April 24, 2007, 14:47 |
Airfoil meshing
Hi:
I am learning ICEM CFD and one of my first tasks is to generate a C-grid around an airfoil. I am trying to create a nice blocking scheme with an O-grid to capture the geometry with a nice boundary layer around it. However, so far all my attemtps have failed. I always get different kind of problems with the grid. Could anyone help me and provide me an idea or step-by-step approach to create C-grids with ICEM CFD, please? I have never done C-grids before. I have experience using gambit, where I usually do circular grids around airfoils. I have already completed all the ICEM tutorials, so I am familiar with the tools in the program. Thanks |
April 24, 2007, 17:28 |
Re: Airfoil meshing
Where are you from? contact me. I talk spanish and I can help you out, with a previous airfoil project I worked. Cheers Santiago.
April 25, 2007, 05:33 |
Re: Airfoil meshing
I found it also not that easy to do. But this is how I did the blocking of it in the end.
<img src=http://users.cybercity.dk/~ida3068/cfd/C-grid.png> <img src=http://users.cybercity.dk/~ida3068/cfd/C-grid%20blocks.png> Dr. Flow Squad |
May 9, 2007, 21:09 |
Re: Airfoil meshing
May 10, 2007, 05:26 |
Re: Airfoil meshing
That looks OK. Can I see it zoomed in on the airfoil?
May 10, 2007, 10:19 |
Re: Airfoil meshing
September 28, 2009, 09:43 |
Karatix
Rep Power: 17 |
I also try to create a C-Mesh, with a similar strategy, but each time I export the mesh (using CFX4) there is a very tiny gap at the leading edge. When I associated the two vertices ahead of the airfoil to one point (5m away from the leading edge), the exporting failed. When I overlapped the verticies manually using "move vertex" the gap does not disappear and neither for moving both vertices using the coordinate system. Do you have any suggestion for me? |
September 30, 2009, 11:06 |
#9 |
Christiano Santim
Rep Power: 17 |
hi santiago,
can u show me step by step, blocking mesh scheme? see u later, regards |
October 10, 2009, 09:59 |
#10 |
Salvatore
Sorry Santiago....
Can you explain step by step how do you create the blocks for the mesh ??? Thx for all... |
April 17, 2010, 00:57 |
I FINALLY made a movie to answer this frequently asked question
#11 |
Simon Pereira
Rep Power: 47 |
I FINALLY made a "how to" movie to answer this frequently asked question, well three parts actually.
They are on the ANSYS YouTube site... http://www.youtube.com/ansysinc I know it is late, but I hope it helps... |
June 1, 2010, 12:50 |
#12 |
Jiang Lijun
Rep Power: 17 |
Thanks for your perfect job, Simon
Lijun |
December 26, 2019, 05:56 |
#13 |
RI
Problem Meshing Airfoil | erodv | OpenFOAM | 12 | January 11, 2012 18:46 |
Airfoil Meshing Scheme in Gambit | J. Weiler | FLUENT | 6 | October 2, 2011 16:41 |
Basic steps meshing an airfoil [ICEM] | peterputer111 | ANSYS Meshing & Geometry | 4 | April 19, 2010 13:08 |
Meshing airfoil | Wason | FLUENT | 6 | November 8, 2009 12:50 |
Meshing An airfoil with a simple plain flap | S. Kalam | FLUENT | 7 | January 30, 2005 21:22 |
