Cp(theta) of 2D laminar circular cylinder flow
Old   May 12, 2015, 15:57
Default Cp(theta) of 2D laminar circular cylinder flow
M S
Michael_x is on a distinguished road
Dear all,
I have a question concerning the Cp(theta) of a 2D cylinder flow at Re=150 and Ma=0.2 (see picture attached).
What I do not understand is: at theta=0 deg Cp should be 1 but in my simulation it is 1.04. Where can these 0.04 come from?
I am doing a compressible calculation (Thermal Energy) with Air Ideal Gas.
Thanks in advance,
Michael
Michael_x is offline   Reply With Quote
Old   May 12, 2015, 19:23
4% error is pretty close in most cases. But if you want to be more accurate have a look at the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   May 25, 2015, 10:52
M S
Thanks for the answer.
I am using the fourth order backwards Euler scheme in time and the high resolution scheme in space so I am wondering if the error should not be smaller?
The same problem has been calculated with scientif CFD softwares, too, and people used to get errors smaller than 1% (time scheme: runge kutte 4th order accurate, space scheme: central differences 4th order accurate).
Do you guys expect such big errors using CFX (lower formal accuracy in advection scheme)?
Thanks in advance and greetings,
Michael
Old   May 25, 2015, 21:01
CFX is capable of very high accuracy - you are not limited by the software for how accurate you can go in most cases. The usual limitations of accuracy are the correct choice of physics options, development of a suitable mesh, time and convergence criteria and a computer big enough to run it. So the limitation is the ability of the user to do all these things properly, not the software.
convergence issue flow around circular cylinder SB123 STAR-CCM+ 1 December 13, 2014 16:18
Flow over 2D Cylinder, Laminar and Turbulent Tsr63 FLUENT 5 November 13, 2014 13:13
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
asking about wake in Inviscid flow in cylinder circular teguhtf FLUENT 0 April 23, 2011 01:14
Modeling flow acros circular cylinder Zhihua Main CFD Forum 3 April 20, 2004 12:16
