[GAMBIT] Need help with meshing Diesel IC engine |
January 27, 2012, 05:50 |
#21 |
Maxime Perelli
Rep Power: 41 |
Wall edges should be already set as wall, then define the edges which are in your domain as interior.
Then set up wall edges and interior edges as rigid body
In memory of my friend Hervé: CFD engineer & freerider |
January 29, 2012, 07:56 |
#22 |
Rep Power: 15 |
Getting error when doing it as five parts..
'Error: replace_c_in_f_layering: cell of wrong type or NULL cell detected at layering zone. Error Object: ()' @max, @Ghost I can't attach the file here due to the 97kb file size limit.. I can mail them to you ides If I get the ids |
January 30, 2012, 02:17 |
#23 |
Maxime Perelli
Rep Power: 41 |
don't have Fluent anymore, I am basing on my memory...
If you are adding or deleting layers with your interior edges, take care to really set the right "side" of your edges. Thus interior means you have 2 adjacent cells. If you are adding or deleting layers on the upper side, then you need to set height of cells for those adjacent cells in the meshing-options panel
January 30, 2012, 05:59 |
#24 | |
Rep Power: 15 |
For 1,2,3 interiors I can put he adjacent cell size as 1 (sqr mesh of size 1 mm) What will I put for the other value? 0? Should I put cell height for edges that are not in contact with deforming part? |
January 30, 2012, 06:24 |
#25 |
Maxime Perelli
Rep Power: 41 |
No it is ok, if you regrouped all interior edges together.
Sans titre.png Basically you need to set edge C as stationnary. Edges A,B,1,2 & 3 as rigid body. That's it. AS you can see edges 1,2 and 3 have 2 adjacent regions (yellow and white) For edges 1,2 and 3 specify the cells height for the right adjacent cells. (you have to understand here if edge side belong to the yellow domain, or the white one). If you specify 0, then you don't have add/suppress layering (this value should be set for the non-adjacent region)
January 30, 2012, 07:05 |
#26 |
Rep Power: 15 |
January 30, 2012, 07:10 |
#27 |
Maxime Perelli
Rep Power: 41 |
no edges 4,5 and 6 belong to another domain which has to be define as rigid body (I forgot sorry)
So in Gambit define the semi-disk as fluid domain (call it moving or whatever), and in Fluent define this region as rigid body.
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; January 30, 2012 at 08:01. |
January 30, 2012, 07:15 |
#28 | |
Rep Power: 15 |
I think I grouped all of them as 1 single edge when meshing so I think I will go back and start from the mesh again. Will get back soon with new queries |
February 10, 2012, 10:02 |
Meshing finished
#29 |
Rep Power: 15 |
This basically finished the meshing part of the project. I will continue the topic as another thread on model selection.
The topic is continued here. Last edited by tsram90; February 10, 2012 at 13:05. |
Diesel engine in CFX 11.0 | Kirillo | CFX | 13 | July 10, 2019 06:06 |
Premixed heptane-air combustion in a diesel engine (HCCI-dieselEngineFoam) | ayhan515 | OpenFOAM Running, Solving & CFD | 2 | August 21, 2015 08:44 |
Diesel Engine Combustion | arun | OpenFOAM Running, Solving & CFD | 25 | August 11, 2015 10:26 |
meshing of two-stroke engine in gambit | ravi | FLUENT | 2 | January 18, 2012 02:14 |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 10:46 |
