand to functions that perform a number of lowerlevel message passing operations which send sections of data as single arrays from one process to another process. These lower-level message passing macros can be easily identified in the macro name by the characters SEND and RECV. Macros that are used to send data to processes have the prefix PRF_CSEND, whereas macros that are used to receive data from processes have the prefix PRF_CRECV. Data that is to be sent or received can belong to the following data types: character (CHAR), integer(INT), REAL and logical (BOOLEAN). BOOLEAN variables are TRUE or FALSE. REAL variables are assigned as float data types when running a single precision version of ANSYS Fluent and double when running double precision. Message passing macros are defined in the prf.h header file and are listed below. /* message passing macros */ PRF_CSEND_CHAR(to, buffer, nelem, tag) PRF_CRECV_CHAR (from, buffer, nelem, tag). There are four arguments to the message-passing macros. For ‘send’ messages: • to is the node ID of the process that data is being sent to. • buffer is the name of an array of the appropriate type that will be sent. • nelem is the number of elements in the array. • tag is a user-defined message tag. The tag convention is to use myid when sending messages." I dont know how to use PRF_CSEND or PRF_CRECV macros?Does anyone can tell me how to use PRF macro transfer two dimension or three dimension array variables from host to node? Thanks! |
June 13, 2016, 19:29 |
Rep Power: 18 |
The example on "Message Passing" in the UDF manual explains how to send and receive arbitrary sized arrays between compute nodes. You should be able to use the same logic with exchanging with node_host as well.
June 18, 2016, 22:12 |
liuyan
Rep Power: 13 |
Thanks for your reply,i will read the mannual about the message pass.
June 18, 2016, 22:13 |
liuyan
Rep Power: 13 |
Thanks for your reply,i will read the mannual about the message passing example.
UDF to replace mesh | siamak1438 | FLUENT | 0 | March 26, 2015 03:58 |
[ICEM] replace geometry | kmgraju | ANSYS Meshing & Geometry | 1 | January 5, 2015 10:59 |
Running out of UDMI, what can in use to replace it ? | Sdvk | Fluent UDF and Scheme Programming | 0 | May 23, 2014 14:16 |
Replace H equation with Teqn in chtMultiregionFoam OF 2.3 | Moncef | OpenFOAM Running, Solving & CFD | 0 | May 22, 2014 21:37 |
run f;uent job in batch mode? | jx | FLUENT | 5 | July 2, 2003 12:29 |
