January 20, 2013, 20:19 |
#102 |
Ali this method is perfect. But I am not able to generate the volume mesh in the inner domain through denauly. No matter Whatever I do, I always get one big larger than inner domain!!!!
January 28, 2013, 07:00 |
Problem in Denauly mesh
#104 |
Now I am trying to generate denauly using surface mesh as shown in previous posts. But volumes are leaking as can be seen attached Figs.
What is the problem? I checked through build topology and did not find any problem there. |
January 28, 2013, 10:13 |
#106 |
Big box is deleted so there is only small box (should be same now? ). Tgrid does make the grid and even prisms successfully but there is some thing strange happening there as well (quite different than ICEM)
January 28, 2013, 10:57 |
#107 |
Tgrid is making prisms in the first wing (from left to right on screen) correctly but it is penetrating prism inside the wing instead of extruding them on wing 2 and 3. See attached pics and files are also attached.
https://dl.dropbox.com/u/68746918/Inneronly.rar |
January 28, 2013, 12:55 |
#109 | |
Simon Pereira
Rep Power: 47 |
There are two sets of node numbers, the ones in the forground and the ones in the background... Basically, it messes up the surface mesh node numbers in the background so that when delaunay runs it gets the wrong connectivity. To fix it, try running the Edit mesh option to re-number nodes before running delaunay.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
April 21, 2013, 08:50 |
#110 | |
Marinus
Rep Power: 13 |
April 23, 2013, 11:40 |
#112 | |
Marinus
Rep Power: 13 |
Somewhere during saving the element numbers were changed automatically, however when I tried doing this manually it did not fix the problem. Maybe I did this wrong. Luckely I found a working solution . Thanks for the help. |
April 23, 2013, 13:36 |
#114 |
Marinus
Rep Power: 13 |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 19, 2023 00:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 08:21 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 01:35 |
[ICEM] Hexa meshing blocking problem | fergal | ANSYS Meshing & Geometry | 0 | June 28, 2011 11:01 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 21:03 |
