Stop and Restart Solver
Old   February 17, 2016, 07:30
Default Stop and Restart Solver
re
rere is on a distinguished road
Hiya
How do I stop and restart a solver?
Working on 1000 iterations and waiting for graph to show convergence, which is all taking so much time!
Thanks
rere is offline   Reply With Quote
Old   February 17, 2016, 11:34
Maxim
-Maxim- is on a distinguished road
hit the stop button in solver manager and wait until the current time step is finished and the result file (*.res) is written to your hard drive.
to restart, select the result file from the stopped calculation as "Initial Values".
-Maxim- is offline   Reply With Quote
Old   February 17, 2016, 12:14
Opaque will become famous soon enough
or press the Continue arrow on the Solver Manager toolbar.
Opaque is offline   Reply With Quote
Old   February 17, 2016, 12:24
re
okay, once I've closed and exited Ansys....what are the exact steps to restart?
Ta
Old   February 18, 2016, 03:11
Maxim
http://lmgtfy.com/?q=restart+solver+run+cfx
the second link leads to
ANSYS CFX-Solver Manager User's Guide
You press ctrl+f and search for 'restart'.
Old   February 18, 2016, 05:07
re
I had tried this with a previous simulation but the iteration count mentioned on the screen and the graph didn't match. The graph was showing UPTO 80 iterations and the solver had reached 321 at the time.
Old   February 18, 2016, 06:03
Maxim
I would guess you had your graph set to display 'this run only' or some fixed number of iterations and the out file showed the total number of iterations. It usually shows 'number of iterations of THIS run' in () right below it.
Old   February 18, 2016, 07:09
re
In the Solver Control, I had iterations fixed --> min:1 and max: 1000 iterations, but I'd stopped it at 80 and when I attempted restart, it only showed the graph at 80 (not beyond) - however, the iteration continued. So, the graph and solver were not in sync
Old   February 18, 2016, 07:15
Maxim
can you provide screenshots of that? And the settings of the monitors? I am sure that this is just a problem with the settings of the monitors and/or the monitored variables.
Old   February 18, 2016, 08:54
re
This is another simulation, that hasn't yet been stopped but it shows you the graph to the left and the solving on the right.
The stopped simulation doesn't show that both are in sync (can't open that simulation, i DAREN'T STOP THIS ONE).
Regarding the settings (again, can't take screenshots) but these are the only steps:
Setup > Insert > Solver > Solver Control > Basic Settings > Convergence control > Maximum Iterations > 1000 > Convergence Criteria > Residual Target > 1e-5 > Apply > Close
File Type: jpg Screen Shot 2016-02-18 at 12.49.06.jpg (158.6 KB, 16 views)
Old   February 18, 2016, 09:04
Maxim
I am not talking about your convergence control settings, I am talking about the monitor settings. Right-click on the monitor (graph) and go to 'monitor properties'.
Old   February 18, 2016, 09:26
re
Please see attached
Old   February 18, 2016, 09:28
Maxim
yeah, that would now be interesting for the monitors that were/are 'out of sync'. Take your time, finish your current simulation and then try to restart the other one again and check if your sync problem still exists.
Old   March 3, 2016, 05:53
re
still exists.
Old   March 3, 2016, 06:04
Maxim
some more information would be nice.
Which setting did you use in the define run - initial values window?
Strange rhoCentralFoam behavior after restart... vkrastev OpenFOAM Bugs 27 November 19, 2013 13:04
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
functionObject Probe: it's possible to stop and restart? ivan_cozza OpenFOAM Post-Processing 0 September 28, 2010 05:42
ReactingFoam solver restart gcollecutt OpenFOAM Running, Solving & CFD 0 August 9, 2007 06:30
UDF:How stop and restart particle tracking? Adriano FLUENT 2 May 31, 2006 13:14
