April 6, 2010, 12:06 |
Modeling 2D Geometries
Sarah
Rep Power: 16 |
I want to model a 2D geometry in ansys (12.1) and I am not sure if I my method is the right one. First I drawed polygon lines with a closed end, and then I extruded this sketch. My problem is that the geometry becomes 3-dimensional with the extrusion. And it is impossible to put the depth (for the extrusion) to 0mm or even 1e-1000mm (i.e. as thinn as possible) . So my question is: is there another way to create simlpe faces in ansys or does it only go by extrusion? Thanks in advance for an answer! P.S.: Sorry if this is a stupid question but I am new with ansys and I am desperate |
April 7, 2010, 12:31 |
Surfaces from Sketches
Simon Pereira
Rep Power: 47 |
Extrude is for 3D data… If you just want to create a surface from a sketch, then go to “Concept => Surfaces from Sketches”.
SurfaceFromSketches_01.gif This will prompt you to select your sketch(es). Then click generate. SurfaceFromSketches_02.gif The SurfaceSketch will appear in the model tree with its associated Sketches… SurfaceFromSketches_03.gif Next you will need to select the edges to apply named selections for things like inlets and outlets… |
April 8, 2010, 06:01 |
Sarah
Rep Power: 16 |
Hi PSYMN,
It works ! Thank you for your detailed reply |
Modeling Geometries in CFX | Jux | CFX | 0 | May 11, 2009 07:15 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 16:46 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 10:21 |
