[ICEM] How to subtract solid from fluid region ICEMCFD
Like Tree13Likes
Old   April 20, 2010, 11:06
Default How to subtract solid from fluid region ICEMCFD
lisa
lisa is on a distinguished road
Dear Members,
I have a Impeller , rotar and the blades joined together. I would like to substract the solid part of the geometry from the fluid region in ICEMCFD.
I am not sure how to carry out the boolean operation in ICEMCFD.
Thanks in advance
Sesan
lisa is offline   Reply With Quote
Old   April 21, 2010, 11:17
Default Booleans are unnessary...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM CFD is not a solids based modeler (it is surface based). Therefore, Booleans are not necessary.
Instead, go to the geometry tab and "create body", then choose the material point option (from 2 points).
Type in "FLUID" as the Material name and then select two locations on the model such that the mid point will be in the fluid...
Similarly, create a second material point named "SOLID", and select its two locations so that the mid point will be in the solid...
Flood fill will take care of the rest for Tetra/Prism...
For Hexa blocking, you select which volume material the blocks are in... but it still helps to have these material points.
If you skip this step and just mesh the model without material points, it will just create them on its own with names like CREATEDMATERIAL1, etc. I usually create them.
Best regards,
Simon
PSYMN is offline   Reply With Quote
Old   April 22, 2010, 09:52
lisa
Hi Simon,
Thanks for the reply. Would also like to know if i can do in Icemcfd Unite,subtract operations like in Gambit.
Since i am looking to subtract the solid from the fluid region and then mesh the fluid region. Like flow around the car. Will it be possible in icem.
Thanks
Sesan
amin_gls likes this.
Old   April 22, 2010, 11:12
Default Don't need to do that stuff.
PSYMN's Avatar
Simon Pereira
Again, ICEM CFD is not a solid modeler and does not need to do any of these operations...
For subtract, you put different Material points in each region.
For Unite, you put the same material points in each region.
It doesn't really unite or subtract anything, but the end result will be the same as if you did.
Side note: If you want to maintain surface elements (internal wall) between volume regions in the same material, you must turn on the internal walls check box on that part (under Params by Parts).
ICEM CFD is very different from Gambit... You need to realize these fundamental differences and advantages or you will be frustrated trying to reproduce the same processes as you used in Gambit... However, if you are willing to change your approach, we can give you the mesh you want.
amin_gls and soheil_r7 like this.
Old   May 19, 2010, 02:21
Andrey
Andrey M. is on a distinguished road
Sorry, mis click.
Andrey M. is offline   Reply With Quote
Old   May 19, 2010, 02:34
Andrey
Hello Simon!
I suppose. I have the same problem. I'm new in ICEM and in fact I have no experience with Gambit. I'm trying to make task with rotation in OpenFOAM using MRFsimpleFoam. I've found small tutorial for GAMBIT (http://openfoamwiki.net/index.php/MRFSimpleFoam) and now trying to make it in ICEM. I'm very thankful for your previous posts the really added much understanding in differences, but I still need some advice.
Going step by step:
1.generate two cylinders (r1=0.5 h1=1; r2=0.25, h2=0.5) and one cube (h3=0.3)
2.subtract cylinder 2 from 1 (maintain cylinder 2)
3.subtract cube 3 from cylinder
Till that moment there is no any problems. As I understand I need just to make 3 parts in ICEM.
4. Connect the faces (inner face of cylinder 1 and outer face of cylinder 2)
To do that I need to make 3 material points one as solid in cube and two in cylinders as fluid.
5. define continuum types (zones): rotor for cylinder 2, and stator for cylinder
As I understand you I need to mark intwall checkbox in part mesh parameters. Am I right?
6.define boundaries (inlet, outlet, cubeWall, cylindricWall, sliderFace).sliderFace is the connected faces mentioned above.
7.define the boundary for sliderFace as INTERIOR
At this two steps I misunderstanding. Inlet,outlet, walls it's not problem I knew how to do that, but everything connected with sliderFace, boundary between two cylinders, is a mystery. I suppose that it needed not to have a small cylinder as part, but to have some additinal boundary. But I don't know how to do that. Can you show the way?
Best regards,
Andrey
Old   May 19, 2010, 17:12
Default Solver forum...
PSYMN's Avatar
Simon Pereira
Andrey,
You only need to mark parts as internal wall if the volumes on both sides are the same material, but you want to keep the shell elements. By default (if you don't mark as internal wall) it will remove shell elements if the volume material on both sides is the same.
I am not quite clear on what your model looks like, but generally speaking, you could just put the sliding interface surfaces into a Part (perhaps named "SLIDING_INTERFACE") and then set it up in in FLUENT...
Beyond that, I suggest asking this question under the solver forum (I am not a huge Fluent expert), or look up how to do it in a Fluent tutorial...
Old   August 10, 2011, 19:43
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
I am having a similar problem and also having trouble following Simon's explanation. For simplicity, I'm trying to model the 2D heat transfer through a square aluminum block with a circular hole in the center. I'm having trouble creating a mesh because I don't know how to exclude the circular region from the rectangular aluminum domain in ICEM. All geometry (points and edges) were created in ICEM.
Thanks for your help.
NormalVector is offline   Reply With Quote
Old   August 11, 2011, 15:28
PSYMN's Avatar
Simon Pereira
Normal Vector... Hexa or Tetra? Assuming Hexa and assuming you have blocked the plate and it has thickenss, you just need to place the blocks into the correct part. Do this by right clicking on the volume part => Add to Part => Add Blocking Material.
If it is a zero thickness baffle, then all you need to do in hexa is work with the associations => Face to Surface. Assign the face to the surface and the shells (internal wall) will be created.
If this doesn't help, please include an image so I can understand the issue.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Old   August 11, 2011, 16:39
NormalVector
I've attached what I'm working with. I'm trying to mesh the grey part using a 2D, zero-thickness tetra mesh to use in FLUENT. In Gambit I would just create the rectangular and circular surfaces and then use the boolean subtract to leave the rectangular surface with a circular hole cut out of the center. As you've said, ICEM is completely different from Gambit and I'd like to transfer that procedure into ICEM but I've had no luck. Does my problem require blocking?
Thanks for your time.
Old   August 12, 2011, 12:17
Default Simple surface based paradigm.
  #11
PSYMN's Avatar
Simon Pereira
So it is just a surface with a hole in it... You just want a 2D triangle mesh?
No problem.
If the grey part is a surface, just mesh it. If there is a surface for the circle in the middle, just delete it (or don't select it to be meshed). It is a surface based mesher, there is no need for booleans.
ICEM CFD has several meshers that could get it done for you.
If you use patch dependent surface meshing, then you will need to make sure that you run Geometry => Repair => Build Diagnostic Topology. This tool makes sure that each surface is bounded by "attached" curves. You will need to set the sizes on these curves (or the overall parts). The Patch dependent mesher starts from "loops" that get their sizes from these curves and then pave across the surfaces using a recursive loop algorithm. If you want prism, do a search for instructions regarding BLAYER2D.
If you are going to use Patch Independent surface mesh, you just set up sizes on surfaces and curves and hit mesh. It is not as picky about attachment or gaps or anything like that. You can look up more about this algorithm in the help.
Either way should be pretty easy.
ICEM CFD Hexa would also be nice and not hard to block either. But you should probably try a tutorial or two first.
Best regards,
Simon
Old   August 12, 2011, 12:43
NormalVector
Yeah that's basically it, I'm not working with too complicated geometry. Perhaps I should have mentioned that I'm creating this geometry inside of ICEM from points, curves and then surfaces. My problem is getting a surface in the shape of the grey region. When I choose to create a surface from the four outer square edges and the circle, ICEM disregards the circle and just creates a square surface with no hole in the middle.
Meshing makes more sense now... so an edge mesh is necessary?
Old   August 12, 2011, 13:54
PSYMN's Avatar
Simon Pereira
Oh, so you don't yet have what you showed me. Instead, you have a square surface with a circle drawn on it...
There are several ways to cut the square with the circle.
The most obvious is "Create/modify surface => Segement surface => by curve". Then delete the surface inside the circle.
But most users just run build topology. It will automatically sort out issues like this and segment the surfaces while it builds up the connectivity. Then you just come back and delete the circle if you don't want it.
Simon
NormalVector likes this.
Old   August 12, 2011, 15:14
NormalVector
Thank you, that worked perfectly. While I still have you here, I have another question. I saw on another one of your posts about mesh growth control that you mentioned using the mesh params by parts tab. Will I use that for my 2D case? I want to recreate something like the attached; small elements at the wall and larger elements in the center. I want to do an edge mesh size of, let's say, 0.08 on the surrounding edges and I want it to grow to a size of 0.5 at the interior with a growth ratio of 1.2. Is that growth controlled by "mesh params by parts"?
Old   August 13, 2011, 12:01
LL
aweizazuji is on a distinguished road
Hi Simon. As you mentioned to created materia points, I just want to know how does ICEM determine which part belong to the body you set? Let's you create a CAR solid from two points around a car, and the car is divided into many parts ,then which zone belongs to the CAR solid?
aweizazuji is offline   Reply With Quote
Old   August 20, 2011, 12:45
NormalVector
I also had a question about material points. Should it be created before or after the mesh? Also how does ICEM know what to take as one body... is it determined on a surface basis?
Old   August 20, 2011, 13:44
Default Floodfill explained (briefly)
  #17
PSYMN's Avatar
Simon Pereira
Material assignment is done by a concept called "Flood fill". You should place the material point before mesh generation because Flood fill is part of the octree process, but you can also place a material point later and run flood fill manually from the "Edit Mesh => Repair" DEZ.
I am sure I have described this in detail before, so just do a search for "Material Point" or "FloodFill" for that.
The short version is that it locates the material point and then finds the cell (element) that the material point is in. It logically assumes that you want that cell to be in that volume. Then it assumes that you also want all the volume cells attached to that cell. Then it assumes you also want the volume elements attached to those cells and so on. It stops in any particular direction when it reaches surface elements (shells) that were formed earilier when the mesh was being cut into the geometry. However, in other directions, it keeps adding where ever it finds a volume element next to a marked volume element. Eventually, it runs out of elements to add and then start with the next material point and does the same thing.
If during the process the flood fill encounters another material point, it will say that you have leakage because there were no shells between the material points.
As I said, more detail is in the help and on CFD Online...
Old   August 20, 2011, 13:59
NormalVector
Does ICEM's material point determination work with just surface meshes? I'm working in 2D and thus have no volume.
Old   August 20, 2011, 21:01
PSYMN's Avatar
Simon Pereira
No, material points are for marking the volume. Surface meshes or 2D meshes will inherit the part of the surface geometry they follow.
Simon
Old   August 20, 2011, 23:17
NormalVector
Alright, no material points for me. I saw another post of yours about conjugate heat transfer and the wall/wall shadow not showing up in FLUENT when meshed in workbench. You mentioned making a multi body part and the original poster said the problem was worked out but never said how. I'm not using workbench, is a multiple body part the route I need to take as well? The wall shadow isn't showing up for me in FLUENT either.
Again, I appreciate all this help. I'm making the switch to ICEM and haven't gotten my hands on any tutorials yet.
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
Solid Fluid interactions with non newtonian fluid daniebae ANSYS 12 May 27, 2013 04:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Solid Fluid Interface boundary problems shankara.2 ANSYS Meshing & Geometry 0 April 22, 2009 17:05
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 12:13
