[ICEM] How to create 2 different fluid regions
Old   November 21, 2012, 04:49
Default How to create 2 different fluid regions
nova23 is on a distinguished road
I have 3 different surfaces Solid, Steam and Gas under different part names in ICEM. When I import the mesh into Fluent, under Materials I am getting only air under Fluid, whereas I want two materials under Fluid, one for Gas and another for Steam. What should I do so that I have three separate materials? Can it be done in ICEM or is it something that has to be done in Fluent? I am using version 14.
nova23 is offline   Reply With Quote
Old   November 21, 2012, 11:40
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
three material means three bodies. you have to create three bodies. you will find that tool the geometry tab. all you need to do is select two point (extremities )and the body will be created in the centroid of those two point. for example if you want a body for the solid region (tube) select one point in the inner surface another one in the outer surface.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 22, 2012, 07:22
Actually mine is 2D. What I did was simple, I meshed it, imported in Fluent and in Materials, under fluid I click create/edit, change the various properties and click change/create. Here it will ask "would like to overwrite?" Just hit no and it will create another material under fluid. Then in Cell Zone Conditions I select the appropriate zone and hit Edit and change the material name.
Is this right?
I will also explain the problem and doubts I have:
1. The gas enters from the edge marked in pic with temp 500K and pressure of 100Pa. BC Type Pressure Inlet. There are 2 Gauge total pressure and Supersonic/Initial Gauge Pressure. Which one should I use?
2. The steam is at a temperature of 200K. BC Type Wall
3. I make the left and right edges periodic.
4. I do not know the exit conditions.
5. My objective is to find the solid wall temperature.
I created 3 materials in fluent because there are 3 zones - gas, steam and solid with different properties. Do I need 3 materials or just 2 is enough - steam and solid and give just temp. and pressure for flue gas?
The exit I tried to make Type as Outflow but I get this "Warning: Both outflow and pressure boundaries are present in the domain. This is an incompatibility and solution cannot proceed until this is fixed." So what type should I make exit as?
Old   November 22, 2012, 12:03
diamondx's Avatar
Ghazlani M. Ali
yes
this is more about how to set boundaries condition, you will get more help if you address your problem in the fluent section. a lots of people deal with thermal analysis there.
- it's better to try mass flow inlet instead of pressure inlet.
- you don't have to know the exit condition, leave it the default pressure outlet
- you don't need three materials, you can emit the solid material, in fact, when assigning wall for the tubes, you can specify the thickness and the material , fluent will take care to simulate that real thickness you have while calculating.
this is all i know about it. hope it can help. don't forget to transfer this thread in the fluent section
Regards,
Ali
Old   November 23, 2012, 13:50
Thank you very much diamondx. How do I transfer this thread? Should I create a new Thread in the Fluent section?
Old   November 23, 2012, 13:56
diamondx's Avatar
Ghazlani M. Ali
yes just start a new thread there !!
Regards,
Ali
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
Weak Coupling of Two Fluid Fields/ Regions woody OpenFOAM Running, Solving & CFD 0 November 16, 2009 11:08
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
