Setup a case by commanding in Matlab
Old   March 22, 2014, 14:07
Default Setup a case by commanding in Matlab
Henry Arrigo
Henry Arrigo is on a distinguished road
Hi all;
I have a .msh file and I want to setup a .cfx file from that through programming in MATLAB. How is it possible?
I thought recording a session could be the solution but I don t know how to play that session from MATLAB.
Thanks
Henry Arrigo is offline   Reply With Quote
Old   March 23, 2014, 05:24
I am no matlab expert, but I am sure matlab can call command line executables. So then you can do it like any other script file called from the command line - it is just the command line was called from matlab, not the command line (or a batch/shell file).
Old   March 23, 2014, 06:37
Henry Arrigo
Thanks Glenn
I could play it with -session. But only on the command line. I still have trouble doing it from MATLAB. Thank you anyway.
btw how shell does work?
Old   March 23, 2014, 06:42
Batch files are MS windows, shell scripts are linux.
If it runs from the command line but not from matlab then it sounds like your problem is with matlab, not CFX.
dynamicMesh case setup simpleton questions tellico OpenFOAM Pre-Processing 2 January 17, 2014 13:41
Numerical error or case error? Flow in a 3D pipe fsalvucci OpenFOAM 40 January 30, 2013 08:10
How to repeat to read the same case without saving case and data file? lcg44 Fluent UDF and Scheme Programming 4 November 22, 2012 11:45
OpenFOAM case setup and work flow - what are you using? Arnoldinho OpenFOAM Pre-Processing 4 July 18, 2010 10:16
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
