May 30, 2012, 13:17 |
#41 |
Did you read any of the Ahmed body papers? Usual turbulence intensity of the free stream airflow in a windtunnel is around 0.25 %, so me using 1 % is already a bit higher and more "real world"-like, but 2.5 is unnecessary.
You (and most others) seem to confuse a no slip wall and a no shear wall. No slip wall is what I've used for the ground and the ahmed body (since that's what they are, stationary walls with shear stress or 0 slip). However, for the side and top wall - if you are going after ultimate accuracy and recreating exact wind tunnel conditions, then those walls should also have a boundary layer (same as the ground and the Ahmed body itself), but since most of the time they're far enough away to only affect the solution a little bit (if left as no slip), they can be given no shear stress boundary conditions so their viscosity effects will be disregarded. Since this is mathematically the same as a symmetry BC for Fluent, I used that for simplicity. /edit, seems you have read about turbulence intensity |
May 30, 2012, 13:21 |
#43 |
alessandro
Rep Power: 16 |
May 31, 2012, 11:49 |
#44 |
September 11, 2012, 11:19 |
#45 |
nicolas
Rep Power: 14 |
Hi, I'm meshing Ahmed Body with Pointwise V17. I'd like to know wich is the right mesh dimension on the body, because I see in the pics here posted that are used cells far bigger than mines.
I'm using the following average dimensions: in the length, a point every 2 mm; in the height, a point every 1,6 mm; so the average dimension of the cell is 2x1,6 mm. thanks a lot. |
February 1, 2014, 20:23 |
#46 | |
Meimei Wang
Rep Power: 16 |
Best regards, Meimei |
February 2, 2014, 00:05 |
#47 |
symmetry boundary condition is used becuase we are not giving any angle of attack or side slip angle and flow will be same for both sides. Therefore to reduce the computational cost we must use symmetry BC...
February 2, 2014, 06:51 |
#48 | |
Meimei Wang
Rep Power: 16 |
So I ask, has someone done test or not? Or the usage of symmetry BC is from any experience? Or this is just a widely known setting?
February 2, 2014, 08:45 |
#49 |
You can run both cases and see what is happening.
Generally speaking flow structure will not be symmetric at the particular instant of time, but on average flow variables won't be affected by symmetry condition. |
March 6, 2015, 04:35 |
unstructured meshing of flying wing
#50 |
mahantesh
Rep Power: 12 |
hello..
i am doing unstructured meshing (tetra) with patch indepedent and robost octree method on flying wing and after volume meshing , i gone for prism mesh but prism layers are not created. And one more thing is quality of the mesh is very poor before creating prism layers and after it is still worst in patch dependent scheme ...its about 8*e-6(quality) and orthogonal quality is 0.0003.....if any suggestions related to above topic? |
July 20, 2015, 18:21 |
#51 |
Rep Power: 12 |
I found this topic looking to solve a similar issue I had with ICEM mesh not translating properly into FLUENT.
In my case, ICEM was in mm while FLUENT was in m, so there was a discrepancy of 10^3 when importing into FLUENT, causing my high quality mesh to become extremely low quality and cause divergence. I would get an error of 'invalid/low volume faces' during mesh check. This was fixed by going into mesh and scaling the model. Simple error but just in case anyone else has a similar issue, might be that. |
February 28, 2019, 06:01 |
#52 | |
March 7, 2019, 03:05 |
#53 |
Rozna
Rep Power: 7 |
hai i have a problem with my icem mesh, while loading it to fluent i get the following error:
WARNING: The mesh contains high aspect ratio quadrilateral, hexahedral, or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. pls can u help me |
March 7, 2019, 03:08 |
#54 | |
Rozna
Rep Power: 7 |
March 8, 2019, 09:35 |
#55 |
Gert-Jan
Rep Power: 28 |
Can be anything. Check & smooth your mesh in ICEM. Then smooth the mesh in fluent.
If it does not help then remeseh it in ICEM with better settings. |
March 8, 2019, 11:33 |
#56 | |
Try to run this case in Fluent and see what happens. Use double precision solver |
March 14, 2019, 02:34 |
#57 |
Rozna
Rep Power: 7 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Polyhedral Mesh Quality in Star-CCM+ | niazaliahmed | STAR-CCM+ | 3 | March 8, 2012 14:51 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 23:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
