[ICEM] Hexa -> small y+ problem
Like Tree7Likes
Old   September 5, 2014, 04:55
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey cad,
I thought about your post but still don't get your point.
I made a small sketch and I can't see here how the quality suffers from refining.
The original (coarse) cell is the blue one, the green line shows on of the refined cells. For me, it looks like all angles keep constant.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   September 8, 2014, 08:27
Philipp
Ok guys, they changed the algorithm for orthogonal quality in ICEM so it matches with the value in Fluent now. That's why we see different values in 14.5 and 15.0.
The new calculation depends strongly on how good the cell center coordinates can be calculated. This calculation however depends on the aspect ratio. So for really large aspect ratios, cell center is inaccurate thus orthogonal quality can be bad.
The question is, if "just" the orthogonal quality is bad, or if this inaccurate cell center calculation also influences the algorithm.
So I started some tests with a short periodic pipe (L=0.5D)
I keep x- and z- direction grid constant, also the total number of gridpoints, just change the y value from 5e-6, 2e-6, 1e-6, 5e-7.
Orthogonal quality decreases from >0.75 to >0.45 to >0.25 to >0.1 from large to small y-cell-sizes. k-Omega-SST with low-Re corrections, Fluent 15.0.
I made pictures for U, k and omega and plot all four grids in one picture.
U looks like this:
A closer look to the wall looks like this:
and for k:
and for omega:
Omega of course changes at the very first gridpoint, since the boundary condition depends on the y+ value.
Maybe this is different for not attached flow, but for the pipe I think it's pretty safe to just not care about these "close to the wall" bad orthogonality.
Far, ghost82 and kad like this.
Old   September 8, 2014, 09:44
kad
kad will become famous soon enoughkad will become famous soon enough
Originally Posted by RodriguezFatz View Post
Hey cad,
Attachment 33560
Okay, I did not made that very clear. I did not mean coarsening in the radial ogrid direction but in the tangential direction. This means you have less nodes on the circumference of the pipe and bad aspect ratio cells on the wall.
kad is offline   Reply With Quote
Old   September 8, 2014, 09:58
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
why they consider aspect for orthogonal quality? Since it is mentioned in help you can go up to AR=1000 for single precision and 10,000 for double precision.
It means this value has no significance in reality?
It also implies that CFX wont care either...
Far is offline   Reply With Quote
Old   September 9, 2014, 03:35
Philipp
As far as I understood, it is not considered directly, but really large aspect ratios deplete the correctness of the calculation of orthogonal quality (OQ) in Fluent. The question is, if just the OQ is affected, or actually the solver / any other algorithm as well.
The funny thing is, they told me that Fluent reliably supports only aspect rations up to 100 to 250. So basicallly for y+=1 you had z and y+=250.
I asked him why I would use a low-Re RANS model, if my wall grid needs to be good enough for wall modeled LES anyway. Or if that means, that Hexa meshes are not usable for low-Re Fluent RANS.
Old   September 9, 2014, 16:44
Far
Sijal
I was told that AR = 1000 is ok with single precision and 10000 with double precision.
Today I just made a mesh around a square and these are the statistics from fluent
Mesh Quality:
Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality.
Minimum Orthogonal Quality = 7.07104e-01
Maximum Aspect Ratio = 1.01719e+04
ortho quality = 0.7 and aspect ratio = 10171.9 and results are good
Although i have refined the mesh in the vicinity of wall, but without using ogrid. I guess Ogrid would deteriorate the orthogonal quality.
But what is the orthogonal quality. Is it mix of min angle, determinant 2*2*2 and quality ? If these metrics are good enough, then ortho quality should also be good....
Old   September 10, 2014, 03:39
Philipp
I waver between trying to get a reliable answer from Ansys or just not watching this value ever again...
[ICEM] Problem when I try to merge hexa & prism pipolaki ANSYS Meshing & Geometry 7 December 4, 2012 09:44
Question -> problem in transferring mesh into setup babak.mahjoub FLUENT 2 December 1, 2012 04:14
[ICEM] small problem with icem diamondx ANSYS Meshing & Geometry 1 October 1, 2012 04:24
parallel mode - small problem? co2 FLUENT 2 June 2, 2004 00:47
small problem amiroamir FLUENT 2 December 12, 2002 02:23
