[ICEM] T Junction Meshing using ICEM CFD
Like Tree8Likes
Old   November 11, 2012, 03:22
Default T Junction Meshing using ICEM CFD
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
I am new to ANSYS and I am currently learning meshing in ICEM CFD for my work on T Junction based flows. I have a few questions
1. What is the purpose of an O Grid? Is it only used at the boundaries? where can I learn more about the application of an O Grid?
2. The quality of mesh in the T Junction (where the two pipes intersect) where the important physics needs to be captured is average (It's related to my lack of understanding and using the blocking function properly). I have also posted some pictures which display the mesh along with the quality histogram. Any suggestion on how to improve the meshing functionality and reducing errors would be welcome. Thanks in advance.
Last edited by selvam2487; November 11, 2012 at 03:24. Reason: To remove some pictures
selvam2487 is offline   Reply With Quote
Old   November 11, 2012, 05:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Download from this link
https://dl.dropbox.com/u/68746918/pipejunction_3d.zip
selvam2487 likes this.
Far is offline   Reply With Quote
Old   November 11, 2012, 06:33
Default thank you
Karthik
Hello Mr. Far,
Thank you very much for your help. I think I understand the blocking strategy that you have implemented. I will try to do it and see what happens.
Regards,
Karthick
Old   November 11, 2012, 06:43
Far
Sijal
Just brief steps :
1. Create main block
2. split at the junction and then two splits on the two sides of small pipe and perpendicular to bigger pipe
3. delete two blocks on right and left of the small pipe
4. Make associations
5. snap vertices.
6. make o-grid inside the small small upto the large pipe's bottom. Select two extreme faces.
7. Make the O-grid for the larger pipe and again select the respective end faces.
8. go to edge mesh parameters and update all sizes and go to second tab and give size 2 and apply. Keep on applying until mesh size is at-least 20000 hexas
9.Check premesh.
10. One horizontal split in the large pipe.
11. Play with vertices location panel to adjust the blocking to higher quality.
Anouar and ticofiz like this.
Old   November 11, 2012, 14:35
Default Smooth mesh
Far
Sijal
Smooth mesh after applying the elliptical solver.
Gweher and FJSJ like this.
Old   November 12, 2012, 06:12
Karthik
Hello Mr. Far,
Could you please explain me as to what is the function of an O Grid? Also, when checking premesh quality histogram, the angles are not good? How to improve the angles in the mesh? Also, for this T junction geometry, what are the other Premesh quality criterion that should be checked?
Regards
Karthick
Old   November 12, 2012, 06:28
Far
Sijal
Min angle is 32 and min quality is 0.6. which is good enough.
Old   November 12, 2012, 12:21
AB
BrolY will become famous soon enough
The O-Grid is very powerful because with this circular shape, O-Grid helps to have orthogonal cells around the circular shape.
Try to mesh a tube with, and without O-Grid, and it will be obvious
BrolY is offline   Reply With Quote
Old   November 12, 2012, 12:32
Far
Sijal
Mesh quality is 0.6 in ICEM and min orthogonal quality is 0.5 in Fluent and after smoothing (orthogonality) min mesh quality is 0.28 in ICEM and min orthogonal quality is 0.6 in Fluent.
Why smoothness decreases quality in ICEM and enhances the quality in Fluent?
What is the relationship between ICEM quality and Fluent orthogonal quality?
Old   November 12, 2012, 13:00
AB
ICEM help manual about the quality :
Hexa
The quality is a weighted diagnostic between Determinant (between -1 and 1), Max Orthogls (normalized between -1 and 1; if deviation from orthogonality is greater than 90 degrees, then the normalized value will be smaller than 0) and Max Warpgls (normalized between 0 and 1; warpage of 0 degrees is 1, warpage of 180 degrees is 0). The minimum of the 3 normalized diagnostics will be used.
When you do orthogonal smoothing, you increase the orthogonal quality, but maybe, it also decreases the quality of your determinant.
I guess Simon could help us on that.
Old   November 12, 2012, 13:06
Far
Sijal
Check this Figure.
http://afinemesh.files.wordpress.com...el-529x359.png
Can you tell me which quality he is talking about?
Old   November 26, 2012, 08:16
Andrey
Ralen is on a distinguished road
Another idea.
1. Split selected block.
2. Split selected block.
3. Delete default associations of six edges and associate them to surface.
4. Snap Project Vertices.
ticofiz likes this.
Ralen is offline   Reply With Quote
Old   November 26, 2012, 08:18
Andrey
5. Create O-Grid with all blocks and faces of three ends.
ticofiz likes this.
Old   November 26, 2012, 10:03
Far
Sijal
can you share the files?
By the way excellent comeback.
Old   November 26, 2012, 10:49
Default good
  #15
Far
Sijal
Ralen method is simple and somehow giving better quality and good looking mesh with few splits as you can see in attached pics(Mine in this post and Ralen' idea in next post.
My method:
Old   November 26, 2012, 10:51
Default Ralen's Method
  #16
Far
Sijal
Here are the images from Ralen's Method:
Old   November 27, 2012, 01:17
Andrey
http://www.sendspace.com/file/p70hlf
Old   February 24, 2013, 22:09
df
vansyle is on a distinguished road
Hi Ralen,
The link is died, could you please upload again? Thank you very much!
vansyle is offline   Reply With Quote
Old   November 1, 2016, 19:35
Dan
YoungMan is on a distinguished road
Hello everyone, I this thread hasn't been used in two years but I would really appreciate it if someone could post a mesh file for a Tee junction for openfoam. It would really help with my work!
YoungMan is offline   Reply With Quote
Old   November 2, 2016, 10:26
Far
Sijal
check these videos and you will find mesh and icem cfd files in description. if not i will provide you.
https://www.youtube.com/watch?v=HVbwUmGp3Xg
https://www.youtube.com/watch?v=aHVPJA0_JGQ
https://www.youtube.com/watch?v=-LOSmwUQcGI
https://www.youtube.com/watch?v=fycZjB2txig
https://www.youtube.com/watch?v=u7a9C2zo0zg
icem, mesh quality, o grid
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 10:48
[ICEM] Problems with meshing in ICEM CFD Benne ANSYS Meshing & Geometry 2 September 17, 2012 04:08
[ICEM] Helicopter meshing tutorial - ICEM CFD Far ANSYS Meshing & Geometry 0 May 20, 2012 12:10
[ANSYS Meshing] Icem cfd - hexa meshing arunkumarnd ANSYS Meshing & Geometry 9 April 12, 2012 06:47
