[Workbench] Which input file format can be used to import geometry
Old   July 31, 2013, 17:05
Question Which input file format can be used to import geometry
Chaithu
Irondome is on a distinguished road
Hi friends,
I am new to ansys workbench and have a problem to carry out my project. Please excuse me if the problem is silly.
The problem is, I am given set of .geomTurbo files with specified geometry profile of rotor. The problem is we cannot use Numeca and my professor has asked me to use these files in other format and use Bladegen or Geometry Component systems in Ansys workbench.
Since I am new, I do not know, to which format I shud change the given file. I am attatching a screen shot of the file.
It will be very helpful if someone can help me out.
Excuse me if the problem is very silly or easy.
Thanks a lot.
Irondome is offline   Reply With Quote
Old   January 17, 2018, 22:12
Shihar
mhal6932 is on a distinguished road
Hi did u manage to build the impeller from the file in ANSYS , i have the cordinates of the radiver blade but was not able to create the full geometry of the impeller in ANSYS?
mhal6932 is offline   Reply With Quote
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 05:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
