How to calculate CFL Number in star-CD
Old   November 26, 2004, 18:36
Default How to calculate CFL Number in star-CD
Xobile
How to calculate CFL number / Courant Number in star-CD?
Xobile
Old   November 28, 2004, 10:14
Default Re: How to calculate CFL Number in star-CD
4xF
Take a look at the post in the archive by Giovanni on Mon, 19 May 2003, 1:19 a.m.
Old   November 28, 2004, 20:17
Xobile
I am trying to find out the CFL number and as suggested by 4xF , I went into archives and got this command to get the CFL number and I tried using it but I have got errors:
The command is::
In PROSTAR
RESDAT,10
write the problem file & run the case
trlo,star.rpo
stor iter 10
getc vis
cset news flui
popt cont $cplo
But when i do the above , i run the case after typing RESDAT,10 but I cannot open the file as it says
Error in opening star.rpo
what to do? and what is the reason??
Xobile
Old   November 29, 2004, 07:29
4xF
Do you have an .rpo file in your working directory?
Old   November 29, 2004, 08:24
steve
It should should be
resd,,"freq to write rpo file"
or you can do this in monitor numeric behaviour | write freq for residuals
then after you run the transient case
trlo,star.rpo !load the rpo file as per a pstt file
stor iter first !or what ever iteration you want to see
if you are using 320 or higher you will see the courant number listed in the scalar data panel or else you can execute the command
getc cnum
note that if you use v315A you need to do a "getc vis"
Steve
Old   November 29, 2004, 20:44
AB
I am doing the same thing as suggested by 4xF and steve but there is no star.rpo file created. So I am not able to load any star.rpo file.
can anyone tell me what is the reason? Any problems with settings of my star-CD??
Xobile
Old   November 30, 2004, 05:12
4xF
Please take a look at what steve wrote. The answer to your problem is there since you *need* to ouput the .rpo file.
Old   December 14, 2004, 17:24
Gudrun
C'mon guys! Why dont we try just calculating the CFL number as per it's definition using a normal .pst or .pstt file using the "operate" command?
Or was this a silly suggestion?
Old   December 15, 2004, 08:29
4xF
Do you know by chance how to define a CFl number on an unstructured mesh which does not have a priory any defined grid directions? Because I don't... So, why would n't we get the CFL number as given back by STAR and use it instead?
Old   December 17, 2004, 17:29
Gudrun
Well... lets assume that the CFL-numbers are to be used for engineering purposes, and that we do know the shape of our cells (i.e, tetrahedrals, pyramids or which ever..). Lets then assume that we know how to calculate the volume of the cell, and how to derive a typical cell side length from the volume. Eureka!!! I see a solution to the problem, do you?
How do you think the CFL-calculation is implemented for an unstructured mesh in the code? They sure ain't waving the magick stick, even if they do have access to slightly more info in the solver than what is given in Prostar.
Old   December 18, 2004, 07:37
  #11
4xF
And what if you would not know the shape of your cell? Say, you just need for the solver to know which neighbors you share and what is the face you have in common for calculating fluxes? This is how an unstructured solvers works and you do not need explicitely to know how the cell is shaped.
And now comes the magic stick (which is cell shape independent):
CFL = (Mass_flux)*dt/(rho*cell_volume)
Have fun...
How to calculate the SWIRL NUMBER David FLUENT 1 January 6, 2013 02:23
how to calculate Nusselt number,in CFX? prayskyer CFX 2 June 19, 2006 02:24
how to calculate Nusselt number? prayskyer Main CFD Forum 0 June 17, 2006 21:57
how to calculate the Damköhler number? alfaia FLUENT 0 June 15, 2005 16:11
to calculate local nusselt number Shoeb Siemens 2 January 20, 2005 11:38
