Error interpolating results onto the new mesh
Like Tree1Likes
Old   September 24, 2009, 22:18
Default Error interpolating results onto the new mesh
^_^
Jasmine is on a distinguished road
I got this error when an result file was used as intitial values file. Can anybody help me figure it out? THanks a lot
Details of error:-
Details of error:-
Error detected by routine MAKDAT
CDANAM = BBMID CDTYPE = REAL ISIZE = 7651833
CRESLT = FULL
CRESLT = FULL
Current Directory : /INTERP/OLD1/MESH/TSTEP0/CLOOP0/ZN1/ELEMENT_TREE
| ****** PROBLEM REPORT ****** |
| Subsystem: Input |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: |
| /usr/ansys_inc/v110/CFX/bin/linux-amd64//solver-pvm.exe exited |
| with return code 1. |
Jasmine is offline   Reply With Quote
Old   September 25, 2009, 07:53
My guess is you have run out of memory. Try it on a machine with more memory, or look at the interpolator memory settings in the documentation to use less memory.
Old   September 25, 2009, 14:23
^_^
Yes. It works now!
Thanks ghorrocks~~
Old   May 26, 2014, 01:48
Default Similar kind of error
george
gorge is on a distinguished road
Error interpolating results onto the new mesh: C:\Program |
| Files\ANSYS Inc\v145\CFX\bin\winnt\solver-pcmpi.exe exited with |
| return code 1
But this doesnt work when I run it on a machine with higher memory..
gorge is offline   Reply With Quote
Old   April 1, 2015, 04:25
MarkoP is on a distinguished road
I have the same problem. I don't know how the memory would be a problem since I am running the simulation on:
Intel i7-4770, 3.4GHz and 16GB RAM
Any ideas?
MarkoP is offline   Reply With Quote
Old   April 1, 2015, 04:54
By the way, I have this error as well:
Details of error:-
Illegal data area length CDANAM = NTOTALS_EST CDTYPE = INTR ISIZE = 0
CRESLT = SIZE
Current Directory : /INTERP/NEW/NAMEMAP
Could it be that the problem is with the number of nodes? I have an Academic License and around 2M nodes. I guess that the limit is 512K
Old   May 2, 2017, 16:01
Azeez Ali
azeezjabbar is on a distinguished road
hey i have the same problem plz help? is memory is the issue?
Originally Posted by Jasmine View Post
Yes. It works now!
Thanks ghorrocks~~
azeezjabbar is offline   Reply With Quote
Old   November 18, 2017, 00:54
Default Error: exited with return code1
Kaythi
Kaythi is on a distinguished road
I am facing this problem while I am simulating water flow of turbine. Can anyone help me? Error interpolating results onto the new mesh: C:\Program Files\ANSYS
Inc\v162\CFX\bin\winnt-amd64\double\solver-pcmpi.exe exited with return
code 1.
Kaythi is offline   Reply With Quote
Old   November 18, 2017, 06:17
The most likely cause is you have run out of memory. If that is not the case then give more details on what you are doing.
Old   July 7, 2018, 14:07
Enrico Crobu
EnricoCrobu is on a distinguished road
same error happens to me:
Error interpolating results onto the new mesh: D:\ANSYS
Inc\v182\CFX\bin\winnt-amd64\solver-mpi.exe exited with return code 1.
I am trying to use DOE and Response Surface Optimisation, and all DPs fail with same error.
I am running the solver using RSM.
Is it a mesh interpolation memory issue?
Many thanks
EnricoCrobu is offline   Reply With Quote
Old   July 8, 2018, 07:40
It could be that you are running out of memory. You would have to provide more details of what you are doing before we could help more.
EnricoCrobu likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 9, 2018, 16:04
Enrico Crobu
Ghorrocks, I am running an optimisation case, using CFX and Workbench.
Everything goes well when I run (local) the initial case to generate the required output condition for the optimisation.
When i then add the Response Surface Optimisation module and run the generated DP cases using RSM, everything fails.
I believe the problem is the Solver looking for the IBM MPI Distributed Parallel instead of the Intel MPI Distributed Parallel, but that may just be a secondary problem.
any similar experience anybody?
Old   August 7, 2018, 13:14
Enrico Crobu
Solution found to this.
Problem was indeed the required Catalogue Size around 3.5K during the interpolation phase of the solver.
Execution Control > Interpolator >Interpolator Memory > Catalogue Size > 4x
This fixed it in my case, calculation now running smoothly
Thanks
Old   November 12, 2018, 13:02
sadhana m bhat
Sadhana m bhat is on a distinguished road
hey!!
i am also facing the same problem of "interpolating onto new mesh" while solving for an impeller model.
And have tried all those which others have suggested to,but still stuck with the same error.
please helpp!!
Sadhana m bhat is offline   Reply With Quote
Old   November 12, 2018, 16:53
Have a look in the documentation about the initial conditions interpolation routine. It has a few memory settings available, so adjusting some of those settings might help.
Old   November 12, 2018, 20:50
sadhana m bhat
Ok thank you!!
Will try this out
Old   November 15, 2018, 01:21
sadhana m bhat
Can I couple the data of CFX analysis done on one impeller model to the stress analysis done on a another impeller model similar to it but is dimensionally slightly different?
Old   November 15, 2018, 01:24
It will map the forces (from pressure and wall shear) onto the surface for the FEA, so the surface will have to match good enough for the mapping/interpolation to work.
Old   November 15, 2018, 01:29
sadhana m bhat
Okay thank you
Old   November 15, 2018, 01:30
sadhana m bhat
What exactly is interpolating results on mesh?
Can tell me brief..
why dynamic mesh method give wrong results? weiyang1980 Main CFD Forum 0 September 22, 2009 22:06
[OpenFOAM] 'integrate variables' filter on a polyhedral mesh gives wrong results... jbf ParaView 0 September 4, 2009 05:08
Restart Deforming Mesh Calculation Tristan CFX 0 June 22, 2009 19:34
Mesh Refinement JY Siemens 7 September 19, 2002 14:37
