[ICEM] subdomain mesh
Old   September 6, 2015, 04:23
Question subdomain mesh
hani mortezaee
h.mortezaee is on a distinguished road
hi all
im trying to mesh cylinder that has cylinder in its volume as subdomain, what should i do ?
a general description for this kind of meshing will be helpful,
thank you all in advance
h.mortezaee is offline   Reply With Quote
Old   September 6, 2015, 06:38
Attique Javaid
attiquejavaid08 is on a distinguished road
pictorial description will help in giving some suggestion.
attiquejavaid08 is offline   Reply With Quote
Old   September 8, 2015, 09:43
Antanas is on a distinguished road
Originally Posted by h.mortezaee View Post
hi all
General Description: Launch ANSYS Meshing and press Generate mesh.
Antanas is offline   Reply With Quote
Old   September 8, 2015, 11:33
hani mortezaee
thats really funny
i know that , i needed the help in ICEM not ansys meshing
Old   September 8, 2015, 15:34
thats really funny
Ok. Take a look ICEM CFD software for 3D concentric cylinders. Maybe it's will help. But he should use o-grid for inner cylinder there.
Old   September 9, 2015, 05:28
hani mortezaee
Ive already seen that but the mesh generated doesn't give me a domain inside the outer cylinder for using in cfx-pre , i can do the mesh with ansys meshing its "apparently" a good mesh , u see aspect ratio is below 5 , skewness and orthogonal angel is fine too , but my solution doesn't converge , my BCs also fine , for more information im trying to model cyclotron gas target , its a cylindrical cavity with filling pressure of 25 atm and its going to be bombarded with proton beam of certain energy and current , it deposits about 570 watt in the cavity that its volume is about 70 ml , so i need the patch conformed mesh of a lot tiny cylinder inside the cavity to model the proton beam energy deposition inside that tiny cylinders , and i need that mesh to be as good as it gets ,
im really frustrated i don't really know where is my problem ,
i know its meshing forum but i thought maybe with more description i could get help better
thanks for reading
Old   September 9, 2015, 07:39
thanks for reading
Hmm... you may need to associate block faces to geometry surfaces. Look ICEM tutorial 'Bottom Up Hexa Mesh Strategy for a Grid Fin' Step 5.
Old   September 9, 2015, 07:44
hani mortezaee
yeah i think so , sounds right
thankyou for quick reply
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
