A problem about density in liquid air definition |
October 28, 2013, 10:41 |
Rep Power: 17 |
I want to carry out a numerical simulation about an cryogenic liquid turbine which used the liquefied air as the working fluid.
Here i have to define a new material: liquid air at 95-105K, pressure:0.6-7MPa There is a problem:when the density is set to a constant value or values dependent on pressure or Temperature,the solver can simulate it. But if it is set to a function related to p and T, the solver make errors. ----------------- the density definition is: fluidairdensity(T,pabs,0) ----------------- the error shows: Fatal bounds error detected --------------------------- Variable: Density Derivative wrt Pressure at Constant Temperature Locale : R1 ----------------- I think the definition is right but I can't find where is wrong. Thanks for any help. And I will be very gratitude if you give me more information. I am really need you help!! |
October 28, 2013, 17:53 |
Rep Power: 144 |
Debugging material properties is always tricky. But you have to look into the error message - it says your "density derivative wrt P at constant T is out of bounds", which means either a divide by zero or a badly behaved function at this condition.
I have had to deliberately distort material property curves at certain critical points so the derivative of the function remains bounded for all combinations. This is one way to get around this error, but obviously distorts the material properties a bit. |
October 28, 2013, 21:51 |
Rep Power: 17 |
ghorrocks,
Thanks for your help. I quite agree with you about that, and i tried to simply the density data as follows: P T 0 density 0.51 94 0 723.81 0.52 94 0 723.86 0.53 94 0 723.91 0.54 94 0 723.96 0.55 94 0 724.01 0.56 94 0 724.05 0.57 94 0 724.1 0.58 94 0 724.15 0.59 94 0 724.2 0.6 94 0 724.25 0.61 94 0 724.29 0.62 94 0 724.34 0.63 94 0 724.39 0.64 94 0 724.44 0.65 94 0 724.48 0.66 94 0 724.53 0.67 94 0 724.58 0.68 94 0 724.63 0.69 94 0 724.67 0.7 94 0 724.72 0.71 94 0 724.77 0.72 94 0 724.82 0.73 94 0 724.86 0.74 94 0 724.91 0.75 94 0 724.96 0.76 94 0 725.01 0.77 94 0 725.05 0.78 94 0 725.1 0.79 94 0 725.15 0.8 94 0 725.2 0.81 94 0 725.24 0.82 94 0 725.29 0.83 94 0 725.34 0.84 94 0 725.38 0.85 94 0 725.43 0.86 94 0 725.48 0.87 94 0 725.53 0.88 94 0 725.57 0.89 94 0 725.62 0.9 94 0 725.67 0.91 94 0 725.71 0.92 94 0 725.76 0.93 94 0 725.81 0.94 94 0 725.85 0.95 94 0 725.9 0.96 94 0 725.95 0.97 94 0 725.99 0.98 94 0 726.04 0.99 94 0 726.09 1 94 0 726.13 1.01 94 0 726.18 1.02 94 0 726.23 1.03 94 0 726.27 1.04 94 0 726.32 1.05 94 0 726.37 1.06 94 0 726.41 1.07 94 0 726.46 1.08 94 0 726.51 1.09 94 0 726.55 1.1 94 0 726.6 1.11 94 0 726.65 1.12 94 0 726.69 1.13 94 0 726.74 1.14 94 0 726.78 1.15 94 0 726.83 1.16 94 0 726.88 1.17 94 0 726.92 1.18 94 0 726.97 1.19 94 0 727.02 1.2 94 0 727.06 1.21 94 0 727.11 1.22 94 0 727.15 1.23 94 0 727.2 1.24 94 0 727.25 1.25 94 0 727.29 1.26 94 0 727.34 1.27 94 0 727.38 1.28 94 0 727.43 1.29 94 0 727.48 1.3 94 0 727.52 1.31 94 0 727.57 1.32 94 0 727.61 1.33 94 0 727.66 1.34 94 0 727.7 1.35 94 0 727.75 1.36 94 0 727.8 1.37 94 0 727.84 1.38 94 0 727.89 1.39 94 0 727.93 1.4 94 0 727.98 1.41 94 0 728.02 1.42 94 0 728.07 1.43 94 0 728.11 1.44 94 0 728.16 1.45 94 0 728.21 1.46 94 0 728.25 1.47 94 0 728.3 1.48 94 0 728.34 1.49 94 0 728.39 1.5 94 0 728.43 But the error still occurs in the same way: Fatal bounds error detected --------------------------- Variable: Density Derivative wrt Pressure at Constant Temperature Locale : R1 I think the "density derivative wrt P at constant T" is d(density)/dP at constant T, and it is used to calculate the total differential of d(x+dx,y+dy), x=pressure, y=temperature. Similarly, the d(density)/dT at constant P is also needed, that is why we should import these data for FLUENT User-Defined Real Gas Model. I also read the post named "Bounds error for an EOS specified via an interpolation table" in CFD online. http://www.cfd-online.com/Forums/cfx...ion-table.html The poster met the same problem, but he just reordered the table so that pressure varies first then temperature in the table. The problem was solved. I tried but failed. Part of the CFX Command Language for Run is as follows: LIBRARY: CEL: EXPRESSIONS: liquidcp = lcp(T,pabs,0) liquidk = lk(T,pabs,0) liquidrou = lrou(pabs,T,0) liquidvis = lvis(T,pabs,0) mfr = massFlow()@V1 Inlet + massFlow()@e1 outlet + massFlow()@G2 outlet sat = sattable(T) ten = tentable(T) vaporcp = vcp(T,pabs,0) vapork = vk(T,pabs,0) vaporrou = vrou(pabs,T,0) vaporvis = vvis(T,pabs,0) END FUNCTION: lrou Argument Units = MPa,K,[] Option = Interpolation Result Units = kg m^-3 INTERPOLATION DATA: Data = \ 0.51,94,0,723.81,0.52,94,0,723.86,0.53,94,0,723.91 ,0.54,94,0,723.96\ ,0.55,94,0,724.01,0.56,94,0,724.05,0.57,94,0,724.1 ,0.58,94,0,724.15\ ,0.59,94,0,724.2,0.6,94,0,724.25,0.61,94,0,724.29, 0.62,94,0,724.34,\ 0.63,94,0,724.39,0.64,94,0,724.44,0.65,94,0,724.48 ,0.66,94,0,724.53\ ,0.67,94,0,724.58,0.68,94,0,724.63,0.69,94,0,724.6 7,0.7,94,0,724.72\ ,0.71,94,0,724.77,0.72,94,0,724.82,0.73,94,0,724.8 6,0.74,94,0,724.9\ 1,0.75,94,0,724.96,0.76,94,0,725.01,0.77,94,0,725. 05,0.78,94,0,725.\ 1,0.79,94,0,725.15,0.8,94,0,725.2,0.81,94,0,725.24 ,0.82,94,0,725.29\ ,0.83,94,0,725.34,0.84,94,0,725.38,0.85,94,0,725.4 3,0.86,94,0,725.4\ 8,0.87,94,0,725.53,0.88,94,0,725.57,0.89,94,0,725. 62,0.9,94,0,725.6\ 7,0.91,94,0,725.71,0.92,94,0,725.76,0.93,94,0,725. 81,0.94,94,0,725.\ 85,0.95,94,0,725.9,0.96,94,0,725.95,0.97,94,0,725. 99,0.98,94,0,726.\ 04,0.99,94,0,726.09,1,94,0,726.13,1.01,94,0,726.18 ,1.02,94,0,726.23\ ,1.03,94,0,726.27,1.04,94,0,726.32,1.05,94,0,726.3 7,1.06,94,0,726.4\ 1,1.07,94,0,726.46,1.08,94,0,726.51,1.09,94,0,726. 55,1.1,94,0,726.6\ ,1.11,94,0,726.65,1.12,94,0,726.69,1.13,94,0,726.7 4,1.14,94,0,726.7\ 8,1.15,94,0,726.83,1.16,94,0,726.88,1.17,94,0,726. 92,1.18,94,0,726.\ 97,1.19,94,0,727.02,1.2,94,0,727.06,1.21,94,0,727. 11,1.22,94,0,727.\ 15,1.23,94,0,727.2,1.24,94,0,727.25,1.25,94,0,727. 29,1.26,94,0,727.\ 34,1.27,94,0,727.38,1.28,94,0,727.43,1.29,94,0,727 .48,1.3,94,0,727.\ 52,1.31,94,0,727.57,1.32,94,0,727.61,1.33,94,0,727 .66,1.34,94,0,727\ .7,1.35,94,0,727.75,1.36,94,0,727.8,1.37,94,0,727. 84,1.38,94,0,727.\ 89,1.39,94,0,727.93,1.4,94,0,727.98,1.41,94,0,728. 02,1.42,94,0,728.\ 07,1.43,94,0,728.11,1.44,94,0,728.16,1.45,94,0,728 .21,1.46,94,0,728\ .25,1.47,94,0,728.3,1.48,94,0,728.34,1.49,94,0,728 .39,1.5,94,0,728.\ 43 Option = Three Dimensional END END MATERIAL: LN2 Material Group = User Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = liquidrou Molar Mass = 28.013 [g mol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = liquidcp Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [MPa] Reference Specific Enthalpy = -86164 [J kg^-1] Reference Specific Entropy = 3239.4 [J kg^-1 K^-1] Reference Temperature = 94.2 [K] END TABLE GENERATION: Error Tolerance = 0.01 Maximum Absolute Pressure = 1.8 [MPa] Maximum Temperature = 105 [K] Minimum Absolute Pressure = 0.1 [MPa] Minimum Temperature = 85 [K] Pressure Extrapolation = On Temperature Extrapolation = Yes END DYNAMIC VISCOSITY: Dynamic Viscosity = liquidvis Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = liquidk END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.0076741 [K^-1] END END END MATERIAL: VN2 Material Group = User Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Density = vaporrou Molar Mass = 28.013 [g mol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = vaporcp Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 0.50808 [MPa] Reference Specific Enthalpy = 86588 [J kg^-1] Reference Specific Entropy = 5080.5 [J kg^-1 K^-1] Reference Temperature = 94.2 [K] END TABLE GENERATION: Error Tolerance = 0.01 Maximum Absolute Pressure = 1.8 [MPa] Maximum Temperature = 105 [K] Minimum Absolute Pressure = 0.1 [MPa] Minimum Temperature = 85 [K] Pressure Extrapolation = On Temperature Extrapolation = Yes END DYNAMIC VISCOSITY: Dynamic Viscosity = vaporvis Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = vapork END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.0164 [K^-1] END END END END Thanks for any help. |
October 29, 2013, 02:03 |
Rep Power: 144 |
You appear to have defined your function only at a single temperature. Doesn't this make the derivative WRT temperature undefined? So I would add a second temperature to the table and then the derivatives are defined.
October 29, 2013, 02:50 |
Rep Power: 17 |
In order to test whether the data is suitable for the calculation, i defined the function only at a single temperature for simplification at this time.
In the past simulation, the density function is defined as follows in the range of 90-100K,0.3-1.5MPa: 90K, 0.3MPa, density 90K, 0.35MPa,density ... 90K, 1.5MPa,density 90.5K,0.3MPa,density 90.5K,0.35MPa,density ... 100K,0.3MPa,density ... 100K,1.5MPa,density Obviously, some vapor data points were taken out from the table to guarantee all the data points were in the liquid region. In addition, i just tried to add a second temperature to the table, but it doesn't work. The attachment is my ccl in the calculation, could you please help me to check the definition. Thanks a lot for your help! |
October 29, 2013, 06:00 |
Rep Power: 144 |
Two suggestions:
1) Your table limits are 0.1-1.8MPa, but your expression is only defined for 0.5-1.5MPa. You have turned on the extrapolation option. So it is going to be extrapolating to your top and bottom limits, and that could easily go bezerk. I would make your table limits inside your table of values to stop extrapolation. 2) If that does not work I would simplify this further and make density a linear function of pressure. If that does not work then just use constant properties. Keep simplifying until it works. Once you have something which works add the complexity one little bit at a time. Then you know exactly what the problems are. |
October 29, 2013, 11:27 |
#7 | |
Rep Power: 17 |
ghorrocks,thanks a lot for your suggestions.
I tried to make the table limits inside the table values to stop extrapolation, but the error still occurs. In the past, i just made the density a linear function of pressure or temperature for simplification, and these all worked well. Moreover, i also defined the cp,thermal conductivity and viscosity as the function of P & T, but only the density defined as a linear function of P or T. That is also feasible. The error occurs when the density is defined as function of P or T. I was so cofused about this. Thanks again for your kind help. Quote:
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 16:04 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Air entrainment Problem | Jing_min | FLOW-3D | 1 | September 11, 2012 11:24 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 15:20 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
