February 10, 2012, 15:40 |
J-Type topology,shifted and non shifted periodicity
Hi Folks
Previously I tried several times to create the J-type mesh for turbomachinery using ICEM. with no success. http://www.cfd-online.com/Forums/ans...ine-blade.html Finally I found a method to do so and wanted to share with you. Geometry is simple with leading edge type shape. Picture of final mesh Steps to create this topology(1-5): Last edited by Far; February 11, 2012 at 07:50. Reason: Title change |
February 11, 2012, 07:47 |
Nonconformal periodicity treatment
Since latest version of Fluent has option for non conformal periodic boundary conditions. Therefore it is not always required to define the periodicity in ICEM and also there is no need to use the shifted periodic boundary condition. We shall create the non-conformal periodic boundary in Fluent. In ICEM define per1 and per2 as interface boundaries.
PS : Fluent V 12 and ICEM V 12 are used for all this work steps 14-16 |
February 14, 2012, 13:16 |
Simon Pereira
Rep Power: 47 |
Why not just apply a CGrid or Quarter Ogrid on this...
Maybe I am not understanding your goal, but I think you could have got all the hard part done in one quick top down procedure. Oh well.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
February 15, 2012, 14:17 |
Simon Pereira
Rep Power: 47 |
The first 9 steps can be replaced by 2 simple splits, a quarter ogrid and one delete block. You will get to the same blocking, but the index will be much cleaner.
I didn't understand what you were trying to accomplish with steps 10 thru 13... I guess this is a periodic model and you were trying to create a shifted periodic blocking? Just put a quarter Ogrid the other way, then apply periodic verts and be done.
February 12, 2013, 04:12 |
Rep Power: 17 |
hi FAR.
thanks for your post - I think the Numeca mesher uses J-grids quite extensively. Just a quick question though, were you able to make conformal periodics with this mesh? I am trying to stay away from quarter o-grids since I often end up with a block of dense cells in the quarter o-grid and which then gives me mesh related issues with variables which are highly sensitive to mesh density! Again thanks for posting this - Best regards Jonathan |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
rhoSimpleFoam | claco | OpenFOAM | 7 | April 20, 2010 04:32 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
