[GAMBIT] Meshing in Gambit for analysis of flow past cylinders
Like Tree3Likes
Old   February 25, 2012, 17:51
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
With mapped hexa blocks, the number of nodes on parallel edges must match (except where they are multiplied by a refinement factor).
For instance, if you have 10 nodes across one index, it must be the same the whole way across your model. You can't just set one particular edge to 7 nodes... that 7 must propagate.
The option to propagate distributions is for the "distribution" (the mesh law, initial spacing, etc.), the number of nodes must be propagated...
lth likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 11, 2012, 01:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
@PSYMN: Any solution to this problem (mesh refinement) for 2-D grids in ICEM
Far is offline   Reply With Quote
Old   March 13, 2012, 09:33
PSYMN's Avatar
Simon Pereira
@Far... It is a defect and has been reported. It should be sorted out for 14.5.
Old   March 13, 2012, 10:09
Default Thankyou
  #64
Far
Sijal
Thankyou very much for very detailed analysis about problem and your time. As I can see things are improving at rapid pace at ANSYS (especially due to Sr product manager )
Old   March 28, 2012, 14:59
Far
Sijal
I saw one of your presentations where you have explained that by deleting (permanently) the inner block of cylinder we can avoid this constraint on parallel edges.
Old   April 2, 2012, 09:49
Far
Sijal
I made the youtube tutorial on how to create mesh of circular cylinder in ICEM.
This is two part video tutorial.http://www.cfd-online.com/Forums/ans...-tutorial.html
Old   October 24, 2017, 03:27
Default Chimera / overset grid
  #67
Far
Sijal
This time i have solved this flow (Re=40) using chimera/overset mesh. And Cd comes out to be 1.518. So there is not much difference in results.
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Flow past a sphere Fabio FLUENT 23 December 18, 2009 16:32
Supersonic flow past a wedge with counter flow Mahesh Bailakanavar FLUENT 0 February 14, 2008 01:21
incompressible free surface flow past cylinder vineet FLUENT 2 April 1, 2002 06:56
beginning - Flow past a square cylinders Odenir de Almeida Main CFD Forum 4 February 10, 1999 10:38
