attack angle in CFX
Old   November 26, 2008, 10:20
Default attack angle in CFX
anne
we all know that there are tow ways to consider attack angle in CFX simulation:
method 1: rotate geometry and remesh
method 2: modify inlet velocity components, as well as in intialization conditions.
however, in my case (I tried both of them), only method 2 works. method 1 can be run, but after I finish the running, i can't get all of the results (only part of them), i.e. i can't save the results correctly.
it doesn't make any sense, does it?
do your guys have any comments on it? a new bug? or i did sth wrong?
any comments are welcome
many thanks
anne
Old   November 27, 2008, 10:15
Default Re: attack angle in CFX
CycLone
Method 1 will work if you have done the geometry steps properly. Make sure you are rotating only the part of interest (presumably an airfoil or aircraft?) and if you did some kind of enclosure operation or boolean to create the fluid volume, you need to insert the rotation ahead of this operation, otherwise the fluid region will be unaffected.
There are a few other alternatives:
3. Rotate the geometry within CFX using the moving mesh capability. If you do this, you'll need to solve the mesh motion equations, so you may want to do a few iterations to move the geometry then restart with mesh motion turned off.
4. Place your body within a cylindrical or spherical domain and rotate the grid surrounding the body by using a mesh transformation in CFX-Pre.
5. Place you body with a cylindrical or spherical domain and apply a "frozen rotor" interface between the domains. The frozen rotor interface is only available if you have rotating frames of reference, but you can still use it for stationary domains. If you apply it, make sure the axis of rotation is aligned with the axis of your sphere or cylinder. The Frozen Rotor interface allows you to specify a clocking angle, which is normally used to examine the effect of grid alignment between rotors and stators. Rather than rotating the grid, the solver will offset the "virtual" alignment of faces at the interface, but the effect is the same.
6. Use the grid motion as in 2, but apply it to a cylindrical or spherical domain.
The advantage to doing this at the solver level is that you can write a CEL expression to clock the angle to achieve the desired CL on the fly.
-CycLone
Old   November 28, 2008, 08:50
anne
thanks, cyclone.
however, what about if I only rotate the geometry, and then modify the mesh a little (the mesh around the body is a cylindrical mesh), like reprojet some points, etc in order to make sure the mesh quality is still good. is that OK? actually that's what I have done, running can be started, but I can't save the results correctly. what do you think about this?
many thanks
Old   November 28, 2008, 12:11
CycLone
Where are you rotating it? In what application and how?
Old   December 2, 2008, 07:42
anne
it's nacelle application, let's assume flow direction is x-axis, so I rotate it along y or z and make it incline an angle with x-axis, which is the attack angle or side angle.
so what do you think
Old   December 2, 2008, 11:13
CycLone
Are you only rotating the nacelle?
Old   December 4, 2008, 10:55
anne
yes, then remesh around the nacelle.
Old   December 5, 2008, 00:12
CycLone
Why would you remesh around the nacelle only?
Old   December 12, 2008, 13:00
anne
because there is o-grid around nacelle. outside o-grid there is no big change because of the small attack angle
Old   December 16, 2008, 21:33
CycLone
How's the grid quality? Why just remesh locally?
Old   December 17, 2008, 14:31
  #11
anne
mesh quality is good, above 0.35, and it is a structured mesh, no need to change the far field area, anyway, many thanks for your points
Getting lift force at zero angle of attack Shamoon Jamshed FLUENT 14 September 5, 2012 00:16
when the angle of attack =?, the total lift coefficient begin to decrease suddenly liujmljm Main CFD Forum 6 August 3, 2012 06:46
[ICEM] Angle of Attack wolvi_ak ANSYS Meshing & Geometry 8 August 5, 2011 10:31
how to plot attack angle along with impeller span direction at leading edge wildli FLUENT 0 August 31, 2010 15:47
Angle measurement in CFX sham CFX 0 September 2, 2006 01:26
