May 29, 2014, 11:43 |
Meshing a Turbine Bladepassage
Daniel Frederik
Rep Power: 12 |
Hi everybody,
I'm currently simulating a radialturbine. While Meshing the TurbineBlade i noticed that TurboGrid meshes the blade not within the Geometry Zone defined by BladeGen (see Picture). The Mesh is shifted to the right. Is that normal? Thanks for the responses Daniel |
June 2, 2014, 06:35 |
#2 | |
June 2, 2014, 06:46 |
Daniel Frederik
Rep Power: 12 |
Thank you for you're reply Far. What do you mean by that much domain? It's just one blade passage of ten. Is there a better way to do it?
June 3, 2014, 16:35 |
Ion
Rep Power: 16 |
The Mesh is shifted to the right because you used default in turbogrid and this mean that at topology you use ATM method... you can change to Traditional with Control Points and the mesh will have the blade in the middle...
[GAMBIT] Meshing a wind turbine for wing tip vortexes | Grog106 | ANSYS Meshing & Geometry | 1 | March 29, 2012 07:07 |
Meshing Volume in Gambit for a water turbine | Zaqie | FLUENT | 1 | July 24, 2009 02:25 |
Marine current turbine (meshing and stimulation help needed!!) | coolyihao | FLOW-3D | 0 | March 16, 2009 12:48 |
Q: how to do a good meshing in turbine usin gambit | oscar | FLOW-3D | 1 | March 15, 2009 00:15 |
turbo turbine meshing with gambit | Mak | FLUENT | 3 | October 2, 2008 07:31 |
